Results 1 to 10 of 10
Thread: T_40 USB Host not working
    Apr 2020
    5
    Hello friends,
    my project plan: To connect my USB mouse to Teensy 4.0 via USB Host, and let the Teensy forward all incoming mouse data to the computer, like a "passthrough". I soldered a USB A Female cable to the Teensy for USB Host support.
    I'm measuring ~4.78 V. The mouse lights up, but my Teensy is not getting any data.
    Here's my (very simple) testing code. I'm using USBHost_t36. Is anything wrong with it maybe?
    #include "USBHost_t36.h"
    USBHost usbHost;
    MouseController mouseController(usbHost);
      Serial.println("Init");
      usbHost.begin();
      usbHost.Task();
      if (mouseController.available())
        Serial.println("Juhu!");
        mouseController.mouseDataClear();
    Let me know if you have any ideas =)
    Felix
    26,572
    Most likely cause is a hardware issue. Maybe show us photos of how you connected the cable?
    Or it could be something on the software side. To get much more info, edit USBHost_t36.h to enable the verbose debug info. That will at least tell you whether the library is detecting and trying to enumerate your device.
    10,792
    Did you try with the mouse example sketch?
    My guess is you need to add at least one HID Controller objects like here is an updated version, I also threw in a HUB object in case you plug one in and some devices like a few keyboards have one internal. :
    USBHost usbHost;
    USBHIDParser hid1(usbHost);
    USBHIDParser hid2(usbHost);
    USBHub hub1(usbHost);
      usbHost.begin();
      usbHost.Task();
    16,244
    That code doesn't show anything here.
    Start from this :: ...\hardware\teensy\avr\libraries\USBHost_t36\exam ples\Serial\Mouse\Mouse.ino
    That will confirm the hardware to start.
    16,244
    Took me a bit to find a wired mouse … KurtE's updated example now works here as well.
    Apr 2020
    5
    Thanks for your replies. Unfortunately, neither the complete official example nor KurtE's program give me output. I have enabled verbose output in USBHost_t36.h. This is my output when I power up the Teensy with my USB mouse already connected to it:
    Init
    USB2 PLL running
     reset waited 6
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 20003000
    periodictable = 20003000
    port change: 14001403
        connect
      begin reset
    port change: 14001005
      port enabled
    And this is the output I get when disconnecting the USB mouse while Teensy is running:
    port change: 1C00100A
        disconnect
    disconnect_Device:
    USBDriver (available_drivers) list: 20001E00 -> 20002420 -> 20002A40
    USBDriver (dev->drivers) list: (empty
    delete_Pipe 20003400
      shut down async schedule
      Free transfers
        * 536884544 * remove * free
        * 536884352
        * 536884416 * remove * defer free until QH
      Free transfers attached to QH
        * 536884352
        * 536884416
        * 536884480
    * Delete Pipe completed
    removed Device_t from devlist
      disable
    And this is the output I get by connecting the USB mouse again, while the Teensy is already running:
        connect
      begin reset
      port enabled
      end recovery
    new_Device: 1.5 Mbit/sec
    new_Pipe
    I tried USB mice from two different vendors. I can post pics of my wiring later if needed. What do you guys think?
    16,244
    Tried here today on two different 1062 Teensy's with USB Host wiring - and others ( T4 and T_3.6 ) prior - the example code is tested to work. ANd KurtE tested to work - now and before.
    Problem would seem to be hardware connect usability of the D+/D- wiring. Unless the two mice are odd - the one found and used here is a Logitech.
    Apr 2020
    5
    I might have soldered D+ and D- in the wrong order, maybe I got a wrong pinout for my USB cable. I will switch them and update you. Thanks!
    Apr 2020
    5
    Switched D+ and D- cables and everything works as expected, using KurtE's code (but without the second USBHIDParser and USBHub).
    Thanks for the help and sorry for wasting your time.
    16,244
    Great news. Can you post a pic to complete the solution
