Rotary encoder find
Dulz
Hi everyone, i found this rotary encoder at work and would like to attempt to read it.
The details i can make out are:
Matsushita ER24 (from research i believe is panasonic)
AER12122
The instructions i will post a photo, but they are all in what i assume is Japanese.
My fist issue is, does anyone know how to wire this thing up? With unreadable instructions and i cant seem to find anything online, its a pretty big first hurdle!
Second, any advice on which teensy would be best used? I think from memory the 3.6 could count seperatly to the main code? Is that correct? And if so do they all do that?
From what i can see on the instructions, it says 12v-24v. I'm assuming that is the red wire? I also am assuming that the others are signal wires and that they wouldn't need 12v?
Based on some other forum post I found from Russia
The outputs are open collector so they just need pulled up to the appropriate voltage for the microcontroller, in this case 3.3v for the Teensy 3.6
Red: 12v-24v
Black: 0v or Ground
Shield: Ground
White: A
Green: B
Yellow: Z (optional)
Hi Guys, thanks for your replys. I have had a go at connecting it to a teensy 3.6 using the wiring vjmuzik gave above.
It appears to be counting, however only counting upwards. If i spin it either way then it goes up. Any thoughts on why? I will post the code in my next reply.
#define ENCODER_OPTIMIZE_INTERRUPTS
#include <Encoder.h>
// Change these pin numbers to the pins connected to your encoder.
// Best Performance: both pins have interrupt capability
// Good Performance: only the first pin has interrupt capability
// Low Performance: neither pin has interrupt capability
Encoder knobLeft(9, 10);
// avoid using pins with LEDs attached
while (!Serial) {}
Serial.println("Encoder Test:");
long positionLeft = -999;
long newLeft;
newLeft = knobLeft.read();
if (newLeft != positionLeft) {
Serial.print("Left = ");
Serial.print(newLeft);
positionLeft = newLeft;
if (Serial.available()) {
Serial.read();
Serial.println("Reset both knobs to zero");
knobLeft.write(0);
I put a 10k pullup resistor to pins 9 and 10, which really smoothed it out, otherwise it was going crazy counting when it wasnt even spinning. But only counts up.
Do you have access to a logic analyzer or a 2-channel oscilloscope?
It would be useful to see the waveform on A and B while rotating in the two directions.
You could use the teensy and the arduino IDE serial plotter as a logic analyser.
Turn the encoder and take a photo. It's not ideal but here you can see two good channels.
Reversing the encoder will show reversed color order.
//wire channels a and b to inputs 0 and 1
 pinMode(0,INPUT_PULLUP);
 pinMode(1,INPUT_PULLUP);
  Serial.print(digitalRead(0));
  Serial.print(",");
  Serial.println(digitalRead(1));
Although I expect you will only be getting one channel.
Note my cheapy encoder here uses White for VCC and Red as A signal. If I were to wire it up incorrectly I expect at the least I would blow one of the channels.
Edit: You could wire your channels to an analog pin and then you have a teensy oscilloscope.
//wire channels a and b to inputs 14 and 15
 pinMode(14,INPUT_PULLUP);
 pinMode(15,INPUT_PULLUP);
  Serial.print(analogRead(14));
  Serial.print(",");
  Serial.println(analogRead(15));
Thanks for the replys guys,
I played around a bit longer yesterday and was able to get it reading both ways by putting a capacitor in the line with a pullup resiter as well, however i wouldn't say it was a reliable read, every turn i could get different results and going backwards read about 20% less than going forwards.
So today I tryed the make your own oscilloscope idea, and my results definitely look different to the ones you posted. I will post pictures. It was going crazy just sitting there, so i put a delay(100) in there to try and see what was happening. The photos have the delay.
This pic the encoder was just sitting still
This pic i rotated it slightly and then let it sit still
There was no capacitor or pullups when i ran this test.
Jason
So in the first picture, the encoder was not moving? And yet, there's a pulse on one of the 2 lines (A or B)...!?
That's odd. I have no idea, have to pass.
