Results 1 to 2 of 2
Thread: method to addd a transistor to 4.0 or 3.2 to boost a pin output to 5v
    Jan 2020
    Greenport NY
    1
    For either a 4.0 or 3.2, I need to boost the output of a pin, for example
    pinMode(5, OUTPUT); // and later
    digitalWrite(5, HIGH); // produces ~3.3v on pin 6
    yet I need 5v. to trigger the DC motor drive module input of this part https://www.droking.com/160W-2-Chann...tor-Controller
    Q1. Please provide a link to a schematic to help me place a transistor correctly on the breadboard.
    Q2. Would any old transistor do the job? I've got a few in my Radio Shack NPN PNP stash.
    Ideally I'd also like to pass along a PWM value to control the speed of the vacuum motor, and to that end I've got
    analogWrite(6, 100); // to suitably dim an LED
    Q3. Would the solution to Q1 above also pertain passing along a suitably strong 5v PWM signal to a DC motor drive module input?
    I've scanned some forum postings and I think I almost understand that this can be done. A simple simple schematic with added instructions would be most appreciated.
    Project: a Cuirass Ventilator solution within https://helpwithcovid.com/projects/13
    Thank you, Steve
    Jun 2013
    Torrance CA
    415
    A1) https://www.instructables.com/id/12V...-NPN-Transist/ (NPN), https://startingelectronics.org/begi...rduino-buzzer/ (PNP) just replace the 12V with 5V and the motor/buzzer with the controller. You don't need the diode from the first example.
    A2) Since you're just driving another controller you shouldn't need a huge current gain so yes I'd say just about any modern transistor will work.
    A3) PWM should work fine.
