Results 1 to 4 of 4
Thread: RTC Battery size
    Senior Member Davidelvig's Avatar
    Aug 2015
    Wisconsin
    284
    RTC Battery size
    • Is it always a CR2032 sized coin cell for powering a real-time clock in the Teensy? Anything smaller (physical size)?
    • How long should a CR2032 last performing the RTC function?
    • Do I need to do anything in the sketch to keep the clock running (or just the added crystal, maybe caps, and the battery)?
    Thanks!
    Dave
    Aug 2018
    Brisbane, Australia
    25
    I'm using a CR1220 to power the RTC on a few teensy 3.5s. I haven't had to replace the battery yet for about 15 months.
    I use the CR2032 and all you need to do is solder the crystal and add some code.
    Here's the code I use
    // global location
    #include <TimeLib.h> // teensy time library
    #define TIME_HEADER "T"
    time_t RTCTime;
    int hours = hour();
    int minutes = minute();
    int seconds = second();
    int days = day();
    int months = month();
    int years = year();
    // in setup
    RTCTime = ProcessSyncMessage();
    if (RTCTime != 0) {
    Serial.println("Teensy3Clock.set(RTCTime)");
    Teensy3Clock.set(RTCTime); // set the RTC
    setTime(RTCTime);
    // in loop or where ever you need to know the time
    if (hour() > 12) {
    Serial.print(hour() - 12);
    else {
    Serial.print(hour());
    Serial.print(F(":"));
    if (minute() < 10) {
    Serial.print(F("0"));
    Serial.print(minute());
    if (second() < 10) {
    Serial.print(second());
    // if you need to let the user set the time
    // get from the user and pass to setTime
    setTime(hours, minutes, seconds, days, months, years);
    Teensy3Clock.set(now());
    RTCTime = now();
    ..at least I think i included all the calls from my code
    Aug 2015
    Wisconsin
    284
    Thanks, all!
