Results 1 to 4 of 4
Thread: Simple Piezo, wav and Teensy 4.0
    Apr 2020
    France
    19
    Hello. I'm starting with Teensy 4.O and Audio Shield, I have some basics with Arduino.
    To start I would like to play a short wav (drum for example) with a Piezo. Do you have an example please ?
    I found this code for Teensy 3.2 but it doesn't work for me. I did a midi test with the example in the Teensy USB_MIDI and Piezo_midi and everything works with Ableton live.
    With this code the wav (Snare) is played but if I press the Piezo a little hard I get a white noise and nothing works after that.
    If you have a little example you make me happy.
    https://github.com/RyoKosaka/HelloDr.../wavPlayer.ino
        EXAMPLE - Teensy Simple WAV Player with Teensy Audio Audio Shield
        Library : https://github.com/RyoKosaka/HelloDrum-arduino-Library
        Blog : https://open-e-drums.tumblr.com/
    /* NOTICE
        This code is unstable!
    #include <hellodrum.h>
    int PAD1[5] = {
        100, //sensitivity (1-100)
        10,  //threshold (1-100)
        30,  //scan time (1-)
        10,  //mask time (1-)
        38   //note (0-127)
    //name your pad
    HelloDrum pad1(7); //connect to A7(21) pin
    //Teensy Audio
    AudioPlaySdWav playSdWav1;
    AudioPlaySdWav playSdWav2;
    AudioPlaySdWav playSdWav3;
    AudioPlaySdWav playSdWav4;
    AudioPlaySdWav playSdWav5;
    AudioPlaySdWav playSdWav6;
    AudioPlaySdWav playSdWav7;
    AudioPlaySdWav playSdWav8;
    AudioPlaySdWav playSdWav9;
    AudioPlaySdWav playSdWav10;
    AudioPlaySdWav playSdWav11;
    AudioPlaySdWav playSdWav12;
    AudioPlaySdWav playSdWav13;
    AudioPlaySdWav playSdWav14;
    AudioPlaySdWav playSdWav15;
    AudioPlaySdWav playSdWav16;
    AudioMixer4 mixerLeft1;
    AudioMixer4 mixerLeft2;
    AudioMixer4 mixerLeft3;
    AudioMixer4 mixerLeft4;
    AudioMixer4 mixerRight1;
    AudioMixer4 mixerRight2;
    AudioMixer4 mixerRight3;
    AudioMixer4 mixerRight4;
    AudioMixer4 mixerLeftMaster;
    AudioMixer4 mixerRightMaster;
    AudioOutputI2S i2s1;
    AudioConnection patchCord1(playSdWav14, 0, mixerLeft4, 1);
    AudioConnection patchCord2(playSdWav14, 1, mixerRight4, 1);
    AudioConnection patchCord3(playSdWav10, 0, mixerLeft3, 1);
    AudioConnection patchCord4(playSdWav10, 1, mixerRight3, 1);
    AudioConnection patchCord5(playSdWav15, 0, mixerLeft4, 2);
    AudioConnection patchCord6(playSdWav15, 1, mixerRight4, 2);
    AudioConnection patchCord7(playSdWav11, 0, mixerLeft3, 2);
    AudioConnection patchCord8(playSdWav11, 1, mixerRight3, 2);
