Page 8 of 9 FirstFirst ... 6 7 8 9 LastLast
Results 176 to 200 of 201
Thread: T4.1 Ethernet Library
  1. #176
    Feb 2021
    4
    Quote Originally Posted by SGPMao23 View Post
    When I send a html page which size is more than 2000 bytes, my Teensy 4.1 gets stuck. Reducing the page to below 2000 bytes work ok. I'm not sure if it because of the Native Ethernet library or coming from another part. Do you guys know if there is a buffer somewhere I can configure to have more than 2000 bytes?
    To store the html data, I'm using: const char* document = R"rawliteral(data ... data)rawliteral";
    I'm not sure if you solved this, and this may not be the answer - but have you tried calling setSocketSize? The default socket size appears to be 2KB.
    Sorry to post a reply so late - I'm actually waiting for my T4.1 to arrive so I can start playing with this library myself. Thanks @vjmuzik for creating it!
  2. #177
    Are there any plans to add Precision Time Protocol IEEE 1588-200X to the Lib ?
    My understanding is that T4 has hardware support for PTP.
  3. #178
    May 2018
    Land between two rivers
    45
    In the UdpNtpClient example "time.nist.gov" is used as the address. Often the resolving of the name fails. An alternative name that is more universal world wide is "pool.ntp.org". I almost never see a failure using it. Using the pool of NTP servers also spreads the load out much better. I also see round trip packet times that are often much less than half as long.
    const char timeServer[] = "pool.ntp.org"; // alternative to time.nist.gov NTP server
    This is how I rewrote the loop for getting the time when I was debugging what wasn't working. The amount of '-' printed gives a crude amount of time needed to get the timestamp without setting up a proper timer. To find the reason why some name resolutions fail, it will take a deeper dive into the library to see if all possible ARP packets are being handled, and I don't have the time. Using nslookup utility under Linux I get a combined IP4/IP6 address returned for time.nist.gov and it changes each time. For pool.ntp.org I get a 4 IP4 address set for pool.ntp.org that is the same except for the order. I suspect that IP4/IP6 is tripping up the library name reolutioncode.
      int x = 500;
      sendNTPpacket(timeServer); // send an NTP packet to a time server
      while(x-- >= 0) {
        // wait to see if a reply is available
        delay(2);
        if (Udp.parsePacket()) {
          Serial.println('.');
          //Serial.println("packet received");
          x = -1; // kicks us out of the while loop
          // We've received a packet, read the data from it
          Udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
          // the timestamp starts at byte 40 of the received packet and is four bytes,
          // or two words, long. First, extract the two words:
          unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
          unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
          // combine the four bytes (two words) into a long integer
          // this is NTP time (seconds since Jan 1 1900):
          unsigned long secsSince1900 = highWord << 16 | lowWord;
          Serial.print("Seconds since Jan 1 1900 = ");
          Serial.println(secsSince1900);
          // now convert NTP time into everyday time:
          Serial.print("Unix time = ");
          // Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
          const unsigned long seventyYears = 2208988800UL;
          // subtract seventy years:
          unsigned long epoch = secsSince1900 - seventyYears;
          // print Unix time:
          Serial.println(epoch);
          // print the hour, minute and second:
          Serial.print("The UTC time is ");       // UTC is the time at Greenwich Meridian (GMT)
          Serial.print((epoch  % 86400L) / 3600); // print the hour (86400 equals secs per day)
          Serial.print(':');
          if (((epoch % 3600) / 60) < 10) {
            // In the first 10 minutes of each hour, we'll want a leading '0'
            Serial.print('0');
          Serial.print((epoch  % 3600) / 60); // print the minute (3600 equals secs per minute)
          Serial.print(':');
          if ((epoch % 60) < 10) {
            // In the first 10 seconds of each minute, we'll want a leading '0'
            Serial.print('0');
          Serial.println(epoch % 60); // print the second
          Serial.print('-');
      // wait before asking for the time again
      Serial.println("delay 120 seconds");
      delay(120000);
      Ethernet.maintain();
  4. #179
    T4.1 Ethernet file server
    Hy,
    I'm currently making an CANbus logger that is attached to ethernet. The goal is to log the canmessages to the SD card and be able to download the logfile from the teensy over ethernet.
