Page 32 of 32 FirstFirst ... 22 30 31 32
Results 776 to 796 of 796
Thread: Teensy 4.1 Beta Test
  1. #776
    Germany NRW
    6,906
    I tend to use something like this
    #define HOT FASTRUN    __attribute__((hot))
    #define COLD FLASHMEM  __attribute__((cold))
    and then write
    HOT void blah_this_must_be_fast(void) { ..  }
    or
    COLD void some_stuff_for_init_only_or_not_critical(void) { ..  }
  2. #777
    Aug 2017
    280
    Experiments With Soldering Memory Chips To Teensy 4.1 Board
    @All - Teensy 4.1 Arduino 1.8.12 TD 1.52.
    Just made an attempt at soldering PSRAM chip to one of my T4.1 boards. 2 hours later I think I have it done without error (I hope). Tried using tape to hold the PSRAM chip to the T4.1. Was not working well for me. Then I thought why not use a dab of silicone sealer to hold it to the board. Nah, had to wait for it to setup. Then I thought what I need is a clamp. A small clamp to hold the chip in place to the board. I saw that big paper clip. Yes, that could be formed into clamp using needle nose pliers. That is what I did. After tinning the pads on the T4.1 I clamped and centered the PSRAM chip to the T4.1 and tacked two apposing PSRAM pins to the board. Then I finished soldering the rest of the pins.
    I really am not sure of the best way to test for functionality now. I tried testing the PSRAM chip with 'teensy4.1_psram_memtest.ino' and got this:
    EXTMEM Memory Test, 0 Mbyte
    With a fast blinking LED
    Then I tried 'teensy41_extram.ino' and got this response:
    External RAM test
    hardware initialized
    ID: 0D 5D 52 A1 A8 58 DC 9A
    read @000000:  55 55 55 55 55 55 54 75 55 55 55 55 54 55 55 55 41 75 55 45 55 45 51 55
    rd @70000000:  55 55 55 55 55 55 54 75 55 55 55 55 54 55 55 55 41 75 55 45 55 45 51 55
    write @000000: 48 65 6C 6C 6F 20 57 6F 72 6C 64 00 00 00 00 00 00 00 00 00 00 00 00 00
    read @000000:  48 65 6C 6C 6F 20 57 6F 72 6C 64 00 00 00 00 00 00 00 00 00 00 00 00 00
    rd @70000000:  48 65 6C 6C 6F 20 57 6F 72 6C 64 00 00 00 00 00 00 00 00 00 00 00 00 00
    write @000000: 54 65 73 74 20 31 32 33 20 54 65 73 74 00 00 00 00 00 00 00 00 00 00 00
    read @000000:  54 65 73 74 20 31 32 33 20 54 65 73 74 00 00 00 00 00 00 00 00 00 00 00
    rd @70000000:  54 65 73 74 20 31 32 33 20 54 65 73 74 00 00 00 00 00 00 00 00 00 00 00
    read @000000:  54 65 73 74 20 31 32 33 20 54 65 73 74 00 00 00 00 EA 00 00 00 00 00 00
    rd @70000000:  54 65 73 74 20 31 32 33 20 54 65 73 74 00 00 00 00 EA 00 00 00 00 00 00
    read @000000:  54 65 73 74 20 31 32 33 20 54 65 73 74 00 00 00 00 EB 00 00 00 00 00 00
    rd @70000000:  54 65 73 74 20 31 32 33 20 54 65 73 74 00 00 00 00 EB 00 00 00 00 00 00
    read @000001:  65 73 74 20 31 32 33 20 54 65 73 74 00 00 00 00 EB 00 00 00 00 00 00 55
    rd @70000001:  65 73 74 20 31 32 33 20 54 65 73 74 00 00 00 00 EB 00 00 00 00 00 00 55
    ID: FF FF FF
    I also had this compiler message:
    teensy41_extram: In function 'void setup()':
    /home/wwatson/Arduino/teensy41_extram/teensy41_extram.ino:157:27: warning: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'char*' [-fpermissive]
      strcpy(buf, "Hello World");
    In file included from /home/wwatson/arduino-1.8.12/hardware/tools/arm/arm-none-eabi/include/stdlib.h:11:0,
                     from /home/wwatson/arduino-1.8.12/hardware/teensy/avr/cores/teensy4/WProgram.h:34,
                     from /tmp/arduino_build_565606/pch/Arduino.h:6:
    /home/wwatson/arduino-1.8.12/hardware/tools/arm/arm-none-eabi/include/string.h:34:8: note:   initializing argument 1 of 'char* strcpy(char*, const char*)'
     char  *_EXFUN(strcpy,(char *__restrict, const char *__restrict));
    /home/wwatson/Arduino/teensy41_extram/teensy41_extram.ino:163:29: warning: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'char*' [-fpermissive]
      strcpy(buf, "Test 123 Test");
    I guess I am not sure if I killed the chip or if it is actually working
  3. #778
    11,764
    Is that the sketch from : Teensy-4-1-Beta-Test that post Paul posted 5/13?
