Teensy 3.5 & wiz820 ethernet UDP speed problem
microguy
I try to send some UDP packet from a first Teensy 3.5 with wiz820 eth module to a 2nd Teensy 3.5 with wiz820 eth module and a straight cable between the two.
First : when I send packet from the first Teensy to my computer, packet are sent with the right timing : each 20ms ---> no problem
second: when I send packet from my computer to my second Teensy, Teensy received packet ---> no problem
But when I send packet from the first Teensy to nothing or to the second Teensy, timing are very bad (send packet?? every 2s) and the second teensy never received any packet...
Do you Know, why the first Teensy seems to wait for something? slow down and never send the packet? and try each 2s instead of 20ms?
#include <Ethernet.h>
#include <EthernetUdp.h>
//FOR ETHERNET:
#define ethRSTpin 9
#define ethCSpin 10
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };  // MAC and IP controller address
IPAddress ip(192, 168, 1, 178);
unsigned int localPort = 8888;  // local port to listen on
EthernetUDP Udp;  // An EthernetUDP instance to let us send and receive packets over UDP
elapsedMillis TsincelastUDPOut; // increase as time elapses. will be reseted after each UDP send
int RefreshT = 20; //interval beetwen two UDP send
  // set serial com
  delay(3000);
  Serial.println("HELLO");
  //Start wiz ethernet module
  pinMode(ethRSTpin, OUTPUT);
  digitalWrite(ethRSTpin, LOW);
  digitalWrite(ethRSTpin, HIGH);
  Ethernet.init(ethCSpin);  // Ethernet.init(pin) to configure the CS pin
  Ethernet.begin(mac,ip);  // start the Ethernet
  // start UDP
  Udp.begin(localPort);
  Serial.println("End of Ethernet init");
//END OF INIT
    if (TsincelastUDPOut >= RefreshT) {
    TsincelastUDPOut = TsincelastUDPOut - RefreshT;
    Serial.println("send");
    char dataOut[11]= "speed test";
    Udp.beginPacket("192.168.1.174",8888);
    Udp.write((byte *)&dataOut,sizeof dataOut);            //Write packet which contains data structure
    Udp.endPacket();                                       //Close Packet and send
are you using an ethernet crossover cable between the two wiznet modules? (Rx to Tx, Tx to Rx) I don't think wiznet supports auto MDI-X
No, I'm using a normal cable but the wiz820 dtasheet says : "Supports auto-negotiation and auto cross-over detection", so I think it's OK?
OK, now, I can send and receive with good timing...but I have to follow a startup sequence. start receiver before sender... very strange. If not, sender never start....It tries every 2s but without success
No more problem: I just add this on setup:
  if(Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Ethernet cable is not connected.");
    while (Ethernet.linkStatus() == LinkOFF) {
      delay(1);
maybe it can help others...