    However i'm having some troubles with the download of the files. i'm able to get the root folder displayed and download files from it. However, at around the 6-10th refresh of the page, i suddenly get a file = 0 and am not able to display the page, even tho the request is the same. After that, it keeps giving me the File Not Found Error.-
    Seriallog:
    boot
    slowblink: 1 ,fastblink: 0
    FIFO Enabled --> Interrupt Enabled
    	FIFO Filters in use: 8
    	Remaining Mailboxes: 8
    		MB8 code: TX_INACTIVE
    		MB9 code: TX_INACTIVE
    		MB10 code: TX_INACTIVE
    		MB11 code: TX_INACTIVE
    		MB12 code: TX_INACTIVE
    		MB13 code: TX_INACTIVE
    		MB14 code: TX_INACTIVE
    		MB15 code: TX_INACTIVE
    Canbus booted
    SD card initialized
    SD card time synced
    210402.csv
    server is at 192.168.1.177
    Starting logging
    12 51 SD card  02 04 2021 ,incomming= 1, TS=92 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 01 02 04 2021 ,incomming= 1, TS=13958 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 01 02 04 2021 ,incomming= 1, TS=1857 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 02 02 04 2021 ,incomming= 1, TS=55292 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 03 02 04 2021 ,incomming= 1, TS=43191 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 04 02 04 2021 ,incomming= 1, TS=31089 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 05 02 04 2021 ,incomming= 1, TS=18988 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    new client
    GET / HTTP/1.1
    Web request for:
    Main site
    File Opened!
    is a directory
    client disconnected
    12 51 06 02 04 2021 ,incomming= 1, TS=6887 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 07 02 04 2021 ,incomming= 1, TS=60322 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    new client
    GET / HTTP/1.1
    Web request for:
    Main site
    File Opened!
    is a directory
    client disconnected
    12 51 08 02 04 2021 ,incomming= 1, TS=48221 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 09 02 04 2021 ,incomming= 1, TS=36119 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    new client
    GET / HTTP/1.1
    Web request for:
    Main site
    File Opened!
    is a directory
    client disconnected
    12 51 10 02 04 2021 ,incomming= 1, TS=24018 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 11 02 04 2021 ,incomming= 1, TS=11917 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    new client
    GET / HTTP/1.1
    Web request for:
    Main site
    File Opened!
    is a directory
    client disconnected
    12 51 12 02 04 2021 ,incomming= 1, TS=65352 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 13 02 04 2021 ,incomming= 1, TS=53251 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 14 02 04 2021 ,incomming= 1, TS=41149 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    new client
    GET / HTTP/1.1
    Web request for:
    Main site
    File Opened!
    is a directory
    client disconnected
    12 51 15 02 04 2021 ,incomming= 1, TS=29048 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 16 02 04 2021 ,incomming= 1, TS=16947 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    new client
    GET / HTTP/1.1
    Web request for:
    Main site
    File Opened!
    is a directory
    client disconnected
    12 51 27 02 04 2021 ,incomming= 1, TS=4845 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 27 02 04 2021 ,incomming= 1, TS=34078 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 27 02 04 2021 ,incomming= 1, TS=21977 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 27 02 04 2021 ,incomming= 1, TS=9876 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 28 02 04 2021 ,incomming= 1, TS=2804 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 29 02 04 2021 ,incomming= 1, TS=56239 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 30 02 04 2021 ,incomming= 1, TS=44138 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    12 51 31 02 04 2021 ,incomming= 1, TS=32037 ,ID=100 ,Length=8 ,data=A 14 0 64 80 40 20 10
    new client
    GET / HTTP/1.1
    Web request for:
    Main site
    client disconnected
    partial arduino code:
    void ethernet_client(){
        // listen for incoming clients
        if(!client) client = server.available();
        if (client){
          #ifdef DEBUG
          Serial.println("new client");
          // reset the input buffer
            char clientline[BUFSIZ];
            int index = 0;
          noInterrupts();
          while (client.connected()) {
            if (client.available()) {
              char c = client.read();
              // If it isn't a new line, add the character to the buffer
              if (c != '\n' && c != '\r') {
                clientline[index] = c;
                index++;
                // are we too big for the buffer? start tossing out data
                if (index >= BUFSIZ)
                  index = BUFSIZ -1;
                // continue to read more data!
                continue;
              // got a \n or \r new line, which means the string is done
              clientline[index] = 0;
              #ifdef DEBUG
              // Print it out for debugging
              Serial.println(clientline);
              // Look for substring such as a request to get the file
              if (strstr(clientline, "GET /") != 0) {
                // this time no space after the /, so a sub-file!
                char *filename;
                filename = clientline + 5; // look after the "GET /" (5 chars)  *******
                // a little trick, look for the " HTTP/1.1" string and
                // turn the first character of the substring into a 0 to clear it out.