    >> github.com/PaulStoffregen/teensy41_psram_memtest/blob/master/teensy41_psram_memtest.ino
    If so it would start like:
    EXTMEM Memory Test, 16 Mbyte
     CCM_CBCMR=B5AE8304 (88.0 MHz)
    testing with fixed pattern 5A698421
    testing with pseudo-random sequence, seed=2976674124
    testing with pseudo-random sequence, seed=1438200953
    or:
    EXTMEM Memory Test, 8 Mbyte
    or:
    Depending on the size of PSRAM recognized.
    It will give good feedback if soldered and working right.
  4. #779
    Plans for T4.1 Ethernet library
    I was wondering what are the plans for the software support of the native T4.1 Ethernet. Will the https://github.com/PaulStoffregen/teensy41_ethernet be extended upon towards Arduino Ethernet library compatibility, will the Arduino Ethernet library be enriched with native T4.1 Ethernet support, or will the focus be on lwip supporting the T4.1?
    Kind regards,
    Sebastian
  5. #780
    11,764
    Quote Originally Posted by wangnick View Post
    Kind regards,
    Sebastian
    Not sure where it will be in the end with regard to PJRC - but there is this thread: T4-1-Ethernet-Library that has current details.
  6. #781
    2,665
    My beta board has yesterday reached Italy. still waiting.
    Meanwhile, I ordered some T4.1 from Exp-Tech.de, arrived via USP in no time. (No custom issue within Europe)
    For the record, my beta-board arrived today (25-may-2020).
  7. #782
    Aug 2017
    280
    or:
    or:
    Unfortunately it appears to not be working. I guess I will have to pop that chip off and try again. I will check the solder connections again with my magnifying glass first. I did check for shorts between pins but detected none.
    Thanks for the link.
  8. #783
    6,893
    @wwatson, did you solder it in to where the smaller pattern is on the back of the board? (around pads 31-32?)
    You might, retouch each solder joint with solder iron to make sure good contacts, and check for any shorts...
    Also at times like this, I use the hilow test sketch that @defragster and I hacked on awhile ago to see if all of the IO pins appear to work.
    I think one of t last places that sketch was posted was up at: https://forum.pjrc.com/threads/38752...l=1#post226808
    And several places have documented what each of the pins on these patterns are. Including my excel document:
    FLASH or 2nd RAM
    4.26		1:12					RX1		P	52			GND
    4.25							TX1		P	53			50	P		CTS8	MOSI2				1:14		4.28	EMC_28
    4.29		1:15				MISO2			P	54			49	P			SCK2				1:13		4.27	EMC_27
    									3.3V			(pin 1)	51	P					SCL1				4.22	EMC_22
    RAM
    									3.3V			(pin 1)	48	P		RX8							4.24	EMC_24
    Pardon the spacing of quick copy/paste
  9. #784
    Aug 2017
    280
    FLASH or 2nd RAM
    RAM
    @All - I have the PSRAM chip working. It wasn't my soldering or a ruined chip
    I could not figure out why the one sketch 'teensy41_extram.ino' appeared to be working and 'teensy4.1_psram_memtest.ino' was not. So I started with comparing the configuration of the psram chip in both 'teensy41_extram.ino':
    	// reset the chip
    	flexspi_ip_command(0, 0);
    	flexspi_ip_command(1, 0);
    	flexspi_ip_command(2, 0);
    	delayMicroseconds(50);
    and in 'startup.c':
    	// look for the first PSRAM chip
    	flexspi2_command(0, 0); // exit quad mode
    	flexspi2_command(1, 0); // reset enable
    	flexspi2_command(2, 0); // reset (is this really necessary?)
