I have used the timer_adc example code to write the code given below. I want to sample the ADC with high frequency and output its value via pwm. The code works if I use 500kHz as trigger rate. I can see the ADCinterrupt routine working using the "debug-pin" pin5. The code does not work with 1MHz as frequency. I dont see any activity on pin5. If I eliminate the PWM code the ADCsampling seems to work also with 1MHz. What determines the max ADC trigger speed? Why is it influenced by PWM ?
int LEDpin = 5 ;
int PWMpin = 19 ;
#include <ADC.h>
#include <ADC_util.h>
const int readPin = A0; // ADC0
ADC *adc = new ADC(); // adc object;
pinMode(LEDpin, OUTPUT);
pinMode(readPin, INPUT);
while (!Serial && millis() < 5000) ; // wait up to 5 seconds for serial monitor.
Serial.println("begin setup");
boolean withPWM=true ;
if(withPWM){
analogWriteRes(10);
analogWriteFrequency(PWMpin,1000000);
analogWrite(PWMpin, 512);
///// ADC0 ////
adc->adc0->setAveraging(1); // set number of averages
adc->adc0->setResolution(10); // set bits of resolution
adc->adc0->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_HIGH_SPEED); // change the conversion speed
adc->adc0->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPEED); // change the sampling speed
doStart(500000) ;
Serial.println("End setup");
void doStart(int freq){
Serial.print("Start Timer with frequency ");
Serial.print(freq);
Serial.println(" Hz.");
adc->adc0->stopTimer();
adc->adc0->startSingleRead(readPin); // call this to setup everything before the Timer starts, differential is also possible
adc->adc0->enableInterrupts(adc0_isr);
adc->adc0->startTimer(freq); //frequency in Hz
volatile uint16_t adc_val ;
Serial.printf("ADCval=%8d\n",adc_val);
delay(1000) ;
void adc0_isr() {
CORE_PIN5_PORTSET = CORE_PIN5_BITMASK; // debug pin=high
adc_val = (int16_t)ADC1_R0;
analogWrite(PWMpin, adc_val);
CORE_PIN5_PORTCLEAR = CORE_PIN5_BITMASK; // debug pin=low
#if defined(__IMXRT1062__) // Teensy 4.0
asm("DSB");
