Page 1 of 8 1 2 3 ... LastLast
Results 1 to 25 of 191
Thread: T4.1 Ethernet Library
    Apr 2017
    732
    Native Ethernet Library
    With the release of Teensy 4.1 underway I went ahead and made a library to convert existing projects using a Wiznet W5500 along with Ethernet.h to be able to make use of it's Native Ethernet. As long as your sketch doesn't make direct calls to w5100.h it will work right out of the box with no existing API changes at this time.
    To make use of the native ethernet you will have to download my fork of the FNET TCP/IP stack available at: https://github.com/vjmuzik/FNET
    You will also need the wrapper library to go along with it: https://github.com/vjmuzik/NativeEthernet
    This wrapper library does not currently support my USB Ethernet driver, that may change in the future.
    It's as simple as changing <Ethernet.h> to <NativeEthernet.h>
    If you have any questions or encounter any issues please post them here so they can be addressed or fixed.
    14,140
    Nice. Just ran "...\libraries\NativeEthernet\examples\UdpNtpClien t\UdpNtpClient.ino" and it works! { with my Beta T-4.1 and OSH type PJRC magjack - using a 30cm/12" ribbon }
    And it builds from editor with TSET CMDLine batch calling Arduino build without any issue.
    I printed the IP and I can ping it! For some reason Sometimes I have to repower the Teensy after upload? It hits setup() and prints - but nothing after with code edit below. Is that from interrupting a packet in process or something? Reset the ethernet chip in setup()? This showed before adding teensyMAC(mac);
      while (!Serial) {
        ; // wait for serial port to connect. Needed for native USB port only
      Serial.print("Ethernet connect ... \n");
      teensyMAC(mac);
      if (Ethernet.begin(mac) != 0) {
        IPAddress myIP = Ethernet.localIP();
        Serial.printf( "IP Address %u.%u.%u.%u\n", myIP[0], myIP[1], myIP[2], myIP[3] );
      else { // start Ethernet and UDP
        Serial.println("\nFailed to configure Ethernet using DHCP");
    I see it has a hardcoded MAC - need to find Teensy MAC. >> https://forum.pjrc.com/threads/57595...l=1#post221833
    That code - called as above : teensyMAC(mac);
    Uses this function with an #ifdef edited to compile from link:
    void teensyMAC(uint8_t *mac) {
      static char teensyMac[23];
      #if defined(HW_OCOTP_MAC1) && defined(HW_OCOTP_MAC0)
        Serial.println("using HW_OCOTP_MAC* - see https://forum.pjrc.com/threads/57595-Serial-amp-MAC-Address-Teensy-4-0");
        for(uint8_t by=0; by<2; by++) mac[by]=(HW_OCOTP_MAC1 >> ((1-by)*8)) & 0xFF;
        for(uint8_t by=0; by<4; by++) mac[by+2]=(HW_OCOTP_MAC0 >> ((3-by)*8)) & 0xFF;
        #define MAC_OK
      #else
        mac[0] = 0x04;
        mac[1] = 0xE9;
        mac[2] = 0xE5;
        uint32_t SN=0;
        __disable_irq();
        #if defined(HAS_KINETIS_FLASH_FTFA) || defined(HAS_KINETIS_FLASH_FTFL)
          Serial.println("using FTFL_FSTAT_FTFA - vis teensyID.h - see https://github.com/sstaub/TeensyID/blob/master/TeensyID.h");
          FTFL_FSTAT = FTFL_FSTAT_RDCOLERR | FTFL_FSTAT_ACCERR | FTFL_FSTAT_FPVIOL;
          FTFL_FCCOB0 = 0x41;
          FTFL_FCCOB1 = 15;
          FTFL_FSTAT = FTFL_FSTAT_CCIF;
          while (!(FTFL_FSTAT & FTFL_FSTAT_CCIF)) ; // wait
          SN = *(uint32_t *)&FTFL_FCCOB7;
          #define MAC_OK
        #elif defined(HAS_KINETIS_FLASH_FTFE)
          Serial.println("using FTFL_FSTAT_FTFE - vis teensyID.h - see https://github.com/sstaub/TeensyID/blob/master/TeensyID.h");
          kinetis_hsrun_disable();
          *(uint32_t *)&FTFL_FCCOB3 = 0x41070000;
          SN = *(uint32_t *)&FTFL_FCCOBB;
          kinetis_hsrun_enable();
