hello all,
i have been working on a project including 7 rotary encoders and noticed after a lot of use that it sometimes had debouncing issues : the encoders are used to navigate menus and the display was sometimes jumpy.
so i am trying to isolate an encoder and work on its stability.
here i added some hardware debouncing and used a simple code to test how jumpy the numbers are :
here is the schematics of the hardware part :
R = 10kO
C = 0.01uF
ABC are of course the 3 legs of the rotary encoder
this is what i get when running the code and turning the rotary encoder, quite slowly i admit :
.. 237 238 239 240 241 242 243 244 245 244 245 246 247 248 249 250 251 252 ..
you can see there is still a bit of chatter ( i isolate this line from about 20 more lines, all working proper )
is this a very reasonable outcome or is there another way to improve the situation, hardware or software-wise ?
best,
Sylvain
R = 10kO
C = 0.01uF
#include <Arduino.h>
#include <Encoder.h>
int pinRotaryEncoder1A = 30;
int pinRotaryEncoder1B = 29;
Encoder rotKnob1(pinRotaryEncoder1A, pinRotaryEncoder1B);
int counterEndUser;
int oldCounterEndUser;
counterEndUser = rotKnob1.read();
// counterEndUser /= 4 ;
if (counterEndUser != oldCounterEndUser)
Serial.print(counterEndUser);
Serial.print(" ");
oldCounterEndUser = counterEndUser;
best,
Sylvain
