Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 26 to 50 of 132
Thread: T4.1 Ethernet Library
  1. #26
    Apr 2017
    644
    Is NativeEthernet (and FNET) at a point where it can be included with a Teensyduino installer?
    I'm getting ready to package up 1.53-beta3....
    I suppose it is, it’s worked so far at least.
  2. #27
    Apr 2017
    644
    Update:
    Add MDNS wrapper
    -Add WebServerMDNS example
    -Update keywords
    For a web server all it takes is two lines to use MDNS and get a .local address:
    MDNS.begin("Teensy41");  //Domain name
    MDNS.addService("_http._tcp", 80);  //Type of service and port number
  3. #28
    Hi vjmuzik,
    thank you very much for doing this nice work....
    Is the library able to do multicast ?
    Thank you
    Torsten
  4. #29
    Apr 2017
    644
    Yes it's able to do multicast already.
  5. #30
    Quote Originally Posted by vjmuzik View Post
    Great...big thumbs up....thank you
    Torsten
  6. #31
    Apr 2017
    644
    Native Ethernet Update:
    Support for FNET TLS sockets (server-side only for now)
    -Update WebServerMDNS with optional TLS
    FNET Update:
    Readded mbedtls source and support
    -Fixed MDNS service name overflow
    Most likely will work on client-side TLS tomorrow, I've already went through the mbedtls source and put everything in FLASHMEM and large constants in PROGMEM. Without doing that dynamic memory was at 54%, now it sits at 26% with TLS support and at 22% without TLS support, so not too much of an impact at all.
  7. #32
    Apr 2017
    644
    Add client-side TLS support
    -Add WebClientRepeatingTLS example
    -Add client.close() to support proper HTTP close before disconnecting
    -Add functions to set client and server certificates/keys (if needed)
    FNET Update:
    Change mbedtls client verify to optional
    -Disable unused IPv6 support
    As stated yesterday here is the client-side support for TLS as well as an example showcasing the PJRC homepage in all it's HTTPS glory.
  8. #33
    Jul 2020
    12
    I have started porting one of our application that has a web interface. It worked no issues on the Teensy 3.2, and 4.0 with the Wiznet Module, but it is having issues with the 4.1 Network Stack.
    I am using the NativeEthernet library and an updated version of the Webuino library. From what I can tell, there may be two issues, 1. When writing out to the EhternetClient in response to a Web Request, the write is not blocking like it did on the wiznet. On the receiving side, I am seeing parts of my web page, but can tell where it is breaking up, like it was sending data, then interrupted by another write.
    The second issue seems to be with the Client Flush Command, this appears to always hang forever.
    -Steve
  9. #34
    Apr 2017
    644
    Can I get a minimal example of this so that I can find out what's causing the issue? Indeed FNET is non-blocking but it shouldn't send things out of order or overlapping since that would break TCP sockets altogether, I haven't really messed with the Client Flush Command so it very well may be a simple fix for that part.
  10. #35
    Jul 2020
    12
    Just for testing, I just modified the code where it was actually sending out the data to the web client. I placed a delay(10) in front of each Client.write(buffer, sizeof buffer)) and I get a complete web page now.
    The issue may be cause by the size of the web page, it is quite large. The WebServer Application buffers the output into chunks, and sends them out when the buffer gets full (around 64 bytes). I have not been able to track down where in the HTML it is breaking, but I see several chunks, then a chunk that was interrupted, then more chunks. The complete web page is around 40K with inline css, images, etc.
  11. #36
    Apr 2017
    644
    What's likely happening is because of the non blocking nature of FNET it's completely filling the buffers before a packet is sent so data is being overwritten, that would be why adding a delay works since it gives it time to send. I'll work on a fix for this later likely involving client.flush since that's what it's supposed to stop from happening.
  12. #37
    Jul 2020
    12
    Just did another test with the examples included with the NativeEthernet Library.