                (strstr(clientline, " HTTP"))[0] = 0;
                if(filename[strlen(filename)-1] == '/') {  // Trim a directory filename
                  filename[strlen(filename)-1] = 0;        //  as Open throws error with trailing /
                #ifdef DEBUG
                Serial.print(F("Web request for: ")); Serial.println(filename);  // print the file we want
                if(true) // file request
                  #ifdef DEBUG
                  Serial.println("Main site");
                  File file = SD.open(filename, O_READ);
                  if ( file == 0 ) {  // Opening the file with return code of 0 is an error in SDFile.open
                    client.println("HTTP/1.1 404 Not Found");
                    client.println("Content-Type: text/html");
                    client.println();
                    client.println("<h2>File Not Found!</h2>");
                    client.println("<br><h3>Couldn't open the File!</h3>");
                  #ifdef DEBUG
                  Serial.println("File Opened!");
                  client.println("HTTP/1.1 200 OK");
                  if (file.isDirectory()) {
                    Serial.println("is a directory");
                    client.println("Connection: close");  // the connection will be closed after completion of the response
                    client.println();
                    client.println("<!DOCTYPE HTML>");
                    client.println("<html>");
                    client.println();
                    client.print("<h2>Files in /");
                    client.print(filename);
                    client.println(":</h2>");
                    //File entry = file.openNextFile(); // clear the SYSTEM~1/ folder
                    while (true) { // write out all the files and end while
                      // done if past last used entry
                      if (! entry) {
                        // no more files
                      // print any indent spaces
                      client.print("<li><a href=\"");
                      client.print(entry.name());
                      if (entry.isDirectory()) {
                        client.println("/");
                      client.print("\">");
                      // print file name with possible blank fill
                      client.print("</a>");
                      client.println("</li>");
                      entry.close();
                    client.println();
                    client.println("</html>");
                    file.close();
                  else { // Any non-directory clicked, server will send file to client for download
                    client.println("Content-Type: application/octet-stream");
                    client.println();
                    char file_buffer[ETH_BUFFER_SIZE];
                    int avail;
                    while (avail = file.available())  {
                      int to_read = min(avail, ETH_BUFFER_SIZE);
                      if (to_read != file.read(file_buffer, to_read)) {
                      client.write(file_buffer, to_read);
                    file.close();
              else { // everything else is a 404
                client.println();
                client.println("<h2>Error 404: Page not found!</h2>");
          interrupts();
          // give the web browser time to receive the data
          delay(1);
          // close the connection:
          client.stop();
          #ifdef DEBUG
          Serial.println("client disconnected");
    full code: canDBC.ino
  5. #180
    Feb 2020
    100
    Dropping UDP packets after bootup?
    When I boot up, I'm noticing that sent UDP packets are dropped for initial ~30 seconds after bootup. Is that normal?
    If I use DHCP, no dropped packets, but there is a 60 sec DHCP time.
    Static IPs, with local NTP server on a Raspberry Pi. Wireshark on port mirrored switch confirms no packets being sent. Sending every 5 sec.
    MAC: 04:e9:e5:0c:d2:ec
    Configured Ethernet Static IP
    Starting UDP
    Requesting NTP packet
    Waiting for NTP Response
    Seconds since Jan 1 1900 = 3826921298
    Unix time = 1617932498
    The UTC time is 1:41:38
    Here is my code
     Udp NTP Client
     Get the time from a Network Time Protocol (NTP) time server
     Demonstrates use of UDP sendPacket and ReceivePacket
     For more on NTP time servers and the messages needed to communicate with them,
     see http://en.wikipedia.org/wiki/Network_Time_Protocol
     created 4 Sep 2010
     by Michael Margolis
     modified 9 Apr 2012
     by Tom Igoe
     modified 02 Sept 2015
     by Arturo Guadalupi
     This code is in the public domain.
    #include <NativeEthernet.h>
    #include <NativeEthernetUdp.h>
    // Enter a MAC address for your controller below.
