Results 1 to 14 of 14
Thread: Teensy 4.0 w/ TF Mini LIDAR issue
    Mar 2020
    8
    Hi all, I am having issues getting a Benewake TF mini lidar unit to work on a teensy 4.0. I am using the library https://github.com/opensensinglab/tfmini . The following code works just fine on an arduino uno but I cant get this code to work on the teensy. I tried pins 0 and 1 on the teensy and putting said changes in the code as well to no avail. All i see on the serial monitor is "initializing...". Is this a library issue? Any guidance in getting this Lidar to work on the teensy is much appreciated. Thank you all for your time.
    #include <SoftwareSerial.h>
    #include "TFMini.h"
    SoftwareSerial mySerial(10, 11); // Uno RX (TFMINI TX), Uno TX (TFMINI RX)
    TFMini tfmini;
    Serial.println ("Initializing...");
    mySerial.begin(TFMINI_BAUDRATE);
    tfmini.begin(&mySerial);
    // Take one TF Mini distance measurement
    uint16_t dist = tfmini.getDistance();
    uint16_t strength = tfmini.getRecentSignalStrength();
    // Display the measurement
    Serial.print(dist);
    Serial.print(" cm sigstr: ");
    Serial.println(strength);
    delay(25);
    10,946
    Not sure if this page is current: pjrc.com/teensy/td_libs_SoftwareSerial.html
    From that page … any better with ::
    #define rxPin 0
    #define txPin 1
    // set up a new serial port
    SoftwareSerial mySerial =  SoftwareSerial(rxPin, txPin);
    void setup()  {
      // define pin modes for tx, rx, led pins:
      pinMode(rxPin, INPUT);
      pinMode(txPin, OUTPUT);
    New York
    4,809
    When you said you tried to use pins 0 and 1, were you still trying to use SoftwareSerial? Also not sure software serial has been updated to work with T4.0 yet. However with that said you would probably be better off using one of H/W serial ports. So, for instance if you want to use Serial1 (pins 0 and 1):
    #include "TFMini.h"
    TFMini tfmini;
    #define mySerial  Serial1
    6,341
    As mentioned, if you are free to use other pins.
    Example pin 0, 1 than you should use the hardware serial port. As @mjs513 mentioned would be Serial1
    If you have fixed pins like pins 10 and 11, than you might be able to use my FlexIO stuff, where I have Serial port emulation using Flex IO pins.
    Mar 2020
    8
    I put the rx and tx on the respective 0 and 1 pins and included the code you recommend. On the serial monitor it did not even display "initializing".
    #include "TFMini.h"
    TFMini tfmini;
      Serial.print(dist);
      // Wait some short time before taking the next measurement
      delay(25);
    New York
    4,809
    Did you attach rx-tx and tx to rx? or did you match rx-rx and tx-tx?
    Mar 2020
    8
    #define rxPin 0
    #define txPin 1
    void setup()  {
    I put the tx and rx on the respective pins and tried your code with...
    #include "TFMini.h"
    #define rxPin 0
    #define txPin 1
    TFMini tfmini;
      Serial.print(dist);
      delay(25);
    I couldn't get anything on serial monitor.
    6,341
    Again as suggested, you might want to do it more like:
    #include "TFMini.h"
    TFMini tfmini;
      // wait up to 4 seconds for serial monitor to be valid
      while (!Serial && millis() < 4000) ;
      Serial1.begin(TFMINI_BAUDRATE);
      tfmini.begin(&Serial1);
      Serial.print(dist);
      delay(25);
    Note: the added while (!Serial...
    It waits up to 4 seconds for the USB serial object to be initialized and connected to the pc before it continues. Unlike Arduinos like UNOs which have a separate processor (or interface chip) that does USB, the Teensy itself does serial (like Arduino Leonardo), so if you print something out at startup time before your PC has registered the usb object you might miss the output.
    Also note, I am using the Serial1 hardware setup and not the Software Serial code.
    Mar 2020
    8
    White wire to pin 0 (RX1) , green wire to pin 1 (TX1) , red wire to 5 volt Vin, black wire to GND next to VIN.
    New York
    4,809
    Think you have Rx and Tx wired in correctly.
    Green wire (Tx) -> pin 0 (Rx) on T3.6
    While wire (Rx) -> pin 1 (Tx) on T3.6
    Red (5v) -> Vin on T3.6
    GND -> GND on T3.6 (pin right before pin 0).  GND next to Vin is for Audio Gnd.
    This might help with the wiring:
    https://www.instructables.com/id/Ben...ith-Teensy-35/
    Mar 2020
    8
    I was not aware that the teensy itself does serial. I copied your code verbatim. The serial monitor didn't print the "initializing" and is blank.
    Appreciate all of your help. Relatively new to Arduino and completely new to teensy.
    New York
    4,809
    Did you see my post on the wiring and try it in that configuration. Post #10
    10,946
    Quote Originally Posted by cbennett View Post
    Indeed Teensy LC, 3.2, 3.5 and 3.6 and 4.0 all have 3 or more native Serial UART ports. As noted in the P#2 'out of date link':
    The hardware UART Serial port should always be used, if possible, before considering SoftwareSerial. On Teensy, the hardware UART serial port completely separate from the USB port.
    Some Arduino software seems to still rely on or require software Serial - but where possible using the Native Serial hardware results in better performance with less processor overhead, especially on those ports with a FIFO.
    When using Serial the Rx on one side must be connected to the Tx on the other side in both directions and they must share a common GND connection. And the UART signals are delivered and expected from Teensy at 3.3 volts - and on LC, and 3.6 and 4.0 voltage must be limited to 3.3V.
    Mar 2020
    8
    Yes, was unaware tx -> rx and vice versa. Thanks for all your help!
