Results 1 to 7 of 7
Thread: Drums with delay does not work.
    If I do this, then it works:
    #include <synth_simple_drum.h>
    AudioSynthSimpleDrum     drum2;          //xy=142,180
    AudioSynthSimpleDrum     drum3;          //xy=167,246
    AudioSynthSimpleDrum     drum1;          //xy=174,133
    AudioSynthSimpleDrum     drum4;          //xy=207,310
    AudioMixer4              mixer1;         //xy=480,201
    AudioOutputAnalog        dac1;           //xy=647,197
    AudioConnection          patchCord1(drum2, 0, mixer1, 1);
    AudioConnection          patchCord2(drum3, 0, mixer1, 2);
    AudioConnection          patchCord3(drum1, 0, mixer1, 0);
    AudioConnection          patchCord4(drum4, 0, mixer1, 3);
    AudioConnection          patchCord5(mixer1, dac1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=930,518
    static uint32_t next;
      // audio library init
      AudioMemory(15);
      next = millis() + 1000;
      AudioNoInterrupts();
      drum1.frequency(60);
      drum1.length(1500);
      drum1.secondMix(0.0);
      drum1.pitchMod(0.55);
      drum2.frequency(60);
      drum2.length(300);
      drum2.secondMix(0.0);
      drum2.pitchMod(1.0);
      drum3.frequency(550);
      drum3.length(400);
      drum3.secondMix(1.0);
      drum3.pitchMod(0.5);
      drum4.frequency(1200);
      drum4.length(150);
      drum4.secondMix(0.0);
      drum4.pitchMod(0.0);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.5);
      AudioInterrupts();
      static uint32_t num = 0;
      if(millis() == next)
        switch(num % 4)
          case 0:
            drum1.noteOn();
          case 1:
            drum2.noteOn();
          case 2:
            drum3.noteOn();
          case 3:
            drum4.noteOn();
        num++;
      int knobFreq = analogRead(A11);   // tune
      int knobLength = analogRead(A9);  // fine tune
      drum1.frequency(knobFreq*2);
      drum2.frequency(knobFreq*2);
      drum3.frequency(knobFreq*2);
      drum4.frequency(knobFreq*2);
      drum1.length(knobLength*2);
      drum2.length(knobLength*2);
      drum3.length(knobLength*2);
      drum4.length(knobLength*2);
    If I take a drum away to have an input free in the mixer*** to add a delay, then it does not work anymore (with feedback or not, it does not).
    ***I tried with 2 mixers but did not work, as it does not work in one anyway, I am doing something else wrong. I can add again the different drums + mixers once I get it to work.
    THIS IS NOT WORKING WITH DELAY:
    AudioSynthSimpleDrum     drum1;          //xy=485.33331298828125,211.66668701171875
    AudioSynthSimpleDrum     drum2;          //xy=504,263
    AudioSynthSimpleDrum     drum3;          //xy=538,323
    AudioMixer4              mixer1;         //xy=791.3333129882812,279.66668701171875
    AudioEffectDelay         delay1;         //xy=946.6666666666665,444.99999999999994
    AudioOutputAnalog        dac1;           //xy=958.3333129882812,275.66668701171875
    AudioConnection          patchCord1(drum1, 0, mixer1, 0);
    AudioConnection          patchCord2(drum2, 0, mixer1, 1);
    AudioConnection          patchCord3(drum3, 0, mixer1, 2);
    AudioConnection          patchCord4(mixer1, delay1);
    AudioConnection          patchCord5(delay1, 0, dac1, 0);
    AudioConnection          patchCord6(delay1, 0, mixer1, 3);
      AudioMemory(15);
      mixer1.gain(0, 0.5);
      mixer1.gain(1, 0.5);
      mixer1.gain(2, 0.5);
      mixer1.gain(3, 0.7);
      delay1.delay(0, 400);
      drum1.length(1500);
      drum2.length(300);
      drum3.length(400);
      AudioInterrupts();
        switch(num % 3)
          case 0:
            drum1.noteOn();
          case 1:
            drum2.noteOn();
          case 2:
            drum3.noteOn();
        num++;
    Do you know why?
    Member houtson's Avatar
    Aug 2015
    Scotland
    91
    Try increasing AudioMemory() delay uses lots of memory.
    From the GUI:
    Memory for the delayed signal is take from the memory pool allocated by AudioMemory(). Each block allows about 2.9 milliseconds of delay, so AudioMemory should be increased to allow for the longest delay tap.
    Each board has a maximum possible delay.
    Board Maximum
    Teensy 3.0 139.26 ms
    Teensy 3.1 449.39 ms
    Teensy 3.2 449.39 ms
    Teensy 3.5 1671.19 ms
    Teensy 3.6 2413.94 ms
    No matter what value I set (up to the max - up to 99%), I don't get any sound out. I guess I am doing something else wrong.
