Results 1 to 6 of 6
Thread: Data cache demo on Teensy 4.0
    Feb 2019
    123
    Is the data cache used on the Teensy 4.0 in a usual program for holding the data? Or is the on-chip RAM so fast that no data cache is used. How can I demonstrate that the data-cache is used. Is the data cache used if I put data into the flash memory?
    22,497
    Cache is used for RAM2 and Flash. RAM1 is as fast as the processor, so cache is not used for RAM1.
    See "Memory Layout" on the product page:
    https://www.pjrc.com/store/teensy40.html
    Feb 2019
    123
    That would mean that dynamically allocated variables (via malloc) would need the cache, right?
    Feb 2019
    123
    Cache demo seems to work now with a buffer in RAM2
    Germany NRW
    6,920
    Quote Originally Posted by ossi View Post
    malloc() uses RAM2.
    No, it would use the cache. (not need). As it works automagically, you don't need to worry about the cache.
    You need cache-handling manually in one case only: If you use DMA.
    DMA does not invalidate the cache, and it does not know that cache may contain data which is not in RAM. The cache is configured as write-back.
    Feb 2019
    123
    A cache entry can be cleared and invalidated by:
    SCB_CACHE_DCCISW = (((sets << SCB_DCCISW_SET_Pos) & SCB_DCCISW_SET_Msk) | ((ways << SCB_DCCISW_WAY_Pos) & SCB_DCCISW_WAY_Msk) );
    Is there also a posibility to get the info about a cache entry without altering the cache entry?