    // Newer Ethernet shields have a MAC address printed on a sticker on the shield
    byte mac[] = {
      0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
    unsigned int localPort = 8888;       // local port to listen for UDP packets
    const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
    byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
    // A UDP instance to let us send and receive packets over UDP
    EthernetUDP Udp;
    // send an NTP request to the time server at the given address
    void sendNTPpacket(IPAddress ntpServer) {
      // set all bytes in the buffer to 0
      memset(packetBuffer, 0, NTP_PACKET_SIZE);
      // Initialize values needed to form NTP request
      // (see URL above for details on the packets)
      packetBuffer[0] = 0b11100011;   // LI, Version, Mode
      packetBuffer[1] = 0;     // Stratum, or type of clock
      packetBuffer[2] = 6;     // Polling Interval
      packetBuffer[3] = 0xEC;  // Peer Clock Precision
      // 8 bytes of zero for Root Delay & Root Dispersion
      packetBuffer[12]  = 49;
      packetBuffer[13]  = 0x4E;
      packetBuffer[14]  = 49;
      packetBuffer[15]  = 52;
      // all NTP fields have been given values, now
      // you can send a packet requesting a timestamp:
      Udp.beginPacket(ntpServer, 123); // NTP requests are to port 123
      Udp.write(packetBuffer, NTP_PACKET_SIZE);
      Udp.endPacket();
      void teensyMAC(uint8_t *mac) {
        for(uint8_t by=0; by<2; by++) mac[by]=(HW_OCOTP_MAC1 >> ((1-by)*8)) & 0xFF;
        for(uint8_t by=0; by<4; by++) mac[by+2]=(HW_OCOTP_MAC0 >> ((3-by)*8)) & 0xFF;
        Serial.printf("MAC: %02x:%02x:%02x:%02x:%02x:%02x\n", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
      // You can use Ethernet.init(pin) to configure the CS pin
      //Ethernet.init(10);  // Most Arduino shields
      //Ethernet.init(5);   // MKR ETH shield
      //Ethernet.init(0);   // Teensy 2.0
      //Ethernet.init(20);  // Teensy++ 2.0
      //Ethernet.init(15);  // ESP8266 with Adafruit Featherwing Ethernet
      //Ethernet.init(33);  // ESP32 with Adafruit Featherwing Ethernet
      while (!Serial) {
        ; // wait for serial port to connect. Needed for native USB port only
      teensyMAC(mac);
      IPAddress ip(192,168,1,17);
      IPAddress gateway(192, 168, 1, 1);
      IPAddress dns(192, 168, 1, 1);
      IPAddress subnet(255, 255, 0, 0);
      // start Ethernet and UDP
      Ethernet.begin(mac,ip, dns, gateway, subnet);
      Serial.println("Configured Ethernet Static IP");
      if (Ethernet.hardwareStatus() == EthernetNoHardware) {
        Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
      } else if (Ethernet.linkStatus() == LinkOFF) {
        Serial.println("Ethernet cable is not connected.");
      Serial.println("Starting UDP");
      Udp.begin(localPort);
      IPAddress ntpServer(192,168,1,9);
      Serial.println("Requesting NTP packet");
      sendNTPpacket(ntpServer); // send an NTP packet to a time server
      Serial.println("Waiting for NTP Response");
        // print Unix time:
        Serial.print(':');
          Serial.print('0');
        Serial.print(':');
          Serial.print('0');
      // wait ten seconds before asking for the time again
      delay(5000);
  6. #181
    Apr 2021
    2
    Hello everyone,
    just bought and started using a Tennsy 4.1 with the NativeEthernet library and got into this issue: The Teensy freezes when I try to use Ethernet.begin(mac); or Ethernet.begin(mac, ip); when the cable is not connected on powerup. It is not my code, since the issue persists even when using the LinkStatus example from the Ethernet library. There I just changed it to NativeEthernet.h and added the mac and ip byte arrays...
    If I start the example with the cable connected, the example works fine, showing ON/OFF if I connect/disconnect the cable, but freezes with the cable disconnected on powerup...
    Am I missing something? For my program I want to be able to detect if the cable is connected on startup and act accordingly...
  7. #182
    May 2019
    133
    I thought that freezing without a Ethernet cable connected is a known issue.
  8. #183
    Apr 2021
    2
    Quote Originally Posted by tschrama View Post
    Oh, if that is the case, then my Google-fu must have been weak...
    Found it
  9. #184
    Hy,
    I'm making a web server and was wondering if i could define an url so that i can connect using an url instead of an ip adress. The reason is, the server needs to run usign DHCP and i need a way to reliably connect to the server even if it's IP adress is changed.
