Page 2 of 2 FirstFirst 1 2
Results 26 to 43 of 43
Thread: Teensyduino 1.52 Beta #2
  1. #26
    Senior Member jim lee's Avatar
    Dec 2016
    Anacortes, WA
    162
    Thanks for answering guys.
    I've a Mac 10.13.6 I did the Catalina install. As for as I could tell it just put a new IDE on my drive called Teensyduino. I'm kinda' asssuming this is all I need and can toss out my old IDE? I ask because this is so different than what I"m used to where the installer just updates your original IDE.
    -jim lee
  2. #27
    12,381
    Quote Originally Posted by jim lee View Post
    -jim lee
    AFAIK that is correct. Not a mac user - but the notes IIRC said to work with the new secure install stuff tied the TD into IDE all in one to get what is needed.
  3. #28
    Dec 2016
    Anacortes, WA
    162
    Cool thanks! Back in the saddle!
    -jim lee
  4. #29
    Dec 2016
    Anacortes, WA
    162
    Back out of the saddle..
    #include <Adafruit_GFX.h>
    #include <ILI9341_t3.h>
    #include <ILI9341_t3.h> <- No such file.
    I just looked into the package contents (Mac thing) and found this file under hardware/teensy/libraries. Somehow this IDE can't find it.
    Hints?
    -jim lee
  5. #30
    12,381
    No idea how the IDE tracks file locations on MAC - even on Windows ( to avoid the IDE using 'known' system settings of its choosing ) I started doing unzip installs for multiple 'local reference' IDE copies where it runs 'all relative' based on the folder it was started from - but uses a common 'sketchbook' folder where all my stuff and 'personal libraries' are stored.
    If TD+IDE was installed uniquely after an IDE install - and the IDE install was removed the linkage to the any 'IDE' may have been cut?
    Not sure if that is in the right direction of the issue? Perhaps uninstall ALL IDE and TD+IDE copies - then just do a TD+IDE install?
  6. #31
    Dec 2016
    Anacortes, WA
    162
    AH! Got it. Teensyduino has the teensy stuff in it. Then new IDE from Arduino does not. I'd forgot to check to make sure I was compiling for a teensy. So I guess it wasn't looking for teensy library files.
    There is still the issue where ILI9341_t3.h conflicts with Adafruit_GFX.h though.
    -jim lee
  7. #32
    12,381
    Looks like an adafruit_gfx is included with Teensyduino? Need to see the build console output to know if it is using a local version?
  8. #33
    Dec 2016
    Anacortes, WA
    162
    Well, here it is. Looks like teensyduino has a private copy of Adafruit_GFX.h
    Multiple libraries were found for "Adafruit_GFX.h"/var/folders/wt/mcbdk5yn5wz6z1zcpf20xvzw0000gn/T/arduino_build_619311/libraries/ILI9341_t3/ILI9341_t3.cpp.o: In function `Adafruit_GFX_Button::drawButton(bool)':
     Used: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/Adafruit_GFX
     Not used: /Users/jimlee/Documents/Arduino/libraries/Adafruit_GFX_Library
    /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3/ILI9341_t3.cpp:1851: multiple definition of `Adafruit_GFX_Button::drawButton(bool)'
    /var/folders/wt/mcbdk5yn5wz6z1zcpf20xvzw0000gn/T/arduino_build_619311/libraries/Adafruit_GFX/Adafruit_GFX.cpp.o:/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/Adafruit_GFX/Adafruit_GFX.cpp:1587: first defined here
    /Applications/Teensyduino.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Disabling relaxation: it will not work with multiple definitions
    /var/folders/wt/mcbdk5yn5wz6z1zcpf20xvzw0000gn/T/arduino_build_619311/libraries/ILI9341_t3/ILI9341_t3.cpp.o: In function `Print::flush()':
    /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/ILI9341_t3/ILI9341_t3.cpp:1377: multiple definition of `Adafruit_GFX_Button::contains(short, short)'
    /var/folders/wt/mcbdk5yn5wz6z1zcpf20xvzw0000gn/T/arduino_build_619311/libraries/Adafruit_GFX/Adafruit_GFX.cpp.o:/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/Print.h:61: first defined here
    collect2: error: ld returned 1 exit status
    Error compiling for board Teensy 3.2 / 3.1.