    Here even if I simplify with only 1 drum sound (which does not btw affect memory usage - as it's the delay which has more affect), it still does not work:
    AudioConnection          patchCord2(mixer1, delay1);
    AudioConnection          patchCord3(delay1, 0, dac1, 0);
    AudioConnection          patchCord4(delay1, 0, mixer1, 3);
      AudioMemory(150);
      drum1.length(1500);
      AudioInterrupts();
        drum1.noteOn();
    Aug 2015
    Scotland
    91
    @nubie I tried your code with a Teensy 3.6 with the Audioboard. I changed the dac for an i2s output and it works fine (sounds good!).
    I don't have the dac set up for audio out so can't test that, can you post a picture of what you've got connected and what sort of teensy you are using.
    Quote Originally Posted by houtson View Post
    I am using Teensy 3.2. It's inside a module I use to play samples or synth sounds depending which firmware I use.
    DAC out is connected to A14.
    It's only when a delay is added, that it does not work.
    If I try this simple example, there's no delay either.
    AudioSynthWaveformSine   sine1;          //xy=158,74
    AudioEffectEnvelope      envelope1;      //xy=232,156
    AudioEffectDelay         delay1;         //xy=393,238
    AudioMixer4              mixer1;         //xy=532,205
    AudioConnection          patchCord1(sine1, envelope1);
    AudioConnection          patchCord2(envelope1, delay1);
    AudioConnection          patchCord3(envelope1, 0, dac1, 0);
    AudioConnection          patchCord4(delay1, 0, mixer1, 0);
    AudioConnection          patchCord5(delay1, 1, mixer1, 1);
    AudioConnection          patchCord6(delay1, 2, mixer1, 2);
    AudioConnection          patchCord7(delay1, 3, mixer1, 3);
    AudioConnection          patchCord8(mixer1, 0, dac1, 1);
    AudioControlSGTL5000     sgtl5000_1;     //xy=195,272
      // allocate enough memory for the delay
      AudioMemory(120);
      // configure a sine wave for the chirp
      // the original is turned on/off by an envelope effect
      // and output directly on the left channel
      sine1.frequency(1000);
      sine1.amplitude(0.5);
      // create 3 delay taps, which connect through a
      // mixer to the right channel output
      delay1.delay(0, 110);
      delay1.delay(1, 220);
      delay1.delay(2, 330);
      envelope1.noteOn();
      delay(36);
      envelope1.noteOff();
      delay(4000);
    Is the delay also supposed to work with the analog output of the Teensy (DAC)?
    Aug 2015
    Scotland
    91
    I wired up a Teensy 3.2 with the DAC and the first two examples above work fine.
    The last one (#5) doesn't work because you've got two connections to the dac (which only has one port) so all you hear is the signal straight out the envelope.
    If I change it as below I hear the signal delayed 3 times (also you don't need the AudioControlSGTL5000 control object if not using the audio board) . Can you try that and see if it works
    AudioSynthWaveformSine   sine1;          //xy=484,324
    AudioEffectEnvelope      envelope1;      //xy=558,406
    AudioEffectDelay         delay1;         //xy=719,488
    AudioMixer4              mixer1;         //xy=860,455
    AudioOutputAnalog        dac1;           //xy=1120,454
    AudioConnection          patchCord3(delay1, 0, mixer1, 0);
    AudioConnection          patchCord4(delay1, 1, mixer1, 1);
    AudioConnection          patchCord5(delay1, 2, mixer1, 2);
    AudioConnection          patchCord6(delay1, 3, mixer1, 3);
    AudioConnection          patchCord7(mixer1, dac1);
    // Don't need this if not using Audio Board -- AudioControlSGTL5000     sgtl5000_1;     //xy=521,522
      AudioMemory(120);
    Thanks. The fact that there's a noteON in the loop simply confused me. Like not hearing a delay, but simply repeating noteOn.
    So I made some tweaks to understand it. Also added feeback.
    And it works.
    AudioSynthWaveformSine   sine1;          //xy=76.85716247558594,112.85713195800781
    AudioEffectEnvelope      envelope1;      //xy=220.85714721679688,114.85714721679688
    AudioEffectDelay         delay1;         //xy=368.4285888671875,341.2856750488281
    AudioMixer4              mixer1;         //xy=383.8571472167969,128.99996948242188
    AudioMixer4              mixer2;         //xy=609,280
    AudioOutputAnalog        dac1;           //xy=807.4286499023438,340.5714416503906
    AudioConnection          patchCord2(envelope1, 0, mixer1, 0);
    AudioConnection          patchCord3(delay1, 0, mixer1, 1);
    AudioConnection          patchCord4(delay1, 0, mixer2, 0);
    AudioConnection          patchCord5(mixer1, delay1);
    AudioConnection          patchCord6(mixer2, dac1);
      AudioMemory(120);
      mixer1.gain(1, 0.7);
      delay1.delay(0, 1000);
      envelope1.noteOn();
      delay(36);
      int knob = analogRead(A5);
      float feedback = (float)knob / 1050.0;
      mixer1.gain(1, feedback);
    Now that I know how to do by learning here from my previous posts (and your great help), I'll add next a pot to set delay time and have a gate signal or a switch shooting a sound.