    I just added the following lines to the WebServer Example and see where my data is getting dropped.
    I only get lines 0-19 and line 19 is a partial line. I don't get the ending br or closing html tag.
              for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
                int sensorReading = analogRead(analogChannel);
                client.print("analog input ");
                client.print(analogChannel);
                client.print(" is ");
                client.print(sensorReading);
                client.println("<br />");
              >>for (int i = 0; i < 50; i++) {
              >>     client.printf("%5.5d - AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA<br>",i);
              client.print("<br />");
              client.println("</html>");
    Apr 2017
    644
    Alright I posted the fix, it was simple, I also tested client.flush() and it does work without freezing, but that's probably because I already fixed the socketSendAvailable function that it uses in a recent update. Of course the problem was a buffer overflow like I thought since increasing the socket size let it send more data before failing, I tested the fix down to a 512 byte socket size with no issues so I would call it good.
  14. #39
    Jul 2020
    12
    That did help and I am now getting a complete web page. I am having some issues with stability and having the entire CPU lock up. I'm hoping it is a memory leak on my side, still investigating that one. The other thing I did notice, if I power up the board with no network cable connected, the board hangs initializing the Ethernet library. I'm still trying to tack down exactly which call is hanging. I wish we had a real debugger in Arduino!!
  15. #40
    Apr 2017
    644
    It doesn't hang but it certainly is blocking, I'm pretty sure the original w5500 fails if there is no cable connected on startup so I mirrored that in my begin function since the wrapper library is supposed to act the same way as the original. I suppose since I'm already extending the original api to support more things I should add a non blocking begin function so that hot plugging can be better supported.
  16. #41
    Oct 2016
    Essex, England
    19
    I know this thread is really just regarding the NativeEthernet library, but could I ask if someone point me in the right direction, since I purchased my T4.1 I have wanted to try using the Ethernet for connecting my T4.1 to my laptop (no internet just direct) so that eventually I can use a web page to read from and be able to send data back to my T4.1. I have been visiting the 'www.startingelectronics.org' web site which has a good set of examples for pretty much a good starting point for what I am looking to do, albeit its for Arduino, and all I have had to changed is from ethernet.h to NativeEthernet.h, changed the SD card to 'BuiltIn' and got it to find the T4,.1 Mac address. Now I can run the basic webserver no problem but when I ask to send the web page from my SD card as well it doesn't display anything.
    This works fine just sending Analog readings to a fairly blank web page;
      Web Server
     A simple web server that shows the value of the analog input pins.
     using an Arduino Wiznet Ethernet shield.
     Circuit:
     * Ethernet shield attached to pins 10, 11, 12, 13
     * Analog inputs attached to pins A0 through A5 (optional)
     created 18 Dec 2009
     by David A. Mellis
     modified 9 Apr 2012
     by Tom Igoe
    #include <NativeEthernet.h>
    // Enter a IP address for your controller below.