    What I read in the ILI9341_t3.h file
    // To avoid conflict when also using Adafruit_GFX or any Adafruit library
    // which depends on Adafruit_GFX, #include the Adafruit library *BEFORE*
    // you #include ILI9341_t3.h.
    Doesn't seem to be working for some odd reason.
    P.S. I know I'm guilty of cross posting this. But I can't delete my other post. Sorry about that.
    -jim lee
  9. #34
    Dec 2016
    Anacortes, WA
    162
    Ok, I pulled ILI9341_t3 stuff out for now. Went back to the original one from Adafruit. Got everything to compile again. But now there's no teensy loader? Is this not included with this new teensyduino IDE?
    Opening Teensy Loader...
    Unable find Teensy Loader.  (p)  Is the Teensy Loader application running?
    -jim lee
  10. #35
    12,381
    Yes, there should be a TeensyLoader installed - if not then something isn't installed right.
    On this Windows machine the first run to load TeensyLoader takes like 15 seconds for some reason. Though not if started soon after booting - but when run some time later there is a long delay for startup.
    Again - never did the Mac thing - but IDE and TeensyLoader should all be there with all Teensy files and updated boards.txt allowing Teensy selection. and upload.
  11. #36
    Dec 2016
    Anacortes, WA
    162
    Well, your guesses are at least putting me on the right paths. Thank you! The loader didn't come with the installer. So, I thought it was no longer needed with this new fancy stuff. I went back and found the teensy loader app, d-loaded & installed it, clicked it and presto! I'm up and running.
    Thanks again!
    -jim lee
  12. #37
    12,381
    Glad you are up and running! Assumed the FAT catalina installer was all in one solution that would result in IDE 1.8.12 and TD ready to run?
  13. #38
    Jan 2020
    Toscana
    130
    Even though the upload error on the Teensy Loader did not show up again, perfectly following Murphy's Law, I could not get the sound to work. So I followed the idea of a malfunction in hardware and baked the Teensy over night at 50℃, dip fluxed and reflowed newly, then cleaned. Luckily enough, none of the tiny dust on the underside fell off. Et voilą, everything works as it should be, except for the button, which clogged and charred, but use external anyway. Nice and clean audio, stable signals. So nice!
    Thanks @Frank B for i2s library.
    You could add AKM AK4556VT to the list of compatible chips. It works very well, easy to set up, makes nice quality audio, stereo input and output, and is cheap, 1.38$
  14. #39
    Dec 2016
    Anacortes, WA
    162
    After a day of hacking on my teensy stuff I quit the teensyduino and it took the entire mac down. Power off, everything.
    I don't know if it'll help, but here's the stuff apple wanted as a report.
