I use the CR2032 and all you need to do is solder the crystal and add some code.
Here's the code I use
// global location
#include <TimeLib.h> // teensy time library
#define TIME_HEADER "T"
time_t RTCTime;
int hours = hour();
int minutes = minute();
int seconds = second();
int days = day();
int months = month();
int years = year();
// in setup
RTCTime = ProcessSyncMessage();
if (RTCTime != 0) {
Serial.println("Teensy3Clock.set(RTCTime)");
Teensy3Clock.set(RTCTime); // set the RTC
setTime(RTCTime);
// in loop or where ever you need to know the time
if (hour() > 12) {
Serial.print(hour() - 12);
else {
Serial.print(hour());
Serial.print(F(":"));
if (minute() < 10) {
Serial.print(F("0"));
Serial.print(minute());
if (second() < 10) {
Serial.print(second());
// if you need to let the user set the time
// get from the user and pass to setTime
setTime(hours, minutes, seconds, days, months, years);
Teensy3Clock.set(now());
RTCTime = now();
..at least I think i included all the calls from my code