          #define MAC_OK
        __enable_irq();
        for(uint8_t by=0; by<3; by++) mac[by+3]=(SN >> ((2-by)*8)) & 0xFF;
      #ifdef MAC_OK
        sprintf(teensyMac, "MAC: %02x:%02x:%02x:%02x:%02x:%02x", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
        Serial.println(teensyMac);
      #else
        Serial.println("ERROR: could not get MAC");
    An idea of code size now 71KB - might consider moving some startup or rare code as run from FLASHMEM?:
    FlexRAM section ITCM+DTCM = 512 KB
        Config : aaaaaabf
        ITCM :  71024 B	(72.25% of   96 KB)
        DTCM :  25280 B	( 5.93% of  416 KB)
        Available for Stack: 400704
    OCRAM: 512KB
        DMAMEM: 110784 B	(21.13% of  512 KB)
        Available for Heap: 413504 B	(78.87% of  512 KB)
    Flash:  83344 B	( 1.03% of 7936 KB)
    Apr 2017
    732
    Does it just print "Ethernet connect ..." and nothing else? If so, likely it's just DHCP taking longer to work, I haven't encountered this myself while testing, but you can verify this by using Wireshark when it happens and see if there is any activity.
    If it makes it all the way through setup and freezes then there may be a bug somewhere I didn't notice(as I write this I remember I forgot to make sure the DHCP timeout works and I see it doesn't).
    That's a good point, I'll see about this later once I know for certain everything works properly.
    Apr 2017
    732
    All the preloaded examples are just copied over from Ethernet.h so besides just changing the include name everything is the same. Also, I didn't know this existed to find the preloaded addresses, but it's definitely useful.
    14,140
    Quote Originally Posted by vjmuzik View Post
    Assumed that was the case with the examples. Meant to ask if they were going to be Teensy-fied? That change makes startup more telling that setup() is under way … default sample only prints after .begin() completes.
    I was going to simply complain about the mac - but recalled seeing something about it … did a search first and found that and AFAIK it is working as expected. Not sure where it should go - for NTP sample I dropped in the sketch - showed MAC and spew - then got another IP address
    Will this same code work on a T_3.6 with the PJRC ethernet board? I have one of those from Beta. Not sure if the MCU hardware is the same - expect the PHY chip is different - and wired differently. Of course the 3.6 costs more { before building the more elaborate breakout with PHY } and while it has more pins - many edge pins get used for ethernet - so it may be a wash - even if the bottom pads are all used. …. so probably not worth the effort to lose speed and memory - and no add on QSPI.
    Note: I have done upload some half dozen times with last edit and no hangs. Maybe that was when I swapped over to USBHost and back?
    MAC: 04:e9:e5:01:86:c6
    IP Address 192.168.0.169
    Seconds since Jan 1 1900 = 3798354340
    Unix time = 1589365540
    The UTC time is 10:25:40
    Seconds since Jan 1 1900 = 3798354351
    Unix time = 1589365551
    The UTC time is 10:25:51
    2,627
    Thanks for setting up separate thread. Here is my summary of T4.1 Ethernet testing that includes performance comparisons of NativeEthernet/FNET with lwIP and USB ethernet and 2016 T3.5/3.6 ethernet.
    Apr 2017
    732
    I don't have any defines setup in FNET for it to work right now, but it did natively support that processor, presumedly I would just have to make the same changes to that processor code that I did for the 4.1 for it to work. As you say though considering the price difference and the loss of many pins it's not worth it for anyone to really even consider using it.
