//#define NEW_THE_DISP
#include <Adafruit_GFX.h> // Core graphics library
#include <ST7735_t3.h> // Hardware-specific library
#include <ST7789_t3.h> // Hardware-specific library
#include <st7735_t3_font_Arial.h>
#include <Fonts/FreeMonoBoldOblique12pt7b.h>
#include <Fonts/FreeSerif12pt7b.h>
#if defined(__IMXRT1052__) || defined(__IMXRT1062__) // Teensy 4.x
//#define USE_SPI1
//#define USE_SPI2
//#define NON_SPI_PINS
#ifdef USE_SPI2
#define TFT_SCLK 37 //
//#define TFT_MISO 34
#define TFT_MOSI 35 // MOSI can also use pin 7
#define TFT_CS -1//36 // CS & DC can use pins 2, 6, 9, 10, 15, 20, 21, 22, 23
#define TFT_DC 38 // but certain pairs must NOT be used: 2+10, 6+9, 20+23, 21+22
#define TFT_RST 39 // RST can use any pin
#elif defined(USE_SPI1)
#define TFT_SCLK 27 // SCLK can also use pin 14
#define TFT_MOSI 26 // MOSI can also use pin 7
#define TFT_CS 0 // CS & DC can use pins 2, 6, 9, 10, 15, 20, 21, 22, 23
#define TFT_DC 2 // but certain pairs must NOT be used: 2+10, 6+9, 20+23, 21+22
#define TFT_RST 3 // RST can use any pin
#elif defined(NON_SPI_PINS)
#define TFT_SCLK 7 // SCLK can also use pin 14
#define TFT_MOSI 8 // MOSI can also use pin 7
#define TFT_CS 10 // CS & DC can use pins 2, 6, 9, 10, 15, 20, 21, 22, 23
#define TFT_DC 9 // but certain pairs must NOT be used: 2+10, 6+9, 20+23, 21+22
#define TFT_RST 20 // RST can use any pin
#else
#define TFT_SCLK 13 // SCLK can also use pin 14
#define TFT_MOSI 11 // MOSI can also use pin 7
#define TFT_RST 8 // RST can use any pin
#define SD_CS 4 // CS for SD card, can use any pin
#else
// T3.X
//#define USE_SPI1
//#define USE_SPI2
#define USE_SPI1_NOT_HARDWARE_CSDC
#if defined(USE_SPI1_NOT_HARDWARE_CSDC)
#define TFT_SCLK 20 // SCLK can also use pin 14
#define TFT_MOSI 21 // MOSI can also use pin 7
#define TFT_CS 2 // CS & DC can use pins 2, 6, 9, 10, 15, 20, 21, 22, 23
#define TFT_DC 3 // but certain pairs must NOT be used: 2+10, 6+9, 20+23, 21+22
#define TFT_SCLK 32 // T3.5/T3.6
#define TFT_MOSI 0 //
#define TFT_CS 30 // random digital pin
#define TFT_DC 31 // Only Hardware CS pin on SPI1
#define TFT_RST 29 // RST can use any pin
#elif defined(USE_SPI2)
#define TFT_SCLK 46 // T3.5/T3.6
#define TFT_MOSI 44 //
#define TFT_CS 54 // Hardware CS on SPI2
#define TFT_DC 55 // Hardware CS pin on SPI2
#else
//#define TFT_CS2 7
#define TFT_BLK 7
#if defined(NEW_THE_DISP)
ST7735_t3 *ptft = nullptr;
#else
// Option 1: use any pins but a little slower
#if defined(USE_SPI1)
//ST7789_t3 tft = ST7789_t3(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
ST7735_t3 tft = ST7735_t3(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
#else
//ST7735_t3 tft = ST7735_t3(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
ST7789_t3 *ptft = &tft;
// Option 2: must use the hardware SPI pins
// (for UNO thats sclk = 13 and sid = 11) and pin 10 must be
// an output. This is much faster - also required if you want
// to use the microSD card (see the image drawing example)
//ST7735_t3 tft = ST7735_t3(TFT_CS, TFT_DC, TFT_RST);
float p = 3.1415926;
uint8_t use_fb = 0;
