Results 1 to 4 of 4
Thread: USB Host port connection detection
    Apr 2019
    110
    Hello, sorry if I've missed this elsewhere in the forum. I want to detect when a MIDI controller is plugged into the USB Host port of a T3.6. Is there a callback that I can use to detect this? I want to ignore MIDI CC messages (current panel settings) that are sent when certain MIDI controllers are plugged into their host. Thank you.
    12,321
    No idea here about MIDI - but as far as USB Host trying the examples:
    > ...\hardware\teensy\avr\libraries\USBHost_t36\exam ples\Serial\MIDI\InputFunctions\InputFunctions.ino
    > …\\hardware\teensy\avr\libraries\USBHost_t36\examp les\Serial\MIDI\Interface_16x16\Interface_16x16.in o {this one fails on T_4.0 with TD 1.52b2 unless as indicated it is compiled with USB midi16}
    With a keyboard I got my wife some years back and never plugged into anything it works to display they keys and buttons and volume control.
    (edit) >> this "InputFunctions.ino" shows print text for 'CC' and other messages that could be ignored selectively
    Looks gray like this 2011 model - not the newer MK3 :: https://www.amazon.com/M-Audio-Keyst.../dp/B005F3H6QI
    Given this behavior it seems you should be able to start with one of these examples.
    Apr 2019
    110
    Thanks. Running InputFunctions gives some SysEx messages which I'm assuming are specific to the controller when it first connects, plus the selection of controller messages it's chosen to send. Nothing that is reliably a 'MIDI controller attached' signal though. I feel there must be something that can be used to signal when a USB device connects or disconnects to the host port.
    12,321
    There is a DEBUG "#define USBHOST_PRINT_DEBUG" in the USBHost library [ ...\hardware\teensy\avr\libraries\USBHost_t36\USBH ost_t36.h ] that will dump a TON of spew on connect and disconnect for each device - turning that on will give the TEXT to search back to the source.
    With that and plugging in this keyboard shows - then press/release a single key and turn the volume knob:
    port change: 10001803
        connect
      begin reset
    port change: 10001005
      port enabled
      end recovery
    new_Device: 12 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 10 01 00 00 00 08 4D 0A 9D 12 10 01 01 02 00 01
        VendorID = 0A4D, ProductID = 129D, Version = 0110
        Class/Subclass/Protocol = 0 / 0 / 0
        Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: Keystation Mini 32
    enumeration:
    Product: Keystation Mini 32
    enumeration:
    Config data length = 101
    enumeration:
    Configuration Descriptor:
      09 02 65 00 02 01 00 80 20
        NumInterfaces = 2
        ConfigurationValue = 1
      09 04 00 00 00 01 01 00 00
        Interface = 0
        Number of endpoints = 0
        Class/Subclass/Protocol = 1 / 1 / 0
      09 24 01 00 01 09 00 01 01
      09 04 01 00 02 01 03 00 00
        Interface = 1
        Number of endpoints = 2
        Class/Subclass/Protocol = 1 / 3 / 0
      07 24 01 00 01 41 00
      06 24 02 01 01 00
      06 24 02 02 02 00
      09 24 03 01 09 01 02 01 00
      09 24 03 02 0A 01 01 01 00
      09 05 81 02 40 00 00 00 00
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 64
        Polling Interval = 0
      05 25 01 01 09
      09 05 02 02 40 00 00 00 00
        Endpoint = 2 OUT
        Type = Bulk
        Max Size = 64
      05 25 01 01 01
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=20002580
    USBHub claim_device this=20002940
    Descriptor 4 = INTERFACE
    MIDIDevice claim this=20001EA0
    len = 92
      Interface is unknown (might be Yahama)
    type: 36, len: 9
        MIDI Header (ignored)
    type: 4, len: 9
    Descriptor 36 =  ???
    len = 74
      Interface is MIDI
    type: 36, len: 7
    type: 36, len: 6
        MIDI IN Jack (ignored)
    type: 36, len: 6
    type: 36, len: 9
        MIDI OUT Jack (ignored)
    type: 36, len: 9
    type: 5, len: 9
        MIDI Endpoint: 81
          rx_size = 64
    type: 37, len: 5
        MIDI Endpoint Jack Association (ignored)
    type: 5, len: 9
        MIDI Endpoint: 2
          tx_size = 64
    type: 37, len: 5
    new_Pipe
    new_Pipe
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 5 = ENDPOINT
    Descriptor 37 =  ???
    Descriptor 37 =  ???
    MIDIDevice Receive
      MIDI Data: avail = 79
    queue another receive packet
    MIDIDevice Receive
      MIDI Data: 09 90 30 2E
    avail = 78
    read: 2E309009
    Note On, ch=1, note=48, velocity=46
    MIDIDevice Receive
      MIDI Data: 09 90 30 00
    avail = 78
    read: 309009
    Note Off, ch=1, note=48, velocity=0
    MIDIDevice Receive
      MIDI Data: 0B B0 07 7E
    avail = 78
    read: 7E07B00B
    Control Change, ch=1, control=7, value=126
    MIDIDevice Receive
      MIDI Data: 0B B0 07 7D
    avail = 78
    read: 7D07B00B
    Control Change, ch=1, control=7, value=125