    Anonymous UUID:       5171288A-F5CB-2F3F-51AF-8F0E584824DE
    Sun Apr 12 22:25:38 2020
    *** Panic Report ***
    panic(cpu 0 caller 0xffffff800198776f): Kernel trap at 0xffffff8001d4fb33, type 14=page fault, registers:
    CR0: 0x000000008001003b, CR2: 0x0000000000000018, CR3: 0x0000000149caa0e1, CR4: 0x00000000003627e0
    RAX: 0x0000000000000000, RBX: 0xffffff80521ce950, RCX: 0x0000000000000000, RDX: 0xffffff80424b2e00
    RSP: 0xffffff9219d4bc40, RBP: 0xffffff9219d4bc60, RSI: 0xffffff8038ad4290, RDI: 0xffffff80424b2e00
    R8:  0x0000000000000000, R9:  0x000000000000270d, R10: 0x0000000000000000, R11: 0x00071519bf8f52ef
    R12: 0xffffff8039ee0cc0, R13: 0x0000000000000009, R14: 0xffffff80424b2e00, R15: 0xffffff80424b2ee0
    RFL: 0x0000000000010203, RIP: 0xffffff8001d4fb33, CS:  0x0000000000000008, SS:  0x0000000000000010
    Fault CR2: 0x0000000000000018, Error code: 0x0000000000000000, Fault CPU: 0x0, PL: 0, VF: 0
    Backtrace (CPU 0), Frame : Return Address
    0xffffff9219d4b710 : 0xffffff800186c1c6
    0xffffff9219d4b760 : 0xffffff8001995274
    0xffffff9219d4b7a0 : 0xffffff8001987544
    0xffffff9219d4b810 : 0xffffff800181e1e0
    0xffffff9219d4b830 : 0xffffff800186bc3c
    0xffffff9219d4b960 : 0xffffff800186b9fc
    0xffffff9219d4b9c0 : 0xffffff800198776f
    0xffffff9219d4bb30 : 0xffffff800181e1e0
    0xffffff9219d4bb50 : 0xffffff8001d4fb33
    0xffffff9219d4bc60 : 0xffffff8001cfd50d
    0xffffff9219d4bcb0 : 0xffffff8001cfcf8c
    0xffffff9219d4bd20 : 0xffffff8001cfa20f
    0xffffff9219d4bd60 : 0xffffff8001d167c9
    0xffffff9219d4be20 : 0xffffff800189f09f
    0xffffff9219d4beb0 : 0xffffff80018a3105
    0xffffff9219d4bee0 : 0xffffff80018645f6
    0xffffff9219d4bf30 : 0xffffff800181e1ac
    BSD process name corresponding to current thread: teensy_serialmon
    Mac OS version:
    17G65
    Kernel version:
    Darwin Kernel Version 17.7.0: Thu Jun 21 22:53:14 PDT 2018; root:xnu-4570.71.2~1/RELEASE_X86_64
    Kernel UUID: 1AE5ACFD-3B6F-3D74-AD52-31F1430DBC6F
    Kernel slide:     0x0000000001600000
    Kernel text base: 0xffffff8001800000
    __HIB  text base: 0xffffff8001700000
    System model name: iMac18,2 (Mac-77F17D7DA9285301)
    System uptime in nanoseconds: 1993524228744486
    last loaded kext at 1993427686880212: com.apple.driver.usb.cdc.ecm	5.0.0 (addr 0xffffff7f85e92000, size 49152)
    last unloaded kext at 1993487943390344: com.apple.driver.usb.cdc.ecm	5.0.0 (addr 0xffffff7f85e92000, size 49152)
    loaded kexts:
    com.apple.driver.AppleTopCaseHIDEventDriver	133
    com.apple.driver.AudioAUUC	1.70
    com.apple.driver.AGPM	110.23.37
    com.apple.driver.ApplePlatformEnabler	2.7.0d0
    com.apple.driver.X86PlatformShim	1.0.0
    com.apple.filesystems.autofs	3.0
    com.apple.driver.AppleUpstreamUserClient	3.6.5
    com.apple.kext.AMDFramebuffer	1.6.8
    com.apple.kext.AMDRadeonX4000	1.6.8
    com.apple.driver.AppleHDA	281.52
    com.apple.driver.AppleGraphicsDevicePolicy	3.20.13
    com.apple.AGDCPluginDisplayMetrics	3.20.13
    com.apple.driver.pmtelemetry	1
    com.apple.iokit.IOUserEthernet	1.0.1
    com.apple.iokit.IOBluetoothSerialManager	6.0.7f10
    com.apple.Dont_Steal_Mac_OS_X	7.0.0
