Adafruit TFT ILI9341 for Visualizer
jdevlami
Currently working on a visualizer, music is coming from a Bluetooth module that is currently connected to speakers. Just trying to get it to be like a screensaver, where after a few seconds of not touching the screen (where there are currently buttons not tied to anything) to a visualizer going along with the music... I don't know where to continue from the buttons screen.
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#include "TouchScreen.h"
#include "Buttons.h"
#include <stdint.h>
#define BACK_CLR ILI9341_BLACK
#define numButt 6
Button b[numButt];
Button bSingle[numButt];           // single screen
int bSize = sizeof(Button);
#define TFT_CS_0 10
#define TFT_DC_0 6
#define TFT_RST 0
#define numScr 1
#define XP 3
#define YP 1
#define XM 2
#define YM 4
Adafruit_ILI9341 tft = { Adafruit_ILI9341(TFT_CS_0, TFT_DC_0, TFT_RST)};    // screen
// measured 282 ohms accross the X plate
TouchScreen ts = { TouchScreen(XP, YP, XM, YM, 298)};      // touch screen
  tft.begin();
  tft.fillScreen(BACK_CLR);
  // initialise buttons on screen
  int xOffset = 30;                                 // offset from x edge
  int yOffset = 30;                                 // offset from y edge
  int numBX = 2;                                    // number of buttons along the x axis per screen
  int numBY = 3;                                    // number of buttons along the y axis per screen
  int xDiff = (tft.width()) / numBX;             // distance between buttons on x axis per screen
  int yDiff = (tft.height()) / numBY;            // distance between buttons on y axis per screen
  for (int i = 0; i < numBX; i++) {
    for (int j = 0; j < numBY; j++) {
      b[j+numBY * i] = B_Init_Def(b[j + numBY * i],xOffset + i * xDiff,yOffset + j * yDiff);
  for (int i = 0; i < numButt; i++) {
    tft.fillRoundRect(b[i].x, b[i].y, b[i].width, b[i].height, b[i].r, b[i].clr);
 static boolean set = false;
 if (!set) {
   set = true;
   setupSingle();
 singleScreen();
 void setupSingle() {
  digitalWrite(LED_BUILTIN,1);
  // fill other screens with grey, this may not be possible
  for (int i=0; i < numScr; i++)
    if (i != 1)
      tft.fillScreen(0x8410);
  // initialise buttons on left screen
  int bHeight = DEF_B_HEIGHT - 40;                   // height of buttons
  int bWidth = DEF_B_WIDTH - 42;                     // width of buttons
  int xOffset = 20;                                 // offset from x edge
  // place buttons in an even grid formation
      bSingle[j + numBY * i] = B_Init(bSingle[j + numBY * i], xOffset + i * xDiff, yOffset + j * yDiff, bHeight, bWidth, 5, DEF_B_CLR, 1);
  // Draw to screens
    tft.fillRoundRect(bSingle[i].x, bSingle[i].y, bSingle[i].width, bSingle[i].height, bSingle[i].r, bSingle[i].clr);
 void singleScreen() {
  static int led = 1;
  static int cnt = 0;
  if (cnt++ > 200) {
    digitalWrite(LED_BUILTIN, led ^= 1);
    cnt = 0;
  // If touchscreen pressed
  static int fCnt = 0;
  static int lastX = 0, lastY = 0;
  // Read from touchscreens
  TSPoint p = ts.getPoint();
  // When touch detected
  if (p.z > ts.pressureThreshhold) {
    // scale from 0->1023 to tft.width
    p.x = map(p.x, 920, 120, tft.width(), 0);
    p.y = map(p.y, 935, 75, tft.height(), 0);
    // button press to change color
    if (!digitalRead(5))
      // only when pressed, not continuously
      if (fCnt > 30) {
          if (isPressed(bSingle[i], p.x, p.y)) {
            // if red, change to green
            if (bSingle[i].clr == 0xF81F) {
              bSingle[i].clr = ILI9341_GREEN;
              Serial.print("Channel "); Serial.print(i, DEC); Serial.println(" connected");
              // all other green buttons change red
              for (int j = 0; j  < numButt; j++) {
                if (j != i) {
                  if (bSingle[j].clr == ILI9341_GREEN) {
                    bSingle[j].clr = ILI9341_RED;
                    tft.fillRoundRect(bSingle[j].x, bSingle[j].y, bSingle[j].width, bSingle[j].height, bSingle[j].r, bSingle[j].clr);
                    Serial.print("Channel "); Serial.print(j, DEC); Serial.println(" disconnected");
            else {
              // change to red if green
              bSingle[i].clr = 0xF800;//random(0xFFFF);
              Serial.print("Channel "); Serial.print(i, DEC); Serial.println(" disconnected");
            // redraw pressed button
      // allow button to be moved
        // button must move a small distance before it registers
        if (abs(lastX - p.x) > 5 || abs(lastY - p.y) > 5) {
          // first time button pressed
          if (fCnt > 5) {
            lastX = p.x;
            lastY = p.y;
          // remove last button, print new
            tft.fillRoundRect(bSingle[i].x, bSingle[i].y, bSingle[i].width, bSingle[i].height, bSingle[i].r, BACK_CLR);
            tft.fillRoundRect(bSingle[i].x += p.x - lastX, bSingle[i].y += p.y - lastY, bSingle[i].width, bSingle[i].height,bSingle[i].r, bSingle[i].clr);
            lastX = p.x;
            lastY = p.y;
    fCnt = 0;
    fCnt++;
I should update this with some clarifying. I just need to figure out how to do the visualizer. I thought it would be cool to use the touchscreen to visually show changes in the music that gets played.
Code changes still in progress, but so far reduced buttons because 6 were too many.
