Results 1 to 3 of 3
Thread: Adafruit TFT ILI9341
    Mar 2020
    4
    I am trying to use the following code just to test my screen and continue on my project. Adds a grid to what it should look like which is a grid of colored buttons, but also seems stretched. Currently have the MOSI connected to 11 on teensy, and 10 to CS. MISO to 12, 6 to D/C
    #include "Adafruit_GFX.h"
    #include "Adafruit_HX8357.h"
    #define TFT_CS 11
    #define TFT_DC 6
    #define TFT_RST 0 // RST can be set to -1 if you tie it to Arduino's reset
    #define XMAX 320
    #define YMAX 480
    #define BWIDTH 110
    #define BHIGHT 90
    uint16_t clr = HX8357_GREEN;
    // Use hardware SPI
    Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
      //tft.reset();
      tft.begin();
      tft.fillScreen(HX8357_BLACK);
      static bool pressed;
      tft.fillRoundRect(30, 30, BWIDTH, BHIGHT, 5, 0xFFFF - clr);
      tft.fillRoundRect(XMAX - 30 - BWIDTH, 30, BWIDTH, BHIGHT, 5, clr);
      tft.fillRoundRect(XMAX - 30 - BWIDTH, YMAX/2 - BHIGHT/2, BWIDTH, BHIGHT, 5, clr);
      tft.fillRoundRect(30, YMAX/2 - BHIGHT/2, BWIDTH, BHIGHT, 5, 0xFFFF - clr);
      tft.fillRoundRect(XMAX - 30 - BWIDTH, YMAX - 30 - BHIGHT, BWIDTH, BHIGHT, 5, clr);
      tft.fillRoundRect(30, YMAX - 30 - BHIGHT, BWIDTH, BHIGHT, 5, 0xFFFF - clr);
      uint16_t button = digitalRead(35);
      if (button)
        if (!pressed)
          clr = random(0xFFFF);
        pressed = true;
        pressed = false;
      delay(20);
    6,363
    Looks like you are ysing the wrong library?
    Should be:
    #include "Adafruit_ILI9341.h"
    The HX8357 is a larger display with more pixels...
    Mar 2020
    4
    heh. Should have noticed that. Thank you Kurt. Will probably be back later with a different kind of question.
