USB Audio & Frank B's samplerate change code
PE4WJ
I am trying to use a Teensy 3.6 as a soundcard (essentially along the lines of the PassThroughStereo and WavFilePlayerUSB examples), this works perfectly fine at 44.1 kHz for both recording and playback but I would like to run it at 192 ksample/sec. I have tried to use Frank B's sample rate change code but when playing back it seems that the PC still outputs at 44100 sample/sec but the Teensy expects 192 ksample/sec leading to weird sounding audio. When recording and running an FFT on the recorded samples, I can see a clear lowpass characteristic, cutting off at 22050 Hz so something is not in order. Any clues appreciated!
Wouter Jan PE4WJ
Can't say much about that, but part of the issue might be this:
https://github.com/PaulStoffregen/cores/blob/master/teensy3/usb_dev.c#L472
(At least it should use the AUDIO_SAMPLE_RATE... unfortunately Paul changed this to 44117 (why?) so some tricks would be needed to correct this)
I use this: https://github.com/FrankBoesing/Arduino-Teensy-Codec-lib/blob/master/codecs.h#L66
I'd try to patch these lines and see what happens....
