Results 1 to 4 of 4
Thread: Changing the playback speed on Play Flash raw
    Junior Member lsrichard's Avatar
    Mar 2020
    Costa Mesa, CA
    7
    Hi I am working on a MIDI sample playback module that is starting to work well.
    My samples are way to large to be part of the sketch.
    I have a set of multiplexed serial flash chips holding all the samples.
    I am noticing the some of the samples banks are slightly out of tune.
    Is there a way to vary the playback speed on the playFlashRaw object or modify the library to do so ?
    7,608
    Quote Originally Posted by lsrichard View Post
    Not out of the box. You would have to write code to do that. The playFlashRaw object does not support it.
    Mar 2020
    Costa Mesa, CA
    7
    I thought it might be difficult
    I would think it would require modifying a library like serial flash or one of the audio libraries and would require a deep understanding of how playFlashRaw works and what it uses for timing.
    Is it tied to a division of the chips master clock or something else ?
    I know it is using something to determine this playback rate.
    7,608
    No, you only need to modify update() in play_sd_raw
    For example if you (easiest case) want double speed, just skip every 2.nd sample.
    If you want smaller steps.. well... use smaller steps.
    You might need a lowpass-filter afterwards.