    com.apple.driver.AppleHV	1
    com.apple.driver.AppleIntelSlowAdaptiveClocking	4.0.0
    com.apple.driver.AppleIntelKBLGraphics	10.3.6
    com.apple.iokit.BroadcomBluetooth20703USBTransport	6.0.7f10
    com.apple.driver.AppleIntelPCHPMC	2.0.1
    com.apple.kext.AMD9500Controller	1.6.8
    com.apple.driver.AppleThunderboltIP	3.1.1
    com.apple.driver.AppleOSXWatchdog	1
    com.apple.driver.eficheck	1
    com.apple.driver.AppleGFXHDA	100.1.17
    com.apple.driver.AppleSMCLMU	211
    com.apple.driver.AppleMCCSControl	1.5.5
    com.apple.driver.AppleIntelKBLGraphicsFramebuffer	10.3.6
    com.apple.AppleFSCompression.AppleFSCompressionTypeDataless	1.0.0d1
    com.apple.AppleFSCompression.AppleFSCompressionTypeZlib	1.0.0
    com.apple.AppleSystemPolicy	1.0
    com.apple.BootCache	40
    com.apple.filesystems.hfs.kext	407.50.6
    com.apple.driver.AppleSDXC	1.7.6
    com.apple.iokit.AppleBCM5701Ethernet	10.3.1
    com.apple.driver.AirPort.BrcmNIC	1241.31.1a9
    com.apple.driver.AppleAHCIPort	329.50.2
    com.apple.driver.AppleACPIButtons	6.1
    com.apple.driver.AppleRTC	2.0
    com.apple.driver.AppleSMBIOS	2.1
    com.apple.driver.AppleACPIEC	6.1
    com.apple.driver.AppleAPIC	1.7
    com.apple.nke.applicationfirewall	183
    com.apple.security.quarantine	3
    com.apple.security.TMSafetyNet	8
    com.apple.driver.usb.cdc.acm	5.0.0
    com.apple.driver.usb.cdc	5.0.0
    com.apple.driver.usb.IOUSBHostHIDDevice	1.2
    com.apple.driver.AppleUSBHostMergeProperties	1.2
    com.apple.driver.AppleHIDKeyboard	205
    com.apple.driver.AppleMultitouchDriver	1404.4
    com.apple.driver.AppleInputDeviceSupport	1404.3
    com.apple.driver.AppleHSBluetoothDriver	133
    com.apple.driver.IOBluetoothHIDDriver	6.0.7f10
    com.apple.kext.triggers	1.0
    com.apple.kext.AMDRadeonX4200HWLibs	1.0
    com.apple.driver.DspFuncLib	281.52
    com.apple.kext.OSvKernDSPLib	526
    com.apple.kext.AMDRadeonX4000HWServices	1.6.8
    com.apple.driver.AppleGraphicsControl	3.20.13
    com.apple.iokit.IOSerialFamily	11
    com.apple.iokit.IOAVBFamily	680.2
    com.apple.plugin.IOgPTPPlugin	680.15
    com.apple.driver.AppleSSE	1.0
    com.apple.AppleGPUWrangler	3.20.13
    com.apple.iokit.IOSlowAdaptiveClockingFamily	1.0.0
    com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport	6.0.7f10
    com.apple.iokit.IOBluetoothHostControllerUSBTransport	6.0.7f10
    com.apple.iokit.IOBluetoothHostControllerTransport	6.0.7f10
    com.apple.iokit.IOBluetoothFamily	6.0.7f10
    com.apple.kext.AMDSupport	1.6.8
    com.apple.driver.AppleHDAController	281.52
    com.apple.iokit.IOHDAFamily	281.52
    com.apple.driver.AppleSMBusPCI	1.0.14d1
    com.apple.iokit.IOAudioFamily	206.5
    com.apple.vecLib.kext	1.2.0
    com.apple.iokit.IONDRVSupport	519.20
    com.apple.driver.X86PlatformPlugin	1.0.0
    com.apple.driver.IOPlatformPluginFamily	6.0.0d8
    com.apple.driver.AppleSMBusController	1.0.18d1
    com.apple.AppleGraphicsDeviceControl	3.20.13
    com.apple.iokit.IOAcceleratorFamily2	378.26
    com.apple.iokit.IOGraphicsFamily	519.20
    com.apple.iokit.IOSurface	211.15
    com.apple.driver.usb.networking	5.0.0
    com.apple.driver.usb.AppleUSBHostCompositeDevice	1.2