    uint8_t mac[6];
    IPAddress ip(192,168,1,177);
    // Initialize the Ethernet server library
    // with the IP address and port you want to use
    // (port 80 is default for HTTP):
    EthernetServer server(80);
    // Find Mac address for Teensy
    static void teensyMAC(uint8_t *mac) {
      uint32_t m1 = HW_OCOTP_MAC1;
      uint32_t m2 = HW_OCOTP_MAC0;
      mac[0] = m1 >> 8;
      mac[1] = m1 >> 0;
      mac[2] = m2 >> 24;
      mac[3] = m2 >> 16;
      mac[4] = m2 >> 8;
      mac[5] = m2 >> 0;
       while (!Serial) {
        ; // wait for serial port to connect. Needed for Leonardo only
      Serial.println("About to start Ethernet, apparently the cable needs plugged in before it will proceed!");
      teensyMAC(mac);
      static char teensyMacString[23];
      sprintf(teensyMacString, "MAC: %02x:%02x:%02x:%02x:%02x:%02x", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
      Serial.println(teensyMacString);
      // start the Ethernet connection and the server:
      Ethernet.begin(mac, ip);
      server.begin();
      Serial.print("server is at ");
      Serial.println(Ethernet.localIP());
      // listen for incoming clients
      EthernetClient client = server.available();
      if (client) {
        Serial.println("new client");
        // an http request ends with a blank line
        boolean currentLineIsBlank = true;
        while (client.connected()) {
          if (client.available()) {
            char c = client.read();
            Serial.write(c);
            // if you've gotten to the end of the line (received a newline
            // character) and the line is blank, the http request has ended,
            // so you can send a reply
            if (c == '\n' && currentLineIsBlank) {
              // send a standard http response header
              client.println("HTTP/1.1 200 OK");
              client.println("Content-Type: text/html");
              client.println("Connection: close");
              client.println();
              client.println("<!DOCTYPE HTML>");
              client.println("<html>");
              // add a meta refresh tag, so the browser pulls again every 5 seconds:
              client.println("<meta http-equiv=\"refresh\" content=\"1\">");
              // output the value of each analog input pin
            if (c == '\n') {
              // you're starting a new line
            else if (c != '\r') {
              // you've gotten a character on the current line
              currentLineIsBlank = false;
        // give the web browser time to receive the data
        delay(1);
        // close the connection:
        client.stop();
        Serial.println("client disonnected");
    But if I try to send the Web page from SD Card I get nothing
      Program:      eth_websrv_SD_Ajax
      Description:  Arduino web server that serves up a web page
                    that displays the status of a switch connected
                    to pin 3 of the Arduino.
                    The web page is stored on the SD card.
                    The web page contains JavaScript code that uses
                    Ajax to request the state of the switch every
                    second.
      Hardware:     Arduino Uno and official Arduino Ethernet
                    shield. Should work with other Arduinos and
                    compatible Ethernet shields.
                    2Gb micro SD card formatted FAT16
                    Push button switch interfaced to pin 3 of the
                    Arduino
      Software:     Developed using Arduino 1.0.5 software
                    Should be compatible with Arduino 1.0 +
                    SD card contains web page called index.htm
      References:   - WebServer example by David A. Mellis and
                      modified by Tom Igoe
                    - SD card examples by David A. Mellis and
                      Tom Igoe
                    - Ethernet library documentation:
                      http://arduino.cc/en/Reference/Ethernet
                    - SD Card library documentation:
                      http://arduino.cc/en/Reference/SD
      Date:         25 March 2013
      Modified:     17 June 2013
                    - removed the use of the String class
      Author:       W.A. Smith, http://startingelectronics.org
    // size of buffer used to capture HTTP requests
    #define REQ_BUF_SZ   400
    // MAC address from Ethernet shield sticker under board
    uint8_t mac[6];
    IPAddress ip(192, 168, 1, 177); // IP address, may need to change depending on network
    EthernetServer server(80);  // create a server at port 80
    File webFile;
      mac[0] = m1 >> 8;
      mac[1] = m1 >> 0;
      mac[2] = m2 >> 24;
      mac[3] = m2 >> 16;
      mac[4] = m2 >> 8;
      mac[5] = m2 >> 0;
    // Select SD Card
    const int chipSelect = BUILTIN_SDCARD;  // For SD Card Chip select
    char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
    char req_index = 0;              // index into HTTP_req buffer
        Serial.begin(9600);       // for debugging
      teensyMAC(mac);
        // initialize SD card
        Serial.println("Initializing SD card...");
        if (!SD.begin(chipSelect)) {
            Serial.println("ERROR - SD card initialization failed!");
            return;    // init failed
        Serial.println("SUCCESS - SD card initialized.");
        // check for index.htm file
        if (!SD.exists("index.htm")) {
            Serial.println("ERROR - Can't find index.htm file!");
            return;  // can't find index file
        Serial.println("SUCCESS - Found index.htm file.");
        pinMode(3, INPUT);        // switch is attached to Arduino pin 3
        Ethernet.begin(mac, ip);  // initialize Ethernet device
        server.begin();           // start to listen for clients
        EthernetClient client = server.available();  // try to get client
        if (client) {  // got client?
