Results 1 to 3 of 3
Thread: Teensy 4.0 Ventilator Circuit Control (DC Motor Driver)
    Apr 2020
    1
    Hi Guys,
    I am new here but definitely excited to get started on my first project!
    I am working with some colleagues to develop an open-source ventilator solution. One piece of the puzzle we are working on is creating a closed-loop pressure control regulator. The current design configuration uses a Voice Coil Actuator (effectively a DC motor), with positive current turning a pneumatic servo-valve "ON" and negative current exhausting the gas to the atmosphere. Zero current is an idle position.
    I think we want to use a Teensy 4.0 combined with an H-bridge to perform closed-loop pressure control on the pressure circuit. We want to use a PID control strategy to ultimately control the final pressure output. The feedback signal will be a pressure sensor output stage. Finally we want the tunable variables to be stored in flash memory on the Teensy 4.0.
    With that said, I am a bit stuck on the code side of things. I am very new to the Arduino family and I am curious as to where to start.
    Dan
    Nov 2015
    9
    Take a look at https://www.pjrc.com/teensy/td_pulse.html for the analog write functions to control your H bridge.
    Oct 2015
    Roma (IT, EU)
    312
    Great project, a bit generic at the moment.
    Try breaking down the various steps "as seen by the Teensy" and it would be easier to suggest things.
    For example: which kind of signal do you have from the pressure sensor? Analog, I2C, ..?
    Also be aware that Teensy 4 has 3.3v logic level and is not 5v tolerant.
    As to store variables in flash memory, you may know EEPROM lib already, but repetita juvant
    https://www.pjrc.com/teensy/td_libs_EEPROM.html
    Teensy 4.0 is not listed yet, but it has 60KB of EEPROM where you can store your variables.