void setup(void) {
#ifdef TFT_BLK
pinMode(TFT_BLK, OUTPUT);
digitalWrite(TFT_BLK, HIGH);
pinMode(SD_CS, INPUT_PULLUP); // don't touch the SD card
pinMode(TFT_CS, INPUT_PULLUP);
Serial.print("hello!");
ptft = new ST7735_t3(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
Serial.printf("CS:%d DC:%d MOSI:%d SCLK:%d RST:%d\n", TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
// Use this initializer if you're using a 1.8" TFT
//ptft->initR(INITR_BLACKTAB);
// Use this initializer (uncomment) if you're using a 1.44" TFT
//ptft->initR(INITR_GREENTAB);
ptft->initR(INITR_144GREENTAB);
// ptft->init(240,240) ; // use for ILI9488
ptft->init(240,240, SPI_MODE2) ; // CS challenged
#else
ptft->init(240,240, SPI_MODE2) ; // use for ILI9488
// ptft->initR(INITR_144GREENTAB);
// ptft->initR(INITR_144GREENTAB_OFFSET);
// ptft->initR(INITR_MINI160x80);
//ptft->setRowColStart(0,0);
use_fb = 1;
if (![COLOR="#FF0000"]ptft->useFrameBuffer(true)[/COLOR]) { // lets try using a frame buffer.
Serial.println("\n***** Use Frame Buffer Failed *****\n");
use_fb = 0;
Serial.printf("init CS:%d DC:%d MOSI:%d SCLK:%d RST:%d\n ", TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
Serial.printf("Row Start:%d Col Start: %d\n", ptft->rowStart(), ptft->colStart());
uint8_t rotation = 0;
void drawTestScreen(uint16_t background_color) {
ptft->fillScreen(background_color);
ptft->fillRect(ptft->width() / 2 - 32, 20, 64, ptft->height() - 40, ST7735_GREEN);
ptft->fillRect(ptft->width() / 4 - 16, ptft->height() / 4 - 16, 32, 32, ST7735_BLUE);
ptft->fillRect(ptft->width() * 3 / 4 - 16, ptft->height() * 3 / 4 - 16, 32, 32, ST7735_WHITE);
ptft->fillRect(ptft->width() * 3 / 4 - 16, ptft->height() / 4 - 16, 32, 32, ST7735_BLACK);
ptft->fillRect(0, 0, 8, 8, ST7735_BLACK);
ptft->fillRect(ptft->width() - 8, ptft->height() - 8, 8, 8, ST7735_WHITE);
ptft->drawPixel(0, 0, ST7735_YELLOW);
ptft->drawPixel(1, 1, ST7735_RED);
ptft->drawPixel(2, 2, ST7735_BLUE);
ptft->setCursor(0, ptft->height() / 2 - 4);
ptft->printf("R:%d W:%d H:%d", rotation, ptft->width(), ptft->height());
ptft->drawPixel(ptft->width() - 1, ptft->height() - 1, ST7735_YELLOW);
ptft->drawPixel(ptft->width() - 2, ptft->height() - 2, ST7735_RED);
ptft->drawPixel(ptft->width() - 3, ptft->height() - 3, ST7735_BLUE);
void printTextSizes(const char *sz) {
Serial.printf("%s(%d,%d): SPL:%u ", sz, tft.getCursorX(), tft.getCursorY(), tft.strPixelLen(sz));
int16_t x, y;
uint16_t w, h;
tft.getTextBounds(sz, tft.getCursorX(), tft.getCursorY(), &x, &y, &w, &h);
Serial.printf(" Rect(%d, %d, %u %u)\n", x, y, w, h);
void drawTextScreen(bool fOpaque) {
Serial.println("Enter drawTextScreen"); Serial.flush();
tft.fillScreen(ST77XX_RED);
Serial.println("After Fill screen"); Serial.flush();
//tft.setFont();
tft.setCursor(0, 5);
tft.setFont();
Serial.println("After Set font"); Serial.flush();
printTextSizes("SysFont");
Serial.println("After print Text sizes"); Serial.flush();
tft.println("SysFont");
if (fOpaque)
tft.setTextColor(ST77XX_WHITE, ST77XX_BLACK );
tft.setTextColor(ST77XX_WHITE);
