bossredman
I have made a midi footcontroller for my Akai MPC live.
It's quite basic due to the limited midi functionality of the MPC device itself.
ie 6 switches (momentary) sending of either Program Change (PC) & sysex msgs to the MPC.
2 LED's - 1 to indicate the MFC is powered - 1 to indicate when a switch is pressed.
The footcontroller uses a Teensy 3.2 along with the usbmidi.
It uses USB to both power teh Teensy & send the midi commands.
Everything works fine if the Teensy is booted up AFTER the MPC.
But if I leave the Teensy connected to the MPC during boot up - it fails to work & I have to unplug & plug in .
It then works fine.
Any ideas what the issue may be here pls.
The code is very basic & quite small.
It then works fine.
#include <Bounce.h> //Buttons
#include <elapsedMillis.h>
#define BUTTON1 23 //Sequence DECREMENT & Sequence 1
#define BUTTON2 22 //Sequence INCREMENT & Sequence 2
#define BUTTON3 20 //Sequence 3
#define BUTTON4 21 //Sequence 4
#define BUTTON5 14 //PLAY/STOP & Sequence 5
#define BUTTON6 15 //PLAY FROM START & Sequence 6
#define LED_GREEN 6
#define LED_BLUE 8
Bounce bouncer1 = Bounce(BUTTON1, 50); Bounce bouncer2 = Bounce(BUTTON2, 50); Bounce bouncer3 = Bounce(BUTTON3, 50);Bounce bouncer4 = Bounce(BUTTON4, 50);Bounce bouncer5 = Bounce(BUTTON5, 50);Bounce bouncer6 = Bounce(BUTTON6, 50);
boolean MPC_Playing = false;
int MPC_Seq = 0;
elapsedMillis sincePressIA;
elapsedMillis Running;
elapsedMillis LED_timer;
unsigned long IA_Long_Press = 600;
unsigned long LED_Blink_time = 500;
boolean just_rebooted = true; //tracks if just re-booted
int ledState = LOW; // ledState used to set the LED
unsigned long previousMillis = 0; // will store last time LED was updated
const long interval = 100; // interval at which to blink (milliseconds)
pinMode(LED_BLUE, OUTPUT); pinMode(LED_GREEN, OUTPUT);
digitalWrite(LED_GREEN, HIGH); digitalWrite(LED_BLUE, LOW);
LED_timer = 20000;
//setup pins with pullups
pinMode(BUTTON1,INPUT_PULLUP); pinMode(BUTTON2,INPUT_PULLUP); pinMode(BUTTON3,INPUT_PULLUP); pinMode(BUTTON4,INPUT_PULLUP); pinMode(BUTTON5,INPUT_PULLUP); pinMode(BUTTON6,INPUT_PULLUP);
Serial.println("======= Void SETUP =======");
bouncer1.update(); bouncer2.update(); bouncer3.update(); bouncer4.update(); bouncer5.update(); bouncer6.update();
//1st #############################################################################################################################################################################
if ( bouncer1.fallingEdge()) //MPC Live - Sequence DECREMENT
Serial.println("#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-# Switch: 1");
sincePressIA = 0;
bouncer1.update();
else if ( bouncer1.risingEdge() && (just_rebooted == false))
if (sincePressIA > IA_Long_Press) //Long press
Serial.println("Switch 1 --- LONG - Select Sequence 1");
MPC_Seq = 0;
usbMIDI.sendProgramChange(MPC_Seq, 10 );
LED_timer = 0;
else if (sincePressIA < IA_Long_Press) //Short press
Serial.println("Switch 1 --- SHORT - Sequence DECREMENT");
MPC_Seq = MPC_Seq - 1;
if (MPC_Seq < 0 )
MPC_Seq = 0;
LED_timer = 0;
//2nd #############################################################################################################################################################################
else if ( bouncer2.fallingEdge() ) // MPC Live - Sequence INCREMENT
Serial.println("#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-#-# Switch: 2");
sincePressIA = 0;
bouncer2.update();
