I am trying to read a synchronous serial stream from an odd source which provides a clock at about 1MHz to 5MHz but supplies and receives data at various divisions of this frequency, starting at about 9600 baud (a divisor of 372). This divisor can change by negotiation which take place in the stream of data.
I am trying to use TPM0 to do this using an initial modulus of 372 and no pre-scaling. I've had my head in the KL26 reference manual and been rattling around the forums (fora?) for several days now and would very much appreciate someone pointing out to me how stupid I am and more importantly how and where.
Here is my code so far followed by the test results it produces. I have a 3V signal running at about 300Hz on Pin 13 which flashes the LED (if I run the sig-gen slower). I have another LED on pin 23 (which just comes on and stays on). The delay(5000) statements just give me chance to start the serial monitor screen.
And the results:
#include <print.h>
#include <avr/io.h>
#include <avr/interrupt.h>
uint16_t UICC_Li = 372;
bool LED_State = LOW; // for debugging, NOT on Pin13
void setup () { //################################################## Setup #######################################################
Serial.begin(9600); //USB serial port used for debugging
pinMode(10, INPUT); // Pin10: SerialTX = HiZ for now
pinMode(12,INPUT); // SIM RESET Request
pinMode(11, INPUT); // SIM Clock
pinMode(6, INPUT); // SIM Powered (eg 1.8V)
pinMode(5, OUTPUT); // SIM Output Enable
digitalWrite(5, LOW); // SIM Ourput Enable = False
pinMode(23, OUTPUT); // LED for debugging
LED_State = HIGH;
digitalWrite(23, LED_State);
delay(5000); //Allow time to engage serial monitor
Serial.println("Hello");
dbgPrint(); // sends debugging information to usb serial
// INIT TPM0 for etu serial UICC IO clock
//TPM0_SC = 0x0; //clear
TPM0_MOD = UICC_Li; // fix the modulus for now (probably 372dec)
// TMP0_CnV / TMP0_CnSC - None set for now, just using the raw counter overflow
// TMP0_STATUS is only convenient copy of CnV and SC overflow flags (read-only?)
TPM0_CONF = 0; //Clear Don't think anything needs doing in here.
TPM0_SC = 0;
Serial.print("TMP0 Cleared -> ");
dbgPrint();
TPM0_SC = 0x50;;
Serial.print("TMP0 Set x50 -> "); TPM0_SC = 0x50;
dbgPrint();
TPM0_SC |= (1<<7); //Clear Timer Overflow Flag
Serial.print("TMP0TOF Clrd -> "); TPM0_SC = 0x50;
dbgPrint();
//TPM0_SC |= (1<<6); // (BIT6) TOIE interrupt enable
//TPM0_SC |= 0x10; // (BITS3&4) CMOD enabled (external pin) rising edge up counter
// so: TPM0 Enabled, NOT DMA, Interupt Enabled, Ext Clock, Up Count, no prescaling.
// TPM0_SC |= (1<<7); //Clear Timer Overflow Flag
//CORE_PIN13_CONFIG = PORT_PCR_MUX(3);
TPM0_CNT = 0;
} // Setup section
void loop () { //################################################## Loop #######################################################
dbgPrint();
void FTM0_isr(void)
LED_State = !LED_State;
Serial.println(" Interrupt Handled!");
void dbgPrint(void)
Serial.print("TPM0_SC : ");
Serial.print(TPM0_SC, HEX);
Serial.print(" TPM0_CNT : ");
Serial.print(TPM0_CNT, HEX);
Serial.print(" TPM0_MOD : ");
Serial.println(TPM0_MOD, HEX);
And the results:
Hello
TPM0_SC : 89 TPM0_CNT : B6CC TPM0_MOD : BFFF
TMP0 Cleared -> TPM0_SC : 81 TPM0_CNT : B947 TPM0_MOD : 174
TMP0 Set x50 -> TPM0_SC : D0 TPM0_CNT : B947 TPM0_MOD : 174
TMP0TOF Clrd -> TPM0_SC : D0 TPM0_CNT : B947 TPM0_MOD : 174
Hello
TPM0_SC : D0 TPM0_CNT : 0 TPM0_MOD : 174