    	if (flexspi2_psram_id(0) == 0x5D0D) {
    		// first PSRAM chip is present, look for a second PSRAM chip
    		flexspi2_command(4, 0);
    		flexspi2_command(0, 0x800000); // exit quad mode
    		flexspi2_command(1, 0x800000); // reset enable
    		flexspi2_command(2, 0x800000); // reset (is this really necessary?)
    		if (flexspi2_psram_id(0x800000) == 0x5D0D) {
    			flexspi2_command(4, 0x800000);
    			// Two PSRAM chips are present, 16 MByte
    			external_psram_size = 16;
    			// One PSRAM chip is present, 8 MByte
    			external_psram_size = 8;
    		// TODO: zero uninitialized EXTMEM variables
    		// TODO: copy from flash to initialize EXTMEM variables
    		// TODO: set up for malloc_extmem()
    		// No PSRAM
    The reason one sketch worked and the other did not was this:
    So I added that delay after the reset code:
    		// No PSRAM
    And the result was this:
    testing with pseudo-random sequence, seed=3413783263
    testing with fixed pattern 55555555
    testing with fixed pattern 33333333
    testing with fixed pattern 0F0F0F0F
    testing with fixed pattern 00FF00FF
    testing with fixed pattern 0000FFFF
    testing with fixed pattern AAAAAAAA
    testing with fixed pattern CCCCCCCC
    testing with fixed pattern F0F0F0F0
    testing with fixed pattern FF00FF00
    testing with fixed pattern FFFF0000
    testing with fixed pattern FFFFFFFF
    testing with fixed pattern 00000000
     test ran for 35.50 seconds
    All memory tests passed :-)
    What confuses me is why nobody else seemed to have this problem. Anyway for me, problem solved
  10. #785
    London, UK
    110
    This is the output for T4.1:
    PIN   GPIOn-BITm  |  GPIOn-BITm    PIN
    00  -> GPIO6-03   |   GIPO6-02  ->  01
    01  -> GPIO6-02   |   GIPO6-03  ->  00
    02  -> GPIO9-04   |   GIPO6-12  ->  24
    03  -> GPIO9-05   |   GIPO6-13  ->  25
    04  -> GPIO9-06   |   GIPO6-16  ->  19
    05  -> GPIO9-08   |   GIPO6-17  ->  18
    06  -> GPIO7-10   |   GIPO6-18  ->  14
    07  -> GPIO7-17   |   GIPO6-19  ->  15
    08  -> GPIO7-16   |   GIPO6-20  ->  40
    09  -> GPIO7-11   |   GIPO6-21  ->  41
    10  -> GPIO7-00   |   GIPO6-22  ->  17
    11  -> GPIO7-02   |   GIPO6-23  ->  16
    12  -> GPIO7-01   |   GIPO6-24  ->  22
    13  -> GPIO7-03   |   GIPO6-25  ->  23
    14  -> GPIO6-18   |   GIPO6-26  ->  20
    15  -> GPIO6-19   |   GIPO6-27  ->  21
    16  -> GPIO6-23   |   GIPO6-28  ->  38
    17  -> GPIO6-22   |   GIPO6-29  ->  39
    18  -> GPIO6-17   |   GIPO6-30  ->  26
    19  -> GPIO6-16   |   GIPO6-31  ->  27
    20  -> GPIO6-26   |   GIPO7-00  ->  10
    21  -> GPIO6-27   |   GIPO7-01  ->  12
    22  -> GPIO6-24   |   GIPO7-02  ->  11
    23  -> GPIO6-25   |   GIPO7-03  ->  13
    24  -> GPIO6-12   |   GIPO7-10  ->  06
    25  -> GPIO6-13   |   GIPO7-11  ->  09
    26  -> GPIO6-30   |   GIPO7-12  ->  32
    27  -> GPIO6-31   |   GIPO7-16  ->  08
    28  -> GPIO8-18   |   GIPO7-17  ->  07
    29  -> GPIO9-31   |   GIPO7-18  ->  36
    30  -> GPIO8-23   |   GIPO7-19  ->  37
    31  -> GPIO8-22   |   GIPO7-28  ->  35
    32  -> GPIO7-12   |   GIPO7-29  ->  34
    33  -> GPIO9-07   |   GIPO8-12  ->  45
    34  -> GPIO7-29   |   GIPO8-13  ->  44
    35  -> GPIO7-28   |   GIPO8-14  ->  43
    36  -> GPIO7-18   |   GIPO8-15  ->  42
    37  -> GPIO7-19   |   GIPO8-16  ->  47
    38  -> GPIO6-28   |   GIPO8-17  ->  46
    39  -> GPIO6-29   |   GIPO8-18  ->  28
    40  -> GPIO6-20   |   GIPO8-22  ->  31
    41  -> GPIO6-21   |   GIPO8-23  ->  30
    42  -> GPIO8-15   |   GIPO9-04  ->  02
    43  -> GPIO8-14   |   GIPO9-05  ->  03
    44  -> GPIO8-13   |   GIPO9-06  ->  04
    45  -> GPIO8-12   |   GIPO9-07  ->  33
    46  -> GPIO8-17   |   GIPO9-08  ->  05
    47  -> GPIO8-16   |   GIPO9-22  ->  51
    48  -> GPIO9-24   |   GIPO9-24  ->  48
    49  -> GPIO9-27   |   GIPO9-25  ->  53
    50  -> GPIO9-28   |   GIPO9-26  ->  52
    51  -> GPIO9-22   |   GIPO9-27  ->  49
    52  -> GPIO9-26   |   GIPO9-28  ->  50
    53  -> GPIO9-25   |   GIPO9-29  ->  54
    54  -> GPIO9-29   |   GIPO9-31  ->  29
    Thank you for this!