    Apr 2017
    732
    New update that allows customization of buffers from the sketch without editing the library(though you still could if you wanted to), buffers are now allocated using new to allow this.
    This has a max number that is defined in FNET so if you need more sockets than the default 12 you have to edit the define FNET_CFG_SOCKET_MAX over there as well.
    To make use of this you just add the new functions before Ethernet.begin like so:
    Ethernet.setStackHeap(1024 * 128); //Set stack size to 128k
    Ethernet.setSocketSize(1024 * 4); //Set buffer size to 4k
    Ethernet.setSocketNum(6); //Change number of allowed sockets to 6
    Ethernet.begin(mac);
    I've only done minimal testing so if anything breaks let me know.
    2,627
    Nice! Works for me.
    thanks
    2,627
    FNET/NativeEthernet tftp server
    I cobbled together a tftp server (UDP) for the T4.1 that uses the onboard microSD and the SD lib to put and get files.
    https://github.com/manitou48/teensy4...ter/fnet_tftpd
    and using the optional 16MB external flash with SPIFFS
    https://github.com/manitou48/teensy4...t_tftpd_SPIFFS
    TODO: use SdFat-beta as I did with lwIP testing...
    Apr 2020
    Germany, NRW
    86
    Today i learned that. Very cool, will have a look.
    May 2020
    4
    I realized I never replied to this thread, despite writing out a whole post with the intent to. I just wanted to say thank you vjmuzik (and defragster!) your work made my transition so easy that I've been using it for nearly a month and I haven't had to think about it.
    I think that's a sure-fire sign of a job well done.
    Also, manitou, I haven't taken a look at your tftp server yet, but I love the idea of it and it's definitely on my big board of "do something fun with this" :]
    Edit to add: Oh, I wanted to add that I'm building via PlatformIO in vscode, pointing the lib_deps directly to your repo. My ribbon(5")/magjack is the ones Paul recommended. Everything has been working flawlessly out of the box.
    Hello!
    I'm in the process of creating an Art-Net pixel controller based on teensy 4.1.
    And I'm trying to use your NativeEthernet lib, but can't get past
    Serial.println("ETH conf OK");
    in my following code:
    #include <NativeEthernet.h>
    #include <NativeEthernetUdp.h>
    IPAddress ip(2, 0, 0, 1);
    unsigned int localPort = 8888;
    char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
    EthernetUDP Udp;
    static void teensyMAC(uint8_t *mac) {
      uint32_t m1 = HW_OCOTP_MAC1;
      uint32_t m2 = HW_OCOTP_MAC0;
      mac[0] = m1 >> 8;
      mac[1] = m1 >> 0;
      mac[2] = m2 >> 24;
      mac[3] = m2 >> 16;
      mac[4] = m2 >> 8;
      mac[5] = m2 >> 0;
      // Serial starting
      while(!Serial);
      delay(5000);
      Serial.println("Serial OK");
      // ethernet/UDP starting
      Ethernet.setStackHeap(1024 * 64);
      Ethernet.setSocketSize(1024 * 16);
      Ethernet.setSocketNum(1);
      uint8_t mac[6];
      teensyMAC(mac);
      Ethernet.begin(mac, ip);
      Serial.println("ETH begin");
      if (Ethernet.hardwareStatus() == EthernetNoHardware) {
        while (true) {
          Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
      if (Ethernet.linkStatus() == LinkOFF) {
        while (true) {
          Serial.println("Ethernet cable is not connected.");
      Serial.println("ETH OK");
      Serial.print("IP address: ");
      Serial.println(Ethernet.localIP());
      Udp.begin(localPort);
      int packetSize = Udp.parsePacket();
      if (packetSize) {
        Serial.print("Received packet of size ");
        Serial.println(packetSize);
        Serial.print("From ");
        IPAddress remote = Udp.remoteIP();
        for (int i=0; i < 4; i++) {
          Serial.print(remote[i], DEC);
          if (i < 3) {
            Serial.print(".");
        Serial.print(", port ");
        Serial.println(Udp.remotePort());
        // read the packet into packetBufffer
        Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
        Serial.println("Contents:");
        Serial.println(packetBuffer);
      delay(10);
    I'm using your latest lib on github: NativeEthernet and FNET.
