Hello Everybody,
First message on this forum. I really need help for this problem, I have been looking and trying everything possible to solve it.
I work with macOS Mojave 10.14.5 and Teensyduino application from pjrc.
I have a Teensy 3.5 board and a Transcend 16Go SDHC Class 10 Card formatted in ExFAT (also tried in FAT32).
I do not succeed to write and save txt data on the card from the SPI bus of the teensy.
I tried all the examples programs and some from the forum: SdInfo, wipe, Formatter, SdFormatter, ReadWrite.
Always the same error:SD errorCode: 0X20,0X0
I have been looking for this error message inside the code of the librairies but nothing showed up, maybe not the right place.
It also show on some programs the message Initialization failed, verify card
I also try the modified SdInfo from "drmatin 10-03-2016, 05:54 AM" at https://forum.pjrc.com/threads/37652-microSD-slot-on-teensy-3-6 and it showed this message in the monitor:
Thank you for your help,
Regards,
Tony
SdFat version: 10102
type any character to start
init time: 7 ms
Card type: SDHC
Manufacturer ID: 0X74
OEM ID: J`
Product: USDU1
Version: 2.0
Serial number: 0XE7A31943
Manufacturing date: 10/2012
cardSize: 15962.47 MB (MB = 1,000,000 bytes)
flashEraseSize: 128 blocks
eraseSingleBlock: true
OCR: 0XC0FF8000
SD Partition Table
part,boot,type,start,length
1,0X0,0XEE,1,31176703
2,0X0,0X0,0,0
3,0X0,0X0,0,0
4,0X0,0X0,0,0
error:
File System initialization failed.
Regards,
Tony
