Hello everyone,
I have an interesting problem which i suspect is somewhat common, but I have not been able to find a solution to. I am working on some code for an IMU that used an ADIS16364 sensor wired to a Teensy 3.6 using SPI. I want to do my IMU calculations then log the results on the built-in SD card. If I just calculate the values and output them to the USB serial, everything works, but as soon as I add the SD code the entire thing breaks. The sensor SPI start reading erratically, the serial data is all NaN, and it actually gets hard to even reverse the "damage", as multiple uploads of the program without SD references did not fix the problem. After a few board restarts I was able to get the code working again without SD.
My hypothesis is that the SD library does some background reconfiguration to the SPI logic that interferes with all SPI channels and not just the dedicated SD one.
Code below:
Code below:
int16_t SPI_Data=0x0000;
double gyro[3]={0,0,0};
double acc[3]={0,0,0};
double acc_new[3]={0,0,0};
double R[3][3];
float alpha = 0.1;
const float g = 1;
float alpha_gain=0;
float acc_magn=0;
long sum[3]={0,0,0};
double Rot_Quaternion[4] = {1, 0, 0, 0};
double Rot_Quaternion_new[4] = {1, 0, 0, 0};
double Grav_Quaternion[4] = {1, 0, 0, 0};
double Adj_Quaternion[4] = {1, 0, 0, 0};
float pitch=0;
float yaw=0;
float roll=0;
float norm;
float norm2;
float deltaT;
elapsedMicros calculateNow;
elapsedMillis sendMessage;
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
SPI.begin();
SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE3));
digitalWrite(10, LOW);
delayMicroseconds(10);
SPI_Data = (SPI.transfer16(0x0400) << 2);
delay(1);
SD.begin(BUILTIN_SDCARD);
File logFile = SD.open("log.txt",FILE_WRITE);
logFile.println("pitch,roll,yaw");
logFile.close();
if (calculateNow > 10000 ) {
deltaT = calculateNow;
delayMicroseconds(50);
SPI_Data = (SPI.transfer16(0x0600) << 2);
SPI_Data = SPI_Data / 4 ;
gyro[0] = (float)SPI_Data * 0.05;
SPI_Data = (SPI.transfer16(0x0800) << 2);
gyro[1] = (float)SPI_Data * 0.05;
SPI_Data = (SPI.transfer16(0x0A00) << 2);
gyro[2] = (float)SPI_Data * 0.05;
SPI_Data = (SPI.transfer16(0x0C00) << 2);
SPI_Data = SPI_Data / 4;
acc[0] = (float)SPI_Data * 0.001;
SPI_Data = (SPI.transfer16(0x0E00) << 2);
acc[1] = (float)SPI_Data * 0.001;
acc[2] = -(float)SPI_Data * 0.001;
Rot_Quaternion[0] += (-Rot_Quaternion[1] * gyro[0] - Rot_Quaternion[2] * gyro[1] - Rot_Quaternion[3] * gyro[2]) / (deltaT);
Rot_Quaternion[1] += ( Rot_Quaternion[0] * gyro[0] + Rot_Quaternion[2] * gyro[2] - Rot_Quaternion[3] * gyro[1]) / (deltaT) ;
Rot_Quaternion[2] += ( Rot_Quaternion[0] * gyro[1] - Rot_Quaternion[1] * gyro[2] + Rot_Quaternion[3] * gyro[0]) / (deltaT);
Rot_Quaternion[3] += ( Rot_Quaternion[0] * gyro[2] + Rot_Quaternion[1] * gyro[1] - Rot_Quaternion[2] * gyro[0]) / (deltaT);
norm = sqrt(Rot_Quaternion[0] * Rot_Quaternion[0] + Rot_Quaternion[1] * Rot_Quaternion[1] + Rot_Quaternion[2] * Rot_Quaternion[2] + Rot_Quaternion[3] * Rot_Quaternion[3]);
Rot_Quaternion[0] /= norm;
Rot_Quaternion[1] /= norm;
Rot_Quaternion[2] /= norm;
Rot_Quaternion[3] /= norm;
if (Rot_Quaternion[0] < 0)
Rot_Quaternion[1] = -Rot_Quaternion[1];
Rot_Quaternion[2] = -Rot_Quaternion[2];
Rot_Quaternion[3] = -Rot_Quaternion[3];
R[0][0]=Rot_Quaternion[0]*Rot_Quaternion[0]+Rot_Quaternion[1]*Rot_Quaternion[1]-Rot_Quaternion[2]*Rot_Quaternion[2]-Rot_Quaternion[3]*Rot_Quaternion[3];
R[1][0]=2*(Rot_Quaternion[1]*Rot_Quaternion[2]+Rot_Quaternion[0]*Rot_Quaternion[3]);
