Results 1 to 9 of 9
Thread: Teensy 3.5 analog input always returns 65535
    Jan 2020
    13
    I measured it with my meter and the voltage between analog input pin and GND / analogGND (I have them connected) is 2.36V, but the analogRead() funcion always returns 65535. I used jumper cable to connect pin to GND and readings went to 0, so something works, but it doesn't work as it should or as I expected it.
    The voltage source is this voltage divider, BATT_LVL goes to pin 22 on Teensy 3.5.
    Edit: I've found the culprit - getting CPU temperature using <InternalTemperature.h> library. Do you have any idea, why this library made analogRead() useless?
    maybe you have set your reference voltage to INTERNAL, wich is 1.2 Volt für teensy 3.5
    Germany NRW
    6,499
    2,382
    Quote Originally Posted by WGSpacetime View Post
    The default setting (begin()) for InternalTemperature lib will do analogReference(INTERNAL); (1.2v)
    As Frank notes, without seeing your sketch, we can only guess.
    Jan 2020
    13
    I have hundreds lines of code that requires multiple external components in order to work... and my problem was specifically that one thing... nobody would even try to understand that code, not to mention finding all the components and physically testing it...
    2,382
    Ah, then your challenge becomes developing a small program that exhibits the problem. In this case, it seems a small program that uses InternalTemperature and reads an analog pin with 2.4v on it. Experiment with the different values to begin() in InternalTemperature lib.
    6,306
    As mentioned it is sort of hard to help here when there is nothing to check.
    That is are you using the library: https://github.com/LAtimes2/InternalTemperature ?
    How are you calling it? How are you reading the analog pin? Are you using the built in analogRead(pin) code
    or are you using ADC library? or...
    Again why I ask, is there are comments in that library:
      // Note: If settings_type is TEMPERATURE_MAX_ACCURACY, it will change
      //       the ADC settings to be optimal for reading temperature.
      //       If settings_type is TEMPERATURE_NO_ADC_SETTING_CHANGES, it will
      //       keep the default ADC settings or any other settings changes.
      //       readTemperature will detect the current settings and use them.
      bool begin (int temperature_settings_type = TEMPERATURE_MAX_ACCURACY);
    2,382
    I reproduced your problem with this simple sketch using Arduino 1.8.11 and TD 1.51-beta1
    // Teensy 3.x/LC simple internal temperature
    #include <InternalTemperature.h>
    InternalTemperature temperature;
      analogWrite(A21, 192);  // 2.5v on DAC0 jumper to A8 (pin 22)
      analogReadResolution(16);
      temperature.begin(1);   // 0 max/internal(1.2v)   1 external 3.3v
      while (!Serial);
      Serial.print("Temperature: ");
      Serial.print(temperature.readTemperatureC(), 1);
      Serial.println("°C");
      uint32_t val = analogRead(A8);  // pin 22
      Serial.printf("A8 %d %.2f v\n", val, 3.3 * val / 65536);
      delay(3000);
    CORRECTION: do DAC before all else to get 2.48 v on DAC pin.
    I use the T3.5 DAC0 to produce 2.48 v on pin A21 jumpered to pin 22 (A8), using the latest InternalTemperature lib and Teensy analogRead(). The analogRead() is 65535 when using 0 (default) for the temperature.begin(). When using temperature.begin(1), analogRead returns expected value.
    2,382
    I corrected post #8
