Results 1 to 4 of 4
Thread: Teensy 4.0 Inconsistent SDIO SD read times
    Oct 2015
    7
    I am working on a rather large Teensy 4.0 project (it's a portable music tracker / sequencer that will be open source) and hit a minor snag with reading across multiple files.
    Occasionally and seemingly randomly it takes about 8x longer to update a buffer from a file.
    I made a simple example sketch to highlight my issue:
    #include <SdFat.h>
    #define NUM_FILES 8
    #define BUFFER_SIZE 512
    SdFs sd;
    FsFile file[NUM_FILES];
    bool isOpen[NUM_FILES];
    uint8_t buffer[NUM_FILES][BUFFER_SIZE];
    uint32_t pos[NUM_FILES];
    static const char * filename = "test.wav";
        while(!Serial);
        if(sd.begin(SdioConfig(FIFO_SDIO))) {
            Serial.println("Card Init");
            Serial.println("Card Init Failed!");
            while(1) ;
        for(uint8_t i=0;i<NUM_FILES;i++) {
            pos[i] = 0;
            if(file[i] = sd.open(filename, O_READ)) {
                isOpen[i] = true;
                Serial.print("File Open: ");
                Serial.print(filename);
                Serial.print(" on index: ");
                Serial.println(i);
            if(!isOpen[i]) continue;
            uint32_t t = micros();
            file[i].seek(pos[i]);
            uint32_t len = file[i].read((uint8_t *) &buffer[i][0], BUFFER_SIZE);
            pos[i] = len;
            if(len == 0) {
                pos[i] = 0;
            t = micros() - t;
            if(t > 1000) {
                Serial.print("Index: ");
                Serial.print(i);
                Serial.print("\tTime: ");
                Serial.print(t);
                Serial.print("\tPosition: ");
                Serial.print(pos[i]);
                Serial.print("\tLength: ");
                Serial.print(len);
        delay(1);
    It outputs the buffer index, time it took in microseconds, data position, and length when the time took is over 1 millisecond.
    This hiccup takes around 3.2 milliseconds from the usual 300~400 microseconds.
    It occurs with both the stock SD library and SDFatBeta using FIFO_SDIO or DMA_SDIO using the latest Teensyduino. I have not tested older versions.
    Breaking up a read into smaller chunks consecutively seems to help mitigate the issue but it shows itself again if I try to get more than 512 bytes from a single file at a time.
    Usually I'd blame this on SD being SD but the fact that it's non-repeatable on the same file sections or even random reads (doing a seek each pass) has the exact same behavior.
    Disabling IRQ seems to help as well but I have no idea why so any insight into how I can do a deeper dive would be helpful.
    If you're interested in my project you can check out a video on YT I posted a week or so ago.
    https://www.youtube.com/watch?v=DCFJ-3QfqZA
    Thanks!
    I may have different issue but I am facing weird time in writing. Most of the time it looks around 100 microseconds but sometimes it goes above 6000 and sometimes 80000 which is almost a second.
    Try using SDFat-Beta. I am using that as it was looking like SDFat-beta is the latest ones that is going to get next updates.
    2,665
    Quote Originally Posted by HallMark View Post
    write times can vary significantly, as you describe, what not is clear is read times. For read operations, there should be no bad-block handling and wear levelling.
    Oct 2015
    7
    Okay I figured it out... I think.
    Some of the cards I have seem to give occasional lame read speeds regardless of how it's formatted and how many bytes are read when it's not perfectly sequential- Sandisk Pro Endurance.
    What sucks is when they are working, they are faster than any other card I have.
    Need to do more experimenting/digging.