R[2][0]=2*(Rot_Quaternion[1]*Rot_Quaternion[3]-Rot_Quaternion[0]*Rot_Quaternion[2]);
R[0][1]=2*(Rot_Quaternion[1]*Rot_Quaternion[2]-Rot_Quaternion[0]*Rot_Quaternion[3]);
R[1][1]=Rot_Quaternion[0]*Rot_Quaternion[0]-Rot_Quaternion[1]*Rot_Quaternion[1]+Rot_Quaternion[2]*Rot_Quaternion[2]-Rot_Quaternion[3]*Rot_Quaternion[3];
R[2][1]=2*(Rot_Quaternion[2]*Rot_Quaternion[3]+Rot_Quaternion[0]*Rot_Quaternion[1]);
R[0][2]=2*(Rot_Quaternion[1]*Rot_Quaternion[3]+Rot_Quaternion[0]*Rot_Quaternion[2]);
R[1][2]=2*(Rot_Quaternion[2]*Rot_Quaternion[3]-Rot_Quaternion[0]*Rot_Quaternion[1]);
R[2][2]=Rot_Quaternion[0]*Rot_Quaternion[0]-Rot_Quaternion[1]*Rot_Quaternion[1]-Rot_Quaternion[2]*Rot_Quaternion[2]+Rot_Quaternion[3]*Rot_Quaternion[3];
acc_new[0]=R[0][0]*acc[0]+R[1][0]*acc[1]+R[2][0]*acc[2];
acc_new[1]=R[0][1]*acc[0]+R[1][1]*acc[1]+R[2][1]*acc[2];
acc_new[2]=R[0][2]*acc[0]+R[1][2]*acc[1]+R[2][2]*acc[2];
acc[0]=acc_new[0];
acc[1]=acc_new[1];
acc[2]=acc_new[2];
acc_magn = sqrt(acc[0] * acc[0] + acc[1] * acc[1] + acc[2] * acc[2]);
acc[0] /= acc_magn;
acc[1] /= acc_magn;
acc[2] /= acc_magn;
if (acc[2]>=0){
Grav_Quaternion[0] = sqrt((acc[2] + 1) / 2);
Grav_Quaternion[1] = -acc[1] / sqrt(2 * (acc[2] + 1));
Grav_Quaternion[2] = acc[0] / sqrt(2 * (acc[2] + 1));
Grav_Quaternion[3] = 0;
else if (acc[2]<0){
Grav_Quaternion[0] = -acc[1]/sqrt(1-acc[2]);
Grav_Quaternion[1] = sqrt((1-acc[2])/2);
Grav_Quaternion[2] = 0;
Grav_Quaternion[3] = acc[0]/sqrt(2*(1-acc[2]));
alpha_gain = abs(acc_magn - g) / g;
if (alpha_gain <= 0.1) {
alpha_gain = 1;
else if (alpha_gain<0.2 and alpha_gain>0.1) {
alpha_gain = (0.1 - alpha_gain) * 10 + 1;
else {
alpha_gain = 0;
Adj_Quaternion[0] = (1 - alpha * alpha_gain) + (alpha * alpha_gain) * Grav_Quaternion[0];
Adj_Quaternion[1] = (alpha * alpha_gain) * Grav_Quaternion[1];
Adj_Quaternion[2] = (alpha * alpha_gain) * Grav_Quaternion[2];
Adj_Quaternion[3] = 0;
norm2 = sqrt(Adj_Quaternion[0] * Adj_Quaternion[0] + Adj_Quaternion[1] * Adj_Quaternion[1] + Adj_Quaternion[2] * Adj_Quaternion[2] + Adj_Quaternion[3] * Adj_Quaternion[3]);
Adj_Quaternion[0] /= norm2;
Adj_Quaternion[1] /= norm2;
Adj_Quaternion[2] /= norm2;
Adj_Quaternion[3] /= norm2;
Rot_Quaternion_new[0] = Rot_Quaternion[0] * Adj_Quaternion[0] - Rot_Quaternion[1] * Adj_Quaternion[1] - Rot_Quaternion[2] * Adj_Quaternion[2] - Rot_Quaternion[3] * Adj_Quaternion[3];
Rot_Quaternion_new[1] = Rot_Quaternion[0] * Adj_Quaternion[1] + Rot_Quaternion[1] * Adj_Quaternion[0] + Rot_Quaternion[2] * Adj_Quaternion[3] - Rot_Quaternion[3] * Adj_Quaternion[2];
Rot_Quaternion_new[2] = Rot_Quaternion[0] * Adj_Quaternion[2] - Rot_Quaternion[1] * Adj_Quaternion[3] + Rot_Quaternion[2] * Adj_Quaternion[0] + Rot_Quaternion[3] * Adj_Quaternion[1];
Rot_Quaternion_new[3] = Rot_Quaternion[0] * Adj_Quaternion[3] + Rot_Quaternion[1] * Adj_Quaternion[2] - Rot_Quaternion[2] * Adj_Quaternion[1] + Rot_Quaternion[3] * Adj_Quaternion[0];
Rot_Quaternion[0] = Rot_Quaternion_new[0];
Rot_Quaternion[1] = Rot_Quaternion_new[1];
Rot_Quaternion[2] = Rot_Quaternion_new[2];
Rot_Quaternion[3] = Rot_Quaternion_new[3];
calculateNow = 0;
if (sendMessage > 100 ) {
sendMessage = 0;
pitch = Rot_Quaternion[1];
roll = Rot_Quaternion[2];
yaw = Rot_Quaternion[3];
Serial.print(pitch);
Serial.print(",");
Serial.print(roll);
Serial.print(",");
Serial.println(yaw);
logFile.print(pitch);
logFile.print(",");
logFile.print(roll);
logFile.print(",");
logFile.println(yaw);
logFile.close();
