Results 1 to 3 of 3
Thread: Teensy/Arduino Configuration Management Tool
    Oct 2017
    Houston
    448
    Is there a friendly CM tool for Teensy / Arduino that captures the whole Teensy environment? It'd be nice if there was a simple tool that captured:
    - The current C code (sketch) with all tabs
    - A snapshot of all libs used, both Arduino native and user add-ons
    - The current version of Arduino IDE
    - The current Teensy converter
    The reason I think this would be helpful is that I find myself going back and wanting to run something from a year or two ago, and find the libs don't work, or there are multiple names of the same lib and I can't remember which one I used, etc. etc. I guess GitHub could be set up to do this, but I was wondering if there happened to be something already setup for this purpose.
    Thanks for any suggestions! Sorry if there's already something out there and I'm just not aware of it!
    Senior Member blackketter's Avatar
    May 2015
    San Francisco
    316
    If you are willing to step away from the Arduino IDE, try out PlatformIO. https://platformio.org
    You can specify specific versions of libraries on a per-project basis, both from different sources as well as versioning within a single source.
    Oct 2017
    Houston
    448
    Thx, will check it out.