                if (client.available()) {   // client data available to read
                    char c = client.read(); // read 1 byte (character) from client
                    // buffer first part of HTTP request in HTTP_req array (string)
                    // leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
                    if (req_index < (REQ_BUF_SZ - 1)) {
                        HTTP_req[req_index] = c;          // save HTTP request character
                        req_index++;
                    // last line of client request is blank and ends with \n
                    // respond to client only after last line received
                         client.println("Connection: keep-alive");
                        client.println();
                        // Ajax request
                        if (StrContains(HTTP_req, "ajax_switch")) {
                            // read switch state and send appropriate paragraph text
                            GetSwitchState(client);
                        else {  // web page request
                            // send web page
                            webFile = SD.open("index.htm");        // open web page file
                            if (webFile) {
                                while(webFile.available()) {
                                    client.write(webFile.read()); // send web page to client
                                webFile.close();
                        // display received HTTP request on serial port
                        Serial.println(HTTP_req);
                        // reset buffer index and all buffer elements to 0
                        req_index = 0;
                        StrClear(HTTP_req, REQ_BUF_SZ);
                    // every line of text received from the client ends with \r\n
                    if (c == '\n') {
                        // last character on line of received text
                        // starting new line with next character read
                        // a text character was received from client
                } // end if (client.available())
            } // end while (client.connected())
            delay(1);      // give the web browser time to receive the data
            client.stop(); // close the connection
        } // end if (client)
    // send the state of the switch to the web browser
    void GetSwitchState(EthernetClient cl)
        if (digitalRead(3)) {
            cl.println("Switch state: ON");
        else {
            cl.println("Switch state: OFF");
    // sets every element of str to 0 (clears array)
    void StrClear(char *str, char length)
        for (int i = 0; i < length; i++) {
            str[i] = 0;
    // searches for the string sfind in the string str
    // returns 1 if string found
    // returns 0 if string not found
    char StrContains(char *str, char *sfind)
        char found = 0;
        char index = 0;
        char len;
        len = strlen(str);
        if (strlen(sfind) > len) {
            return 0;
        while (index < len) {
            if (str[index] == sfind[found]) {
                found++;
                if (strlen(sfind) == found) {
                    return 1;
            else {
                found = 0;
            index++;
        return 0;
    I can open the index.htm file from explorer and its fine so that code is ok and the SD card (2Gb) is working great. What am I overlooking, I am guessing something really stupid but its woods and trees at the moment.
  17. #42
    Apr 2017
    644
    Have you tried serial printing the file as a starting point to verify everything is correct? You may have to update the libraries as well, I fixed a sending problem earlier today, and there will be some other fixes later tomorrow, but only for UDP.
  18. #43
    Oct 2016
    Essex, England
    19
    Ok then that's interesting, it gets as far as "EthernetClient client = server.available();" constantly whereas I have put other Serial prints at each section it should enter when conditions are right.
    The "192.168.1.177" is polling (I am using Chrome for this) issuing a statement that it is waiting then clears does nothing for several seconds then repeats it is waiting again. Does that mean I have some wrong with my laptop set-up...
  19. #44
    Oct 2016
    Essex, England
    19
    That should have said constantly printing, sorry.
  20. #45
    Apr 2017
    644
    If the basic web server worked then there shouldn’t be a problem with the laptop setup, I do my tests with a laptop as well so I know it does work directly connected to it just fine.
  21. #46
    Oct 2016
    Essex, England
    19
    Just to mention I did your latest update yesterday just in case I had something corrupted.
    Its really odd because any example I run that doesn't involve the sd card works fine, so I am guess two way conversation is taking place for them to work.
