Page 2 of 2 FirstFirst 1 2
Results 26 to 33 of 33
Thread: ws2812b + teensy 4.0: LED strip only shows few frames when powered on
  1. #26
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    277
    Thanks houtson, but modifying my basic sketch above to:
    #include <WS2812Serial.h>
    #define USE_WS2812SERIAL
    #include <FastLED.h>
    #define DATA_PIN    7
    #define NUM_LEDS    1
    #define NUM_STRIPS  1
    CRGB leds[NUM_LEDS];
      // FastLED.addLeds<NUM_STRIPS, WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS);
      FastLED.addLeds<WS2812SERIAL, DATA_PIN, BRG>(leds, NUM_LEDS);
      leds[0] = CRGB::Red;
      FastLED.show();
    ...does not work for me.
    Am I missing something?
    Thanks,
    Paul
  2. #27
    Apr 2015
    Netherlands
    277
    Yeah, I missed this...
    Changed DATA_PIN to 1 and now it works:
    #define DATA_PIN    1
    #define NUM_LEDS    1
      FastLED.show();
    Paul
  3. #28
    Junior Member FOB's Avatar
    Jun 2020
    Brazil
    3
    I have tested with this parallel output, but with this I cannot use different length strips witch is my case. With teensy 3.6 Ive used as this:
    #define NUM_LEDS 121
    #define BRIGHTNESS p
    CRGB leds1[NUM_LEDS];
    CRGB leds2[NUM_LEDS];
    Setup
    FastLED.addLeds<WS2812,12,GRB>(leds1,21,NUM_LEDS); // one strip begins on LED 21
    FastLED.addLeds<WS2812,11,GRB>(leds1,NUM_LEDS);
    FastLED.addLeds<WS2812,10,GRB>(leds2,NUM_LEDS);
    And worked, but with teensy 4.0 don't.
  4. #29
    May 2020
    13
    I already used Parallel Output Mode in the sketch in the original question so this as well as houtson's code didn't get me any further. :/
  5. #30
    Aug 2015
    Scotland
    120
    Hi FinleyOderSo, can you throw up your latest code with the changes you made, Cheers, Paul
  6. #31
    Apr 2015
    Netherlands
    277
    Hi FinleyOderSo,
    I compiled and ran the code you showed in msg #1.
    The sketch runs but the walking dots do not walk smoothly and you see regularly other LEDs light up very shortly. A full cycle/loop takes ~23 secs.
    Adding #define FASTLED_ALLOW_INTERRUPTS 0 at the top of the sketch makes the whole sketch run faster(~18 secs for a cycle) and the occasional flickering of other LEDs disappeared but the walking dots are still moving jerky.
    My 144-LED strip is externally powered by a 5V/7A powersupply. And a levelshifter is used ofcourse.
    Paul
  7. #32
    Apr 2015
    Netherlands
    277
    Looking further into the jerkiness of the walking dot, I shot a short video at 60fps and played it frame-by-frame using PotPlayer. Use 'D' key [backward 1 frame] or 'F' key [forward 1 frame].
    You can find the video and the code here.
    Now things get interesting: the walking LED is sometimes skipping a dot forward or jumping back a dot...
    Definitely something goes wrong here: perhaps not the output timing but the way the array is read out?
    Paul
  8. #33
    May 2020
    13
    So,
    fortunately I got the code working now with the WS2812BSerial library Houtson suggested and the walking dot now is much less jerky. I also got "FASTLED_ALLOW_INTERRUPTS 0" working with Paul's guideline.
    So this is my current code:
    #include <WS2812Serial.h>  // leds
    #define USE_WS2812SERIAL  // leds
    #include <FastLED.h>      // leds
    #define DATA_PIN  1  // it is critical that you use this pin number or other pin numbers using FastLED's Parallel Output procedure
    int brightness = 40;
    // Teensy 4.0 Stuff ================
    #define NUM_LEDS_PER_STRIP 144
    #define NUM_LEDS   NUM_LEDS_PER_STRIP
    CRGB leds[NUM_LEDS_PER_STRIP * NUM_STRIPS];
        //FastLED.addLeds<NUM_STRIPS, WS2812B,DATA_PIN,GRB>(leds, NUM_LEDS_PER_STRIP);
      //USE for WS2811:
     // FastLED.addLeds<NUM_STRIPS, WS2811, DATA_PIN >(leds, NUM_LEDS_PER_STRIP);
      FastLED.setBrightness(brightness);
      FastLED.setMaxPowerInVoltsAndMilliamps(5, 1500);
       set_max_power_indicator_LED(13);
      fill_solid(leds, NUM_LEDS, CRGB::Black);
      FastLED.show();
         fill_solid( leds, NUM_LEDS, CRGB::Red);
         FastLED.delay(500);
         fill_solid( leds, NUM_LEDS, CRGB::Black);
         FastLED.delay(500);
         fill_solid( leds, NUM_LEDS, CRGB::Blue);
         FastLED.delay(500);
         FastLED.delay(500);
         fill_solid( leds, NUM_LEDS, CRGB::Yellow);
         FastLED.delay(500);
         FastLED.delay(500);
         cd77_colorwipe_dot(CRGB::Red, 0, NUM_LEDS, 40);
         cd77_colorwipe_dot(CRGB::Blue, 0, NUM_LEDS, 40);
         cd77_colorwipe_dot(CRGB::Green, 0, NUM_LEDS, 40);
    void cd77_colorwipe_dot(CRGB color,uint16_t from,  uint16_t to,  uint16_t wait) {
      for (uint16_t i = from; i <to; i++) {
        leds[i] = color;
        FastLED.delay(wait);
        leds[i] = CRGB::Black;
        FastLED.show();
    The problem is still that fill_solid as well as for-looping through all leds only fills about half of them.
