Hi all,
As this is my 1st post let me introduce myself. I'm CAR, a mechanical engineer struggling to learn embedded coding and some electronics.
After learning the basics, I proposed myself to sample a 100kHz signal. To test it, I used an internal PWM of my Teensy 4.0.
To measure time, I use the IntervalTimer function included in Teenduino, nevertheless, whenever I try to sample at a frequency below 1.6us I'm unable to capture any data. Could anybody help me?
In my opinion, I'd need a sample rate of 1MHz to properly measure the signal that I intend to measure and, as far as I understood the F_BUS is 150MHz in the Teensy 4.0 so It should be more than enough.
Thank you very much,
CAR
// Fast Measure code
#include <ADC.h>
#include <ADC_util.h>
#define SAMPLES (10000) // how many samples to combine for pp, std.dev statistics
IntervalTimer myTimer;
const byte readPin = A0; // ADC0
const byte interruptPin = 18;
const byte pwmtrig = 6;
const float init_t = 1.0;
// Volatile variables, change in the interrupt
volatile float x[SAMPLES][2];
volatile int i;
volatile float t=init_t;
ADC *adc = new ADC(); // adc object;
pinMode(interruptPin, INPUT_PULLUP);
pinMode(readPin, INPUT);
pinMode(pwmtrig, OUTPUT);
analogWriteFrequency(pwmtrig, 101000);
analogWriteResolution(8);
analogWrite(pwmtrig, 127);
Serial.begin(115200); //Ignored if using USB.
///// ADC0_Set-up /////
// This is where we set-up the ADC.
adc->adc0->setAveraging(1);
adc->adc0->setResolution(10); // set bits of resolution
adc->adc0->setConversionSpeed(ADC_CONVERSION_SPEED::HIGH_SPEED); // change the conversion speed
adc->adc0->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPEED);
///// Timer1 Set-up /////
// Interrupt for signal trigger
attachInterrupt(digitalPinToInterrupt(interruptPin), TrigMeas, RISING);
void loop(){
//END OF MEASURE CONDITION
if (i == SAMPLES)
myTimer.end();
PrintValues();
i = 0;
t = 1.0;
void TrigMeas() {
// Here there is usually a set of intructions. Erased for clarity
myTimer.begin(Read, init_t); // call every init_t us "ticks"
void Read() {
x[i][0] = t;
x[i][1] = analogRead(readPin);
i = i + 1;
t = t + init_t;
void PrintValues(){
Serial.println("Time Voltage");
for (int i=0;i<SAMPLES;i++) {
Serial.print(x[i][0]);
Serial.print(" ");
Serial.println(x[i][1]);
CAR
