hi there,
sorry if this all obvious but i am quite new to the concept of (midi) usb-host(ing) on the teensy.
i envisage a project where i would send usb-midi from a teensy to up to 7 usb-midi devices that are connected to a hub. one of those ports would be connected to a din-usb midi converter and receive midi from external devices, the other six ports would only send out midi (all the same data)
is it possible to have the usb-devices connected or disconnected and the code works anyways? i don't need hotplugging but i might have different usb-midi devices connected at different times, and would like the code to work in any situation. so for example on day x i have one device connected and on day y 5 devices. maybe device x is connected to port 1 once and to port3 the other day. as said before all ports would send out the same midi info, except for one port that would connect to a din-midi converter (i can also make that connection permanent)