  22. #47
    Oct 2016
    Essex, England
    19
    Ok I get a 'SendErr: -20' where does that come from.
  23. #48
    Apr 2017
    644
    Here’s the fulle list of errors: https://github.com/vjmuzik/FNET/blob...k/fnet_error.h
    Seems the socket did not connect like it was supposed to.
  24. #49
    Oct 2016
    Essex, England
    19
    Thanks for that, I had a -17 as well but just once. I have just tried using the Web Datalogger sketch from the startingelectronics.org web site which reads an analog channel and stores it on the SD card but, the bit I am interested in, it sends a *.htm file from SD to browser. This works, its a bit more complicated (well for me it is), so I am thinking I need to work and understand this, I will get there.
    For reference this is the Web Datalogger sketch.
    // Basic Arduino Web Server version 0.1 modified to include logging
    // http://startingelectronics.org/software/arduino/web-server/basic-01/
    // More details and web files available from:
    // http://startingelectronics.org/software/arduino/web-server/01-log-data/
    // Date: 11 July 2015
    // maximum length of file name including path
    #define FILE_NAME_LEN  20
    // HTTP request type
    #define HTTP_invalid   0
    #define HTTP_GET       1
    #define HTTP_POST      2
    // file types
    #define FT_HTML       0
    #define FT_ICON       1
    #define FT_CSS        2
    #define FT_JAVASCRIPT 3
    #define FT_JPG        4
    #define FT_PNG        5
    #define FT_GIF        6
    #define FT_TEXT       7
    #define FT_INVALID    8
    long log_time_ms = 5000; // how often to log data in milliseconds
    long prev_log_time = 0;   // previous time log occurred
    // the media access control (ethernet hardware) address for the shield:
    const byte mac[] PROGMEM = { 0x04, 0xE9, 0xE5, 0x0B, 0xA9, 0x92 };
    //the IP address for the shield:
    const byte ip[] = { 192, 168, 1, 177 };  // does not work if this is put into Flash
    // the router's gateway address:
    const byte gateway[] PROGMEM = { 192, 168, 0, 1 };
    // the subnet:
    const byte subnet[] PROGMEM = { 255, 255, 255, 0 };
    // Select SD Card
      Serial.begin(115200);       // for debugging
        return;  // SD card initialization failed
      Ethernet.begin((uint8_t*)mac, ip, gateway, subnet);
      server.begin();  // start listening for clients
      // if an incoming client connects, there will be bytes available to read:
      if (client) {
          if (ServiceClient(&client)) {
            // received request from client and finished responding
        }  // while (client.connected())
        delay(1);
        client.stop();
      }  // if (client)
      // log the data
      LogData();
    }// void loop()
    void LogData(void)
      unsigned long current_time;   // current millisecond time
      File logFile;                 // file to log data to
      current_time = millis();  // get the current time in milliseconds
      if ((current_time - prev_log_time) > log_time_ms) {
        prev_log_time = current_time;
        // the log time has elapsed, so log another set of data
        logFile = SD.open("log.txt", FILE_WRITE);
        if (logFile) {
          logFile.print(current_time);
          logFile.print(" = ");
          logFile.println(analogRead(5)); // log the analog pin value
          logFile.close();
    bool ServiceClient(EthernetClient *client)
      static boolean currentLineIsBlank = true;
      char cl_char;
      File webFile;
      // file name from request including path + 1 of null terminator
      char file_name[FILE_NAME_LEN + 1] = {0};  // requested file name
      char http_req_type = 0;
      char req_file_type = FT_INVALID;
      const char *file_types[] = {"text/html", "image/x-icon", "text/css", "application/javascript", "image/jpeg", "image/png", "image/gif", "text/plain"};
      static char req_line_1[40] = {0};  // stores the first line of the HTTP request
      static unsigned char req_line_index = 0;
      static bool got_line_1 = false;
      if (client->available()) {   // client data available to read
        cl_char = client->read();
