I have very simple question on obvious but I am not sure what I am missing to make TTL Serialprint (Serial1.Print) statement functional. Can you please help
I reference the link @ https://www.pjrc.com/teensy/td_uart.html. The only difference on my end is different TTL converter (picture of connection attached) to use a premade TTL-RS232 conversion. I purchases a FTDI USB-TTL device from here- https://www.amazon.com/gp/product/B075N82CDL/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 . I did a quick check on this UART loopback and it works; tried various baud rate
What am I missing? I am trying to build Teensy3.6 as a HID sensor device and running into issue. I like to better way to debug the code on all flows to see HID commands coming from OS side ( and not rely on USB serial)
Here is my pin connection
Teensy - FTDI
(Pin0) Rx - Rx
(Pin1) Tx - Tx
Gnd - Ground
Is RX-TX need to be swapped. Not sure I need to connect the Vcc (3.3V) on both side. I did connected both end Vcc (3.3) together earlier). I verified the Vcc is ~3.3V sepeately on both ends (while disconnected) Could it be damaged?
Below is a simple code snippet.
What am I missing. Any pointer will help. Thanks for sharing info
Teensy - FTDI
(Pin0) Rx - Rx
(Pin1) Tx - Tx
Gnd - Ground
#define Uart Serial1
Uart.begin(9600);
Serial.println("Hello World...");
Uart.print("Hello serial");
delay(1000); // do not print too fast!