    com.apple.driver.CoreStorage	546.50.1
    com.apple.filesystems.hfs.encodings.kext	1
    com.apple.iokit.IOAHCIBlockStorage	301.40.2
    com.apple.driver.AppleThunderboltDPInAdapter	5.5.5
    com.apple.driver.AppleThunderboltDPAdapterFamily	5.5.5
    com.apple.driver.AppleThunderboltPCIDownAdapter	2.1.3
    com.apple.driver.AppleHPM	3.1.3
    com.apple.driver.AppleIntelLpssI2CController	3.0.60
    com.apple.driver.AppleIntelLpssDmac	3.0.60
    com.apple.driver.AppleIntelLpssI2C	3.0.60
    com.apple.driver.AppleThunderboltNHI	4.7.2
    com.apple.iokit.IOThunderboltFamily	6.7.8
    com.apple.iokit.IOEthernetAVBController	1.1.0
    com.apple.iokit.IO80211Family	1200.12.2
    com.apple.driver.mDNSOffloadUserClient	1.0.1b8
    com.apple.driver.corecapture	1.0.4
    com.apple.iokit.IOAHCIFamily	288
    com.apple.driver.usb.AppleUSBHostPacketFilter	1.0
    com.apple.iokit.IOUSBFamily	900.4.1
    com.apple.driver.usb.AppleUSBXHCIPCI	1.2
    com.apple.driver.usb.AppleUSBXHCI	1.2
    com.apple.driver.AppleEFINVRAM	2.1
    com.apple.driver.AppleEFIRuntime	2.1
    com.apple.iokit.IOSMBusFamily	1.1
    com.apple.iokit.IOHIDFamily	2.0.0
    com.apple.security.sandbox	300.0
    com.apple.kext.AppleMatch	1.0.0d1
    com.apple.driver.AppleFDEKeyStore	28.30
    com.apple.driver.AppleEffaceableStorage	1.0
    com.apple.driver.AppleKeyStore	2
    com.apple.driver.AppleUSBTDM	439.70.3
    com.apple.driver.AppleMobileFileIntegrity	1.0.5
    com.apple.iokit.IOUSBMassStorageDriver	140.70.2
    com.apple.iokit.IOSCSIBlockCommandsDevice	404.30.2
    com.apple.iokit.IOSCSIArchitectureModelFamily	404.30.2
    com.apple.driver.AppleCredentialManager	1.0
    com.apple.driver.KernelRelayHost	1
    com.apple.iokit.IOUSBHostFamily	1.2
    com.apple.driver.usb.AppleUSBCommon	1.0
    com.apple.driver.AppleBusPowerController	1.0
    com.apple.driver.AppleSEPManager	1.0.1
    com.apple.driver.IOSlaveProcessor	1
    com.apple.driver.DiskImages	480.60.1
    com.apple.iokit.IOStorageFamily	2.1
    com.apple.iokit.IOReportFamily	31
    com.apple.iokit.IOTimeSyncFamily	680.15
    com.apple.iokit.IONetworkingFamily	3.4
    com.apple.driver.AppleACPIPlatform	6.1
    com.apple.driver.AppleSMC	3.1.9
    com.apple.iokit.IOPCIFamily	2.9
    com.apple.iokit.IOACPIFamily	1.4
    com.apple.kec.Libm	1
    com.apple.kec.pthread	1
    com.apple.kec.corecrypto	1.0
    EOF
    Model: iMac18,2, BootROM IM183.0161.B00, 4 processors, Intel Core i5, 3 GHz, 16 GB, SMC 2.40f0
    Graphics: Radeon Pro 555, Radeon Pro 555, PCIe
    Memory Module: BANK 0/DIMM0, 8 GB, DDR4, 2400 MHz, 0x802C, 0x3841544631473634485A2D324733453220202020
    Memory Module: BANK 1/DIMM0, 8 GB, DDR4, 2400 MHz, 0x802C, 0x3841544631473634485A2D324733453220202020
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x16E), Broadcom BCM43xx 1.0 (7.77.37.31.1a9)
    Bluetooth: Version 6.0.7f10, 3 services, 27 devices, 1 incoming serial ports
    Network Service: Wi-Fi, AirPort, en1
    Serial ATA Device: APPLE HDD HTS541010A9E632, 1 TB
    USB Device: USB 3.0 Bus
    USB Device: Bluetooth USB Host Controller
    USB Device: FaceTime HD Camera (Built-in)
    Thunderbolt Bus: iMac, Apple Inc., 33.1
    -jim lee
  15. #40
    Dec 2015
    LA
    183