else if ( bouncer2.risingEdge() && (just_rebooted == false))
Serial.println("Switch 2 --- LONG - Select Sequence 2");
MPC_Seq = 1;
LED_timer = 0;
Serial.println("Button-2 --- SHORT - Sequence INCREMENT");
MPC_Seq = MPC_Seq + 1;
if (MPC_Seq > 127)
MPC_Seq = 1;
usbMIDI.sendProgramChange(MPC_Seq, 10 ); //Using Channel 10 so not to interfer with AxwFx midi
LED_timer = 0;
//3rd - #############################################################################################################################################################################
else if ( bouncer3.fallingEdge()) //Sequence 3
MPC_Seq = 2;
Serial.println("C - SEquence 3");
LED_timer = 0;
//4th - #############################################################################################################################################################################
else if ( bouncer4.fallingEdge()) //Sequence 4
MPC_Seq = 3;
Serial.println("E - Seq 4");
LED_timer = 0;
//5th - #############################################################################################################################################################################
else if ( bouncer5.fallingEdge() ) //MPC Live - /PLAY/STOP/RE-START
sincePressIA = 0;
bouncer5.update();
else if ( bouncer5.risingEdge() && (just_rebooted == false))
Serial.println("Switch 5 --- LONG - Select Sequence 5");
MPC_Seq = 4;
LED_timer = 0;
Serial.println("Button-5 --- SHORT - PLAY/STOP");
if (MPC_Playing == false)
//MPC-Live - PLAY
byte MPC[6] ={0xF0, 0x7F, 0x7F, 0x06, 0x02, 0xF7};
usbMIDI.sendSysEx(6, MPC);
else if (MPC_Playing == true)
//MPC-Live - STOP
byte MPC[6] ={0xF0, 0x7F, 0x7F, 0x06, 0x01, 0xF7};
usbMIDI.sendSysEx(6, MPC );
MPC_Playing =! MPC_Playing;
LED_timer = 0;
//6th - #############################################################################################################################################################################
else if ( bouncer6.fallingEdge() ) //MPC Live - PLAY @ START POSITION
sincePressIA = 0;
bouncer6.update();
else if ( bouncer6.risingEdge() && (just_rebooted == false))
Serial.println("Switch 6 --- LONG - Select Sequence 6");
MPC_Seq = 5;
LED_timer = 0;
Serial.println("Button-6 --- SHORT - PLAY FROM START");
Serial.println("Play from Start");
//MPC-Live - STOP
byte MPC2[6] ={0xF0, 0x7F, 0x7F, 0x06, 0x01, 0xF7};
usbMIDI.sendSysEx(6, MPC2);
//MPC-Live - RESET to beginning
// 127 0 6 68 6 1 0 0 0 0 0
byte MPC[13] ={0xF0, 0x7F, 0x00, 0x06, 0x44, 0x06, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF7};
usbMIDI.sendSysEx(13, MPC );
//MPC-Live - START
byte MPC1[6] ={0xF0, 0x7F, 0x7F, 0x06, 0x02, 0xF7};
usbMIDI.sendSysEx(6, MPC1);
MPC_Playing = true;
LED_timer = 0;
//4 127 127 6 6, RECORD
// 4 127 127 6 3 DEFERRED PLAY:
//PLAY: 4 127 127 6 2
//STOP: 4 127 127 6 1
//RESET: 11 127 0 6 68 6 1 0 0 0 0 0
just_rebooted = false;
LED_Blink();
//MIDI controllers which only transmit data should be designed to read and ignore all incoming messages. If MIDI-OX or similar software is sending messages to Teensy, this simple code will prevent problems with USB buffers filling up with never-read messages.
while (usbMIDI.read())
// ignoring incoming messages, so don't do anything here.
void LED_Blink()
if (LED_timer > LED_Blink_time)
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval)
// save the last time you blinked the LED
previousMillis = currentMillis;
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(LED_BLUE, ledState);
