Looks awesome, can't wait to see the details and hear the result.
Here is a link to a sound cloud demo of the Draw Bar Organ module.
https://soundcloud.com/lsrichard/draw-bar-organ-demo-1
Here is the master wiring schematic.
IT uses a Teensy 4.0 attached to a Rev.D audio board and a Teensy 3.6 to handle the touch screen display and patch loading from the SD card.
They communicate with each other with a standard serial connections sending different parameters to each other.
Here is the power supply and audio output section ect.
I am not sure how to rotate images when I post them.
I am using the stereo output of the audio board in a differential format with normal and inverted output.
This is to help cancel out any digital noise and helps make the noise floor lower.
The audio section also has a 7KHz low pass filter and is isolated with an output transformer.
The isolation is mostly only needed when it is connected to a computer thru the programming ports.
The sound cloud demo link will continue to play the other unrelated files on my sound cloud account after the organ demo has completed.
Not sure how to stop this and I can not delete the other files from a project 6 years ago.
Just push the pause button on sound cloud after the organ demo is done.
- You may not post replies
- You may not edit your posts
Forum Rules