tft.setFont(Arial_28);
printTextSizes("Arial");
tft.print("Arial");
tft.setFont(Arial_20);
printTextSizes("0123456789");
tft.println("0123456789");
tft.setFont(&FreeMonoBoldOblique12pt7b);
printTextSizes("AdaFruit");
tft.println("AdaFruit");
tft.setFont(&FreeSerif12pt7b);
printTextSizes("FreeSan12");
tft.println("FreeSan12");
tft.setCursor(30, 120);
// tft.drawRect(30, 120, 60, 20, ST7735_GREEN);
int16_t x, y;
uint16_t w, h;
tft.getTextBounds("FreeSans", tft.getCursorX(), tft.getCursorY(), &x, &y, &w, &h);
tft.drawRect(x, y, w, h, ST7735_GREEN);
tft.print("FreeSans");
tft.setFont();
tft.setCursor(30, 150);
// tft.drawRect(30, 150, 60, 20, ST7735_GREEN);
tft.getTextBounds("System", tft.getCursorX(), tft.getCursorY(), &x, &y, &w, &h);
tft.print("System");
tft.setCursor(30, 180);
// tft.drawRect(30, 180, 60, 20, ST7735_GREEN);
Serial.println("After last print"); Serial.flush();
[COLOR="#FF0000"]tft.updateScreen()[/COLOR];
Serial.println("Exit drawTextScreen"); Serial.flush();
ptft->setRotation(rotation);
Serial.printf("Set Rotation: %d width: %d height: %d\n", rotation, ptft->width(), ptft->height());
rotation = (rotation + 1) & 0x3;
elapsedMillis timer;
drawTestScreen(ST7735_RED);
[COLOR="#FF0000"]ptft->updateScreen();[/COLOR]
// large block of text
//delay(2500);
Serial.println("Hit any key to continue");
uint8_t loffset = 0;
for (;;) {
while (!Serial.available()) ;
char ch = Serial.read();
while (Serial.read() != -1) ;
if (ch == '.') {
ptft->drawRect(loffset, loffset, ptft->width() - 2 * loffset, ptft->height() - 2 * loffset, ST7735_GREEN);
loffset++;
} else if (ch == 'a') {
drawTestScreen(ST7735_YELLOW);
elapsedMillis ema = 0;
[COLOR="#FF0000"] ptft->updateScreenAsync();[/COLOR]
Serial.println("After Async Update");
[COLOR="#FF0000"]while (ptft->asyncUpdateActive()) ;[/COLOR]
Serial.print("Async completed ");
Serial.println((int)ema, DEC);
} else if (ch == 'c') {
testContinuousUpdate();
} else if (ch == 'o') {
drawTextScreen(1);
} else if (ch == 't') {
drawTextScreen(0);
} else if (ch == 'f') {
// Toggle frame buffer or not frame buffer...
if (use_fb) {
use_fb = 0;
tft.useFrameBuffer(false);
Serial.println("*** Turned off frame buffer ***");
use_fb = 0;
tft.useFrameBuffer(true);
Serial.println("*** Turned on frame buffer ***");
void testContinuousUpdate() {
elapsedMillis emu = 0;
Serial.println("Start Continuous update test");
ptft->fillScreen(ST7735_RED);
ptft->updateScreenAsync(true);
Serial.println("After updateScreenAsync");
while(ptft->frameCount() < 10) {
if (emu > 500) {
emu = 0;
Serial.printf("Frame count: %d\n", ptft->frameCount());
ptft->fillScreen(ST7735_GREEN);
while(ptft->frameCount() < 20) ;
ptft->fillScreen(ST7735_BLUE);
while(ptft->frameCount() < 30) ;
ptft->drawRect(0,0, ptft->width(), ptft->height(), ST7735_BLUE);
ptft->setCursor(10, ptft->height() / 2 - 4);
while(ptft->frameCount() < 35) ;
Serial.println("Finished all frames");
ptft->endUpdateAsync();
Serial.println("After call to endUpdateAsync");
while (ptft->asyncUpdateActive());
Serial.println("Test completed");