    -jim lee
    -jim,
    Can't comment on the crash other than to say I have found it to be as good or better than previous versions, although I too experienced a crash like yours back when I first switched many months ago, but none since.
    The MacOS Catalina versions are named a little weird if your used to the pre-catalina. https://forum.pjrc.com/threads/59054...l=1#post227003. Should add that there is no Teensy Installer req'd and everything you might have picked to include with it is already installed. The little Teensyduino helper app that comes up when you have a Teensy board selected and compile is now called Teensy.
    I could be wrong but I think the name changes were required in order to not conflict with the unaltered Arduino application that must be code signed by them eventually if they haven't done so already. Perhaps the crash we both experienced was something security related with apple since like you my mac had been up many weeks before the installation.
  16. #41
    217
    Regarding the failure to upload to T4, I just wanted to share the following.
    It is not a bug report and I'm not expecting anyone to do anything about it. It should be treated as anecdotal only.
    I have been building a device around the T4 for a while. The T4 has its VIN trace cut, and this seemed to really contribute to the problems. The development system is a Dell XPS 15 with win 10. Strangely, I have found that all the problems go away if I put a plain old unpowered USB hub between the T4 and the computer. The problems with upload, and the USB hub solution, have held over several different T4s and hardware builds. There are too many unknowns, so it the culprit could be windows, it could be the laptop, the external power circuitry. I do not know yet.
    As I said... *anecdotal only*... not a bug report. Just thought I would share my experience.
  17. #42
    Jan 2020
    Toscana
    130
    just my two cents:
    Oh, that could be the ground loop problem, Frank B mentioned some posts upward, depending on the type of power supply, peripherals, etc. The hub "recreates" the USB signals and might contribute in ironing out any issues with levels and timings.
    I've found thant both my Vaio and the HP produce some sort of "static hum" on the metal parts of the shells when connected to AC via their original power brick. They have the grounded italian and german 3-prong connector to the grid. The wall socket has clean and good ground, so I suspect it is some issue within the power bricks, maybe some filtering. The 2001 Toshiba has a eurio 2-pole and does not produce any kind of this hum. Also, the travel power supply for the HP has only two poles and does not introduce hum.
  18. #43
    Apr 2020
    1
    Yes, that seems correct. This confused me also.
    On macOS 10.15.x Teensyduino.app seems to now be a full replacement for the Arduino.app (likely because of security issues - modifying other applications is not allowed).
    The PJRC.com web pages about installation and first steps are very confusing for macOS 10.15 users as a result of this change.
    Teensyduino 1.5.1 is working fine on macOS X 10.15.4 for me FWIW (to a Teensy LC).
