woodencase01
I wanted to check what were the difference between SD card class within Teensy Audio application.
I'm using a Teensy 3.2
Working with PlatformIO on VS Code
Here is my methodology:
I have the following SD cards:
SanDisk 4GB SDHC Class 4
Patriot 16GB SDHC Class 10
Netac 128GB SDXC Class V30
I had to format the Netac to FAT32 to get it to work. I used this software.
For some reasons, the RAW files crashed the Teensy when using more than one sound.
Nevertheless, I managed to get some results I wanted to share with you.
For some reasons, the 4GB file have the best overall performance... But the audio performance is in par with the other synthetic benchmark.
Also, I think the CPU usage function is an approximation, but I only hear glitches using the 16GB card.
Also, considering the Class rating with Sequential Write, the Class 4 (8.2MB/s) performed better than the Class 10(6.5MB/s). Maybe there is a wrong class rating there, where the Patriot might be falsified?
The class V30 was closer to its specification (19.7MB/s).
- Ran a clean format using SD Formatter
- Ran a CrystalDiskMark benchmark
- Ran the Teensy SD Card Test code
- Ran a custom code for reading WAV and RAW files