    AudioConnection patchCord9(playSdWav13, 0, mixerLeft4, 0);
    AudioConnection patchCord10(playSdWav13, 1, mixerRight4, 0);
    AudioConnection patchCord11(playSdWav9, 0, mixerLeft3, 0);
    AudioConnection patchCord12(playSdWav9, 1, mixerRight3, 0);
    AudioConnection patchCord13(playSdWav6, 0, mixerLeft2, 1);
    AudioConnection patchCord14(playSdWav6, 1, mixerRight2, 1);
    AudioConnection patchCord15(playSdWav2, 0, mixerLeft1, 1);
    AudioConnection patchCord16(playSdWav2, 1, mixerRight1, 1);
    AudioConnection patchCord17(playSdWav16, 0, mixerLeft4, 3);
    AudioConnection patchCord18(playSdWav16, 1, mixerRight4, 3);
    AudioConnection patchCord19(playSdWav12, 0, mixerLeft3, 3);
    AudioConnection patchCord20(playSdWav12, 1, mixerRight3, 3);
    AudioConnection patchCord21(playSdWav7, 0, mixerLeft2, 2);
    AudioConnection patchCord22(playSdWav7, 1, mixerRight2, 2);
    AudioConnection patchCord23(playSdWav3, 0, mixerLeft1, 2);
    AudioConnection patchCord24(playSdWav3, 1, mixerRight1, 2);
    AudioConnection patchCord25(playSdWav5, 0, mixerLeft2, 0);
    AudioConnection patchCord26(playSdWav5, 1, mixerRight2, 0);
    AudioConnection patchCord27(playSdWav1, 0, mixerLeft1, 0);
    AudioConnection patchCord28(playSdWav1, 1, mixerRight1, 0);
    AudioConnection patchCord29(playSdWav8, 0, mixerLeft2, 3);
    AudioConnection patchCord30(playSdWav8, 1, mixerRight2, 3);
    AudioConnection patchCord31(playSdWav4, 0, mixerLeft1, 3);
    AudioConnection patchCord32(playSdWav4, 1, mixerRight1, 3);
    AudioConnection patchCord33(mixerLeft4, 0, mixerLeftMaster, 3);
    AudioConnection patchCord34(mixerLeft2, 0, mixerLeftMaster, 1);
    AudioConnection patchCord35(mixerLeft1, 0, mixerLeftMaster, 0);
    AudioConnection patchCord36(mixerLeft3, 0, mixerLeftMaster, 2);
    AudioConnection patchCord37(mixerRight2, 0, mixerRightMaster, 1);
    AudioConnection patchCord38(mixerRight3, 0, mixerRightMaster, 2);
    AudioConnection patchCord39(mixerRight4, 0, mixerRightMaster, 3);
    AudioConnection patchCord40(mixerRight1, 0, mixerRightMaster, 0);
    AudioConnection patchCord41(mixerLeftMaster, 0, i2s1, 0);
    AudioConnection patchCord42(mixerRightMaster, 0, i2s1, 1);
    #define SDCARD_CS_PIN 10
    #define SDCARD_MOSI_PIN 7
    #define SDCARD_SCK_PIN 14
    //#define SDCARD_CS_PIN    BUILTIN_SDCARD
    //#define SDCARD_MOSI_PIN  11  // not actually used
    //#define SDCARD_SCK_PIN   13  // not actually used
    // Use these for the SD+Wiz820 or other adaptors
    //#define SDCARD_CS_PIN    4
        AudioMemory(20);
        // Comment these out if not using the audio adaptor board.
