Page 2 of 2 FirstFirst 1 2
Results 26 to 31 of 31
Thread: Eagle library with Teensy 4.0 (test)
  1. #26
    Quote Originally Posted by eagleman View Post
    Eagle library is uploaded to github:
    https://github.com/eagleman1022/Eagle-Library-Teensy
    Hi eagleman,
    thank you for doing and sharing this....
    But is it possible that in the library you uploaded the T4.1 is missing?
    Again thank you
    Torsten
  2. #27
    Mar 2016
    242
    Hi, I have a library that is in my git repository here. Look for teensy4.1.dist.zip. I use this on several boards including one with Ethernet pictured below.
  3. #28
    Feb 2020
    South Africa
    41
    Thank you very much - I like the separate USB Host block and it follows the footprint pins layout
  4. #29
    Feb 2020
    South Africa
    41
    What I meanClick image for larger version.
ID:	20965 is this - compare yours on the left with the previous on the right:
  5. #30
    Oct 2020
    Melbourne, Australia
    1
    Thanks for the library eagleman! It's working great for me in Fusion 360.
    I have a question about the pogo pins you have used - do you have more comprehensive measurements? I'm trying to find an equivalent part on Digikey but I'm not sure of the correct tip diameter.
  6. #31
    Feb 2020
    8
    How are folks picking up the pads on the bottom of the T4 without hand wiring? I was looking at this: http://skpang.co.uk/catalog/teensy-4...40-p-1575.html and noticed he's grabbing 2 pins off the bottom of the T4 for the 3rd CAN port. I'd like to do that, but wasn't sure quite how.
