/* Audio Library for Teensy, Ladder Filter
* Copyright (c) 2021, Richard van Hoesel
* THE SOFTWARE.
// Huovilainen New Moog (HNM) model as per CMJ jun 2006
// Implemented as Teensy Audio Library compatible object
// Richard van Hoesel, Feb. 21 2021
// v1.5 adds polyphase FIR or Linear interpolation
// v1.4 FC extended to 18.7kHz, max res to 1.8, 4x oversampling,
// and a minor Q-tuning adjustment
// v.1.03 adds oversampling, extended resonance,
// and exposes parameters input_drive and passband_gain
// v.1.02 now includes both cutoff and resonance "CV" modulation inputs
// please retain this header if you use this code.
// https://forum.pjrc.com/threads/60488?p=269609&viewfull=1#post269609
#ifndef filter_ladder_h_
#define filter_ladder_h_
#define LINEAR 0
#define FIR_POLY 1
#include "Arduino.h"
#include "AudioStream.h"
#include "arm_math.h"
#define LINEAR 0
#define FIR_POLY 1
#define INTERPOLATION 4
#define INTERPOLATIONscaler 4
#define I_SAMPLERATE AUDIO_SAMPLE_RATE_EXACT * INTERPOLATION
#define NUM_SAMPLES 128
#define I_NUM_SAMPLES NUM_SAMPLES * INTERPOLATION
#define interpolation_taps 32
static float interpolation_coeffs[interpolation_taps] = {
444.8708144065367380E-6, 0.002132195798620151, 0.004238318820060649, 0.005517336264360800, 0.004277228394758379,-780.0288538232418890E-6,-0.009468419595216885,-0.019306296307004593,
-0.025555801376824804,-0.022415559173490765,-0.005152700802329096, 0.027575475722578378, 0.072230543044204509, 0.120566259375849666, 0.161676773663769008, 0.185322994251944373,
0.185322994251944373, 0.161676773663769008, 0.120566259375849666, 0.072230543044204509, 0.027575475722578378,-0.005152700802329096,-0.022415559173490765,-0.025555801376824804,
-0.019306296307004593,-0.009468419595216885,-780.0288538232418890E-6, 0.004277228394758379, 0.005517336264360800, 0.004238318820060649, 0.002132195798620151, 444.8708144065367380E-6
#define interpolation_taps 36
-14.30851541590154240E-6, 0.001348560352009071, 0.004029285548698377, 0.007644563345368599, 0.010936856250494802, 0.011982063548666887, 0.008882946305001046, 826.6598116471556070E-6,
-0.011008071930708746,-0.023014151355548934,-0.029736402750934567,-0.025405787911977455,-0.006012006772274640, 0.028729626071574525, 0.074466890595619062, 0.122757573409695370,
0.163145421379242955, 0.186152844567746417, 0.186152844567746417, 0.163145421379242955, 0.122757573409695370, 0.074466890595619062, 0.028729626071574525,-0.006012006772274640,
-0.025405787911977455,-0.029736402750934567,-0.023014151355548934,-0.011008071930708746, 826.6598116471556070E-6, 0.008882946305001046, 0.011982063548666887, 0.010936856250494802,
0.007644563345368599, 0.004029285548698377, 0.001348560352009071,-14.30851541590154240E-6
class AudioFilterLadder: public AudioStream
public:
AudioFilterLadder() : AudioStream(3, inputQueueArray) {};
void frequency(float FC);
void resonance(float reson);
void octaveControl(float octaves);
void passband_gain(float passbandgain);
void input_drive(float drv);
void interpMethod(int im);
void initpoly();
virtual void update(void);
private:
float interpolation_state[(NUM_SAMPLES-1) + interpolation_taps / INTERPOLATION];
arm_fir_interpolate_instance_f32 interpolation;
float decimation_state[(I_NUM_SAMPLES-1) + interpolation_taps];
arm_fir_decimate_instance_f32 decimation;
float LPF(float s, int i);
void compute_coeffs(float fc);
bool resonating();
bool firstpoly=true;
bool polyOn = true; // linear default
float alpha = 1.0;
float beta[4] = {0.0, 0.0, 0.0, 0.0};
float z0[4] = {0.0, 0.0, 0.0, 0.0};
float z1[4] = {0.0, 0.0, 0.0, 0.0};
float K = 1.0f;
float Fbase = 1000;
float Qadjust = 1.0f;
float octaveScale = 1.0f/32768.0f;
float pbg = 0.5f;
float overdrive = 0.5f;
float host_overdrive = 1.0f;
float oldinput = 0;
audio_block_t *inputQueueArray[3];