  11. #786
    Jul 2018
    4
    i also got a lot of help from Frank's post. I'm still learning and that's all much appreciated. may i ask you some other questions in the future? thanks again
  12. #787
    May 2015
    USA
    405
    I had teething problems with getting 4.1 to work. The issue was vmware grabbing the new USB id but arduino still partially seeing it. And maybe a udev update issue. Suggestion - a better error message than just "tcgetattr error" when the USB device isn't available. And maybe a note at about udev reload-rules and trigger in the linux installation instructions.
  13. #788
    Jun 2020
    4
    Yes there are 30 GPIO pins that i can count, that is not routed from the MCU.
    The PCB is completely filled with routing on all 4 non-plane layers, and even a few signals escape along the edges of the ground plane layer. It just wasn't possible to escape any more signals to the right hand side of the PCB.
    You could widen the PCB and stack the pins, this way it's also compatible with the old layout.
    Some extra GND pins could be very nice, specially if you think about high speed signals that need short GND distance.
  14. #789
    11,764
    Quote Originally Posted by manicksan View Post
    That note from Paul refers to usable space between the MCU pads on the underside of the chip where " It just wasn't possible to escape any more signals " ... without going to a more complex PCB build perhaps.
    You'll note the T_4.0 MCU is smaller than the T_4.1 MCU - only using that larger part was it possible to get the extra dozen++ pins to feed/escape for added :: QSPI pads, Ethernet chip, Edge pins to complete the T_4.1 as shipped.
  15. #790
    6,893
    As you probably already know, the T4.1 has already shipped, so very unlikely anything will change.
    There are always trade offs here. For example adding that extra two rows of pins would any many cases not allow me to use the board with my current layouts of other boards.
    But it will be interesting to see what layout Paul comes up with for the next board. You may want to make your comments and suggestions on one of the threads, such as:
    https://forum.pjrc.com/threads/60837...l=1#post238827
  16. #791
    Apr 2013
    151
    arrived yesterday, Thanks
  17. #792
    New York
    5,323
    OK this is going to sound like a silly question at this point in time but my memory is failing me, where is the trace I have to cut to separate Vin from USB if i want to use external power?
Name:	InkedTeensy-4.1-1 (1)_LI.jpg
    Is it at 1 going from Vusb to the big pads or 2 between the 2 big pads?
  18. #793
    6,893
    The one I cut is between the two big pads in your redish/orangish colors...
  19. #794
    New York
    5,323
    Yeah - just got my coffee and decided to look on the back of the T4.0 card and sure enough. Thats what I get for using your spreadsheet all the time
  20. #795
    3,743
    Technically you only need to do it if you plan to plug in a USB cable and provide external power at the same time. If you only provide one power source, then you don't need to cut the solder pads.
  21. #796
    New York
    5,323
    Thanks Michael. You are absolutely right except in the use case I am looking at on rover I will have primary power source when the rover is running around the house and the secondary is when i am doing testing where i would have usb plug in for debugging while still powering the rover.
    Most of the time i don't bother cutting the trace
    The one good thing that this did is that I am having a problem with the front panel USB on my PC - not putting out 5v's. Just ordered another one.
