/* Audio Library for Teensy, Ladder Filter
* Copyright (c) 2021, Richard van Hoesel
* THE SOFTWARE.
// Based on Huovilainen New Moog (HNM) model as per CMJ jun 2006
// Implemented as Teensy37 Audio Library compatible object
// Richard van Hoesel, v. 1.04, Feb. 15 2021
// v1.4 FC extended to 18.7kHz, max res to 1.8, 4x oversampling,
// and a minor Q-tuning adjustment
// v.1.03 adds 2x oversampling, extended resonance,
// and exposes parameters input_drive and passband_gain
// v.1.02 now includes both cutoff and resonance "CV" modulation inputs
// please retain this header if you use this code.
// [URL]https://forum.pjrc.com/threads/60488?p=269755&viewfull=1#post269755[/URL]
// [URL]https://forum.pjrc.com/threads/60488?p=269609&viewfull=1#post269609[/URL]
#include <Arduino.h>
#include "filter_ladder.h"
#include <math.h>
#include <stdint.h>
#define MOOG_PI ((float)3.14159265358979323846264338327950288)
//#define osTimes 1
//#define MAX_RESONANCE ((float)1.1)
//#define MAX_FREQUENCY ((float)(AUDIO_SAMPLE_RATE_EXACT * 0.249f))
//#define osTimes 2
//#define MAX_RESONANCE ((float)1.2)
//#define MAX_FREQUENCY ((float)(AUDIO_SAMPLE_RATE_EXACT * 0.38f))
#define osTimes 4
#define MAX_RESONANCE ((float)1.8)
#define MAX_FREQUENCY ((float)(AUDIO_SAMPLE_RATE_EXACT * 0.425f))
//#define lfq 0.25
float AudioFilterLadder::LPF(float s, int i)
float ft = s * (1.0f/1.3f) + (0.3f/1.3f) * z0[i] - z1[i];
ft = ft * alpha + z1[i];
z1[i] = ft;
z0[i] = s;
return ft;
void AudioFilterLadder::resonance(float res)
// maps resonance = 0->1 to K = 0 -> 4
if (res > MAX_RESONANCE) {
res = MAX_RESONANCE;
} else if (res < 0.0f) {
res = 0.0f;
K = 4.0f * res;
void AudioFilterLadder::frequency(float c)
Fbase = c;
compute_coeffs(c);
void AudioFilterLadder:: octaveControl(float octaves)
if (octaves > 7.0f) {
octaves = 7.0f;
} else if (octaves < 0.0f) {
octaves = 0.0f;
octaveScale = octaves / 32768.0f;
void AudioFilterLadder:: passband_gain(float passbandgain)
pbg = passbandgain;
if (pbg>0.5) pbg = 0.5f;
if (pbg<0) pbg = 0.0f;
input_drive(host_overdrive);
void AudioFilterLadder::input_drive(float odrv)
host_overdrive = odrv;
if(host_overdrive >1)
if(host_overdrive>4) host_overdrive = 4.0f;
overdrive = 1.0f + (host_overdrive - 1.0f) * (1.0 - pbg); // max is 4 when pbg = 0, and 2.5 when pbg is 0.5
overdrive = host_overdrive;
if(overdrive < 0) overdrive = 0.0f;
void AudioFilterLadder::compute_coeffs(float c)
if (c > MAX_FREQUENCY) {
c = MAX_FREQUENCY;
} else if (c < 1.0f) {
c = 1.0f;
#ifdef lfq
if(c<500) lfkmod = 1.0f + (500.0f-c)*(1.0f/500.0f) * lfq;
float wc = c * (float)(2.0f * MOOG_PI / (osTimes * AUDIO_SAMPLE_RATE_EXACT));
float wc2 = wc * wc;
alpha = 0.9892f * wc - 0.4324f * wc2 + 0.1381f * wc * wc2 - 0.0202f * wc2 * wc2;
//Qadjust = 1.0029f + 0.0526f * wc - 0.0926 * wc2 + 0.0218* wc * wc2;
//Qadjust = 1.006f + 0.0536f * wc - 0.095 * wc2 ;
Qadjust = 1.006f + 0.0536f * wc - 0.095f * wc2 - 0.05f * wc2 * wc2;
bool AudioFilterLadder::resonating()
for (int i=0; i < 4; i++) {
if (fabsf(z0[i]) > 0.0001f) return true;
if (fabsf(z1[i]) > 0.0001f) return true;
return false;
static inline float fast_exp2f(float x)
float i;
float f = modff(x, &i);
f *= 0.693147f / 256.0f;
f += 1.0f;
f *= f;
f *= f;
f *= f;
f *= f;
f *= f;
f *= f;
f *= f;
f *= f;
f = ldexpf(f, i);
return f;
static inline float fast_tanh(float x)
float x2 = x * x;
return x * (27.0f + x2) / (27.0f + 9.0f * x2);
void AudioFilterLadder::update(void)
audio_block_t *blocka, *blockb, *blockc;
float Ktot;
bool FCmodActive = true;
bool QmodActive = true;
blocka = receiveWritable(0);
blockb = receiveReadOnly(1);
blockc = receiveReadOnly(2);
if (!blocka) {
if (resonating()) {
// When no data arrives but the filter is still
// resonating, we must continue computing the filter
// with zero input to sustain the resonance
blocka = allocate();
if (!blocka) {
if (blockb) release(blockb);
if (blockc) release(blockc);
return;
for (int i=0; i < AUDIO_BLOCK_SAMPLES; i++) {
blocka->data[i] = 0;
if (!blockb) {
FCmodActive = false;
if (!blockc) {
QmodActive = false;
Ktot = K;
float input = blocka->data[i] * (1.0f/32768.0f) * overdrive;
if (FCmodActive) {
float FCmod = blockb->data[i] * octaveScale;
float ftot = Fbase * fast_exp2f(FCmod);
if (ftot > MAX_FREQUENCY) ftot = MAX_FREQUENCY;
compute_coeffs(ftot);
if (QmodActive) {
float Qmod = blockc->data[i] * (1.0f/32768.0f);
Ktot = K + 4.0f * Qmod;
#ifdef lfq
if(Ktot > MAX_RESONANCE * 4 * lfkmod) Ktot = MAX_RESONANCE * 4 * lfkmod;
#else
if(Ktot > MAX_RESONANCE * 4 ) Ktot = MAX_RESONANCE * 4;
if (Ktot < 0.0f) Ktot = 0.0f;
float total = 0;
for(int os = 0; os < osTimes; os++)
float u = input - (z1[3] - pbg * input) * Ktot;
u = fast_tanh(u);
float stage1 = LPF(u, 0);
float stage2 = LPF(stage1, 1);
float stage3 = LPF(stage2, 2);
float stage4 = LPF(stage3, 3);
total += stage4 * 1/osTimes;
blocka->data[i] = total * 32767.0f ;
transmit(blocka);
release(blocka);