        // This may wait forever if the SDA & SCL pins lack
        // pullup resistors
        sgtl5000_1.enable();
        sgtl5000_1.volume(1.0);
        SPI.setMOSI(SDCARD_MOSI_PIN);
        SPI.setSCK(SDCARD_SCK_PIN);
        if (!(SD.begin(SDCARD_CS_PIN)))
            // stop here, but print a message repetitively
            while (1)
        //mixer gain
        mixerLeft1.gain(0,0.25);
        mixerLeft1.gain(1,0.25);
        mixerLeft1.gain(2,0.25);
        mixerLeft1.gain(3,0.25);
        mixerLeft2.gain(0,0.25);
        mixerLeft2.gain(1,0.25);
        mixerLeft2.gain(2,0.25);
        mixerLeft2.gain(3,0.25);
        mixerLeft3.gain(0,0.25);
        mixerLeft3.gain(1,0.25);
        mixerLeft3.gain(2,0.25);
        mixerLeft3.gain(3,0.25);
        mixerLeft4.gain(0,0.25);
        mixerLeft4.gain(1,0.25);
        mixerLeft4.gain(2,0.25);
        mixerLeft4.gain(3,0.25);
        mixerRight1.gain(0,0.25);
        mixerRight1.gain(1,0.25);
        mixerRight1.gain(2,0.25);
        mixerRight1.gain(3,0.25);
        mixerRight2.gain(0,0.25);
        mixerRight2.gain(1,0.25);
        mixerRight2.gain(2,0.25);
        mixerRight2.gain(3,0.25);
        mixerRight3.gain(0,0.25);
        mixerRight3.gain(1,0.25);
        mixerRight3.gain(2,0.25);
        mixerRight3.gain(3,0.25);
        mixerRight4.gain(0,0.25);
        mixerRight4.gain(1,0.25);
        mixerRight4.gain(2,0.25);
        mixerRight4.gain(3,0.25);
        mixerLeftMaster.gain(0,0.25);
        mixerLeftMaster.gain(1,0.25);
        mixerLeftMaster.gain(2,0.25);
        mixerLeftMaster.gain(3,0.25);
        mixerRightMaster.gain(0,0.25);
        mixerRightMaster.gain(1,0.25);
        mixerRightMaster.gain(2,0.25);
        mixerRightMaster.gain(3,0.25);
        if (playSdWav1.isPlaying() == false)
            playSdWav1.play(filename);
        else if (playSdWav2.isPlaying() == false)
            playSdWav2.play(filename);
        else if (playSdWav3.isPlaying() == false)
            playSdWav3.play(filename);
        else if (playSdWav4.isPlaying() == false)
            playSdWav4.play(filename);
        else if (playSdWav5.isPlaying() == false)
            playSdWav5.play(filename);
        else if (playSdWav6.isPlaying() == false)
            playSdWav6.play(filename);
        else if (playSdWav7.isPlaying() == false)
            playSdWav7.play(filename);
        else if (playSdWav8.isPlaying() == false)
            playSdWav8.play(filename);
        else if (playSdWav9.isPlaying() == false)
            playSdWav9.play(filename);
        else if (playSdWav10.isPlaying() == false)
            playSdWav10.play(filename);
        else if (playSdWav11.isPlaying() == false)
            playSdWav11.play(filename);
        else if (playSdWav12.isPlaying() == false)
            playSdWav12.play(filename);
        else if (playSdWav13.isPlaying() == false)
            playSdWav13.play(filename);
        else if (playSdWav14.isPlaying() == false)
            playSdWav14.play(filename);
        else if (playSdWav15.isPlaying() == false)
            playSdWav15.play(filename);
        else if (playSdWav16.isPlaying() == false)
            playSdWav16.play(filename);
        pad1.singlePiezo(PAD1[0], PAD1[1], PAD1[2], PAD1[3]);
        if (pad1.hit == true)
            if (pad1.velocity < 25)
                playFile("snare1.wav");
            if (pad1.velocity >= 25 && pad1.velocity < 50)
                playFile("snare2.wav");
            if (pad1.velocity >= 50 && pad1.velocity < 75)
                playFile("snare3.wav");
            if (pad1.velocity >= 75 && pad1.velocity < 100)
                playFile("snare4.wav");
            if (pad1.velocity >= 100)
                playFile("snare5.wav");
    Apr 2020
    France
    19
    For more details, I use a class 6 SD card with 16 GB. Is it fast enought ?
    I don't think the problem is with the SD card. I did a test with this code and the audio file plays without problem. https://github.com/PaulStoffregen/Au..._Playing_Music
    12,691
    Not sure how the piezo's are connected and what kind of signal they could be passing to the Teensy ...
    to make sure the code works and it isn't the piezo messing with the Teensy - replace with a normal button/switch perhaps … or use Serial Monitor to enter selective values to trigger as the inputs would?
    Apr 2020
    France
    19
    Well, I just did a test with another sd card. She's old and not very fast but it works to do a simple test. At least I now know where the problem is coming from.
    Thank you for your reply.
