Hi all,
Since I'm currently closed indoors I decided to do something with some circuit components that I currently have at home. I decided to make a basic piano with only pieces that I have at home.
Currently I found a:
- Teensy LC
- ADAFRUIT MONO 2.5W CLASS D AUDIO AMPLIFIER - PAM8302
- Speaker, CMS-16093-078L100, 8 Ohms General Purpose Speaker 700mW 100Hz ~ 20kHz
- Soft tactile buttons
- Breadboard and shunts.
Currently I started to map each button in a script, but now I am stuck has I don't have enough knowledge on how I should connect the amp to the teensy, so coming here for support and help on build this.
Current setup images:
https://imgur.com/a/hbVFx4t
Including here the code that I have so far as requested:
- Teensy LC
#include <Bounce.h>
// Digital Pad
Bounce btn_C3 = Bounce( 0, 10);
Bounce btn_Cs3 = Bounce( 1, 10);
Bounce btn_R3 = Bounce( 2, 10);
Bounce btn_Rs3 = Bounce( 3, 10);
Bounce btn_M3 = Bounce( 4, 10);
Bounce btn_F3 = Bounce( 5, 10);
Bounce btn_Fs3 = Bounce( 6, 10);
Bounce btn_G3 = Bounce( 7, 10);
Bounce btn_Gs3 = Bounce( 8, 10);
Bounce btn_A3 = Bounce( 9, 10);
Bounce btn_As3 = Bounce( 10, 10);
Bounce btn_B3 = Bounce( 11, 10);
Bounce btn_C4 = Bounce( 12, 10);
Bounce btn_Cs4 = Bounce( 13, 10);
Bounce btn_R4 = Bounce( 14, 10);
Bounce btn_Rs4 = Bounce( 15, 10);
Bounce btn_M4 = Bounce( 16, 10);
Bounce btn_F4 = Bounce( 17, 10);
Bounce btn_Fs4 = Bounce( 18, 10);
// open the serial port at 9600 bps:
pinMode( 0, INPUT_PULLUP); //btn_C3
pinMode( 1, INPUT_PULLUP); //btn_Cs3
pinMode( 2, INPUT_PULLUP); //btn_R3
pinMode( 3, INPUT_PULLUP); //btn_Rs3
pinMode( 4, INPUT_PULLUP); //btn_M3
pinMode( 5, INPUT_PULLUP); //btn_F3
pinMode( 6, INPUT_PULLUP); //btn_Fs3
pinMode( 7, INPUT_PULLUP); //btn_G3
pinMode( 8, INPUT_PULLUP); //btn_Gs3
pinMode( 9, INPUT_PULLUP); //btn_A3
pinMode( 10, INPUT_PULLUP); //btn_As3
pinMode( 11, INPUT_PULLUP); //btn_B3
pinMode( 12, INPUT_PULLUP); //btn_C4
pinMode( 13, INPUT_PULLUP); //btn_Cs4
pinMode( 14, INPUT_PULLUP); //btn_R4
pinMode( 15, INPUT_PULLUP); //btn_Rs4
pinMode( 16, INPUT_PULLUP); //btn_M4
pinMode( 17, INPUT_PULLUP); //btn_F4
pinMode( 18, INPUT_PULLUP); //btn_Fs4
// Update all the buttons
btn_C3.update();
btn_Cs3.update();
btn_R3.update();
btn_Rs3.update();
btn_M3.update();
btn_F3.update();
btn_Fs3.update();
btn_G3.update();
btn_Gs3.update();
btn_A3.update();
btn_As3.update();
btn_B3.update();
btn_C4.update();
btn_Cs4.update();
btn_R4.update();
btn_Rs4.update();
btn_M4.update();
btn_F4.update();
btn_Fs4.update();
// Check each button for "falling" edge (= high (not pressed - voltage from pullup resistor))
if( btn_C3.fallingEdge() ) {
Serial.print("C3 ");
if( btn_Cs3.fallingEdge() ) {
Serial.print("Cs3 ");
if( btn_R3.fallingEdge() ) {
Serial.print("R3 ");
if( btn_Rs3.fallingEdge() ) {
Serial.print("Rs3 ");
if( btn_M3.fallingEdge() ) {
Serial.print("M3 ");
if( btn_F3.fallingEdge() ) {
Serial.print("F3 ");
if( btn_Fs3.fallingEdge() ) {
Serial.print("Fs3 ");
if( btn_G3.fallingEdge() ) {
Serial.print("G3 ");
if( btn_Gs3.fallingEdge() ) {
Serial.print("Gs3 ");
if( btn_A3.fallingEdge() ) {
Serial.print("A3 ");
if( btn_As3.fallingEdge() ) {
Serial.print("As3 ");
if( btn_B3.fallingEdge() ) {
Serial.print("B3 ");
if( btn_C4.fallingEdge() ) {
Serial.print("C4 ");
if( btn_Cs4.fallingEdge() ) {
Serial.print("Cs4 ");
if( btn_R4.fallingEdge() ) {
Serial.print("R4 ");
if( btn_Rs4.fallingEdge() ) {
Serial.print("Rs4 ");
if( btn_M4.fallingEdge() ) {
Serial.print("M4 ");
if( btn_F4.fallingEdge() ) {
Serial.print("F4 ");
if( btn_Fs4.fallingEdge() ) {
Serial.print("Fs4 ");