    I tried on a brand new teensy 4.1 with nothing attached to it (e.g. no ethernet) and also with a teensy 4.1 on a custom PCB as show below, and the results are the same.
    Any idea ?
    Apr 2017
    732
    Have you tried using DHCP, there may be an IP conflict if it doesn’t get past the Ethernet.begin, I forgot to set that up so it makes sure it’s not using an address already in use. Also doing DHCP doesn’t use up any sockets so you don’t have to worry about that not working when you only want to use 1 socket.
    Do I need to have the ethernet circuitry and ethernet cabled for the `Ethernet.begin` to be successful ?
    I don't have any dhcp server since the network is only my computer (2.0.0.254/255.0.0.0) and the teensy (2.0.1.1) with a working switch.
    Ok so it's working now as in I can ping the board.
    I had to configure it like the following:
    IPAddress ip(2, 0, 1, 1);
    IPAddress gateway(2, 0, 0, 1);
    IPAddress subnet(255, 0, 0, 0);
      teensyMAC(mac);
      Ethernet.begin(mac, ip, gateway, gateway, subnet);
    Will let you know how it goes.
    And thanks for your quick reply, very appreciated :+1:
    Apr 2017
    732
    An Ethernet cable does have to be connected to something for it to get past that, I’ve been testing it directly connected to my laptop that’s been acting as a DHCP server so I haven’t tested without it. The problem was probably the IP address being x.x.x.1 since the first device would be the gateway, if you only supply the IP address the gateway is automatically assembled by using the first three bytes of the IP and setting the last byte to 1. So by giving it an IP of 2.0.0.1 it comes up with a gateway of 2.0.0.1 which of course would conflict with the IP. If you just changed the IP to 2.0.0.2 it should function correctly, I will make sure to put in a check for this so it won’t happen in the future.
    Jul 2018
    4
    vjmuzik, lots of thanks for your recommendation. i will try it to see how it works. may i ask you other questions in the meantime if you don't mind? thanks again
    Apr 2017
    732
    Feel free to ask any questions.
    Hello vjmuzik,
    Is it possible your lib is conflicting with this one: https://github.com/wramsdell/TriantaduoWS2811 ?
    I have all the Ethernet/Art-Net part ok, I also have some functional code with TriantaduoWS2811 alone.
    But when I plug both together, I still have artnet but I cannot light my leds?
    Any idea?
    Regards
    Apr 2017
    732
    To my knowledge it shouldn’t interfere with anything, the only resource I’m using that could potentially cause problems is an interval timer that polls the network stack every millisecond. But, I don’t believe that should be an issue for DMA or FLEXIO.
    Jul 2018
    4
    Quote Originally Posted by xavier.seingard View Post
    Hello vjmuzik,
    Is it possible your lib is conflicting with this one: https://github.com/wramsdell/TriantaduoWS2811https://delicerecipes.com ?
    Any idea?
    Regards
    found a solution? is quite strange that you don't get any issues when using them separately and when plug together they don't work. just interested...
    Ok so I had to move up the Triantaduo include before the Ethernet one and I can light my leds.
    Apr 2017
    732
    Small update:
    Cleanup and enhancements
    - Removed unused items that were no longer in use or not used at all
    - Offloaded DNS lookup to FNET methods so it no longer uses a socket from the wrapper library
    24,251
    Is NativeEthernet (and FNET) at a point where it can be included with a Teensyduino installer?
    I'm getting ready to package up 1.53-beta3....