        if ((req_line_index < 39) && (got_line_1 == false)) {
          if ((cl_char != '\r') && (cl_char != '\n')) {
            req_line_1[req_line_index] = cl_char;
            req_line_index++;
          else {
            got_line_1 = true;
            req_line_1[39] = 0;
        if ((cl_char == '\n') && currentLineIsBlank) {
          // get HTTP request type, file name and file extension type index
          http_req_type = GetRequestedHttpResource(req_line_1, file_name, &req_file_type);
          if (http_req_type == HTTP_GET) {         // HTTP GET request
            if (req_file_type < FT_INVALID) {      // valid file type
              webFile = SD.open(file_name);        // open requested file
              if (webFile) {
                client->println(F("HTTP/1.1 200 OK"));
                client->print(F("Content-Type: "));
                client->println(file_types[req_file_type]);
                client->println(F("Connection: close"));
                client->println();
                // send web page
                  int num_bytes_read;
                  char byte_buffer[64];
                  // get bytes from requested file
                  num_bytes_read = webFile.read(byte_buffer, 64);
                  // send the file bytes to the client
                  client->write(byte_buffer, num_bytes_read);
                webFile.close();
              else {
                // failed to open file
            else {
              // invalid file type
          else if (http_req_type == HTTP_POST) {
            // a POST HTTP request was received
          else {
            // unsupported HTTP request received
          req_line_1[0] = 0;
          req_line_index = 0;
          got_line_1 = false;
          // finished sending response and web page
          return 1;
        if (cl_char == '\n') {
        else if (cl_char != '\r') {
      }  // if (client.available())
      return 0;
    // extract file name from first line of HTTP request
    char GetRequestedHttpResource(char *req_line, char *file_name, char *file_type)
      char request_type = HTTP_invalid;  // 1 = GET, 2 = POST. 0 = invalid
      char *str_token;
      *file_type = FT_INVALID;
      str_token =  strtok(req_line, " ");    // get the request type
      if (strcmp(str_token, "GET") == 0) {
        request_type = HTTP_GET;
        str_token =  strtok(NULL, " ");      // get the file name
        if (strcmp(str_token, "/") == 0) {
          strcpy(file_name, "index.htm");
          *file_type = FT_HTML;
        else if (strlen(str_token) <= FILE_NAME_LEN) {
          // file name is within allowed length
          strcpy(file_name, str_token);
          // get the file extension
          str_token = strtok(str_token, ".");
          str_token = strtok(NULL, ".");
          if      (strcmp(str_token, "htm") == 0) {*file_type = 0;}
          else if (strcmp(str_token, "ico") == 0) {*file_type = 1;}
          else if (strcmp(str_token, "css") == 0) {*file_type = 2;}
          else if (strcmp(str_token, "js")  == 0) {*file_type = 3;}
          else if (strcmp(str_token, "jpg") == 0) {*file_type = 4;}
          else if (strcmp(str_token, "png") == 0) {*file_type = 5;}
          else if (strcmp(str_token, "gif") == 0) {*file_type = 6;}
          else if (strcmp(str_token, "txt") == 0) {*file_type = 7;}
          else {*file_type = 8;}
        else {
          // file name too long
      else if (strcmp(str_token, "POST") == 0) {
        request_type = HTTP_POST;
      return request_type;
    Can I say a big thank you for adapting this library for the T4.1, thanks.
  25. #50
    Aug 2017
    309
    @vjmuzik - I added the Ethernet kit to my T4.1's and tested with this library. All works well. Can you recommend a good FTP library to use. On my T3.6 I was using the Adafruit ESP8266 huzzah board with wifispi and wifiespi8266. Very slow transfer times. I was using both the arduino FTP Server library and FTP Client library trying to get a stable transfer. Not stable at all. Was using gFTP and FileZilla to transfer files. I have seen and used the tftp library with success but would like something more to what I was using before.