  10. #185
    Apr 2021
    Finland
    1
    I moved to 4.1 and setup was easy and it seems work just fine. But when trying to use it with fast data collection with delayNanoseconds or with interrupts I can't keep stable acquisition rate. For example sometimes delayNanoseconds is just fine but sometimes it's almost twice long than previous pause , same happens when trying to do that with interrupts . I tried to disable interrupts before my collection cycle but that doesnt help.
    What would be the best way to "pause" the ethernet handling during other critical tasks ? Or is there a better option to try fixing that problem ?
  11. #186
    Feb 2017
    Chicago, IL
    36
    Quote Originally Posted by vjmuzik View Post
    Native Ethernet Update:
    Add client-side TLS support
    -Add WebClientRepeatingTLS example
    -Add client.close() to support proper HTTP close before disconnecting
    -Add functions to set client and server certificates/keys (if needed)
    Thanks vjmuzik for this library! I have been using it successfully to retrieve weather data from Open Weather. I wanted to expand to get additional information from the National Weather Service API at https://api.weather.gov/
    I ran your TLS example that connects to pjrc.com successfully:
    https://github.com/vjmuzik/NativeEth...peatingTLS.ino
    but when I replace the two instances of "pjrc.com" with "api.weather.gov", client.connect fails to connect. The base URL returns data when accessed via Chrome and CURL from my desktop. I'm a little at a loss as to what additional configuration, settings, etc. are needed to connect here; I looked through the forum and Google to see if I could stumble on anything related to your library, FNET, Certs, etc. but ended up more confused than before. Any pointers would be appreciated.
  12. #187
    Feb 2017
    Chicago, IL
    36
    Update: it is dns.getHostByName(host, remote_addr) in the client.connect() method that fails to resolve the address for the server. "api.weather.gov" is an alias (CNAME) and it appears the dnsClient cannot resolve aliases.
  13. #188
    146
    Teensy Eithernet
    Thanks for the great work.
    I have never work with Ethernet with a micro before so I am just fumbling around.
    I developed a CAN BOB for the 4.1 which included Ethernet.
    I tried the Link example but it says there was no connection even though the cable was connected.
    But when I ran the DhcpAddressPrinter.ino and connected to a router I was served and IP and it was printed out. After that...nothing happened. No more messages. I this correct?
    I added an IP recheck at the below the case statement and no issue just kept printing out the same IP so I am assuming the PCB design is correct? Green light is blinking so I am assuming there is data going back and forth?
    Just trying to figure out an easy way to make sure my PCB design is correct.
    Bruce
  14. #189
    Apr 2021
    4
    I have a Teensy 4.1 with NativeEthernet and use it to send data to a pi.
    When the pi is online it works great, but when the pi is down the Teensy freeze and I need to restart the teensy.
    Does anyone have the same problems, or any idea what the problem is?
    I use Arduino 1.8.13 / Teensyduino 1.54-beta9.
    EthernetClient pyClient;
    void sendPy(String send_string)
      pyClient.setConnectionTimeout(50);
      if (pyClient.connect(pyIP, 8099)) <-- here the teensy freeze
        pyClient.print(send_string);
        Serial.println("Connection failed");
      pyClient.stop();
  15. #190
    Jun 2018
    Northeast USA
    70
    Hello All,
    I've just got my first Teensy 4.1 here with the PJRC magjack kit. updated Teensyduino to 1.54 Beta #9, and have compiled the WebServer example. But.....I get a
    message.
    My guess is the Ethernet.init call needs to be made. Is this a pin number you pass to Ethernet.init?
    Thank You,
    John
    p.s. the memory usage message for FLASH, RAM1, and RAM2 is cool. Thank You Paul & Co.
  16. #191
    Member KD0RC's Avatar
    May 2019
    Colorado, USA
    81
    The library that you need is:
    #include "NativeEthernet.h"
    I don't think you need the init. Here is a chunk of what I do:
    In setup(), I call getIpAddress. addr is a String variable and contains the IP address once it si obtained from DHCP.
    void getIpAddress()
      // start the Ethernet connection:
      Serial.println("=== Waiting for IP address");
      teensyMAC(mac); // Get MAC address from Teensy
      TimeIt = millis();
      while (Ethernet.begin(mac) == 0)
        if(millis() - TimeIt > 10000)  // Ten seconds to get a DHCP served address
          Serial.println("Failed to configure Ethernet using DHCP");
          getFixedIpAddress();
      addr=String(Ethernet.localIP()[0]) + "." +
           String(Ethernet.localIP()[1]) + "." +
           String(Ethernet.localIP()[2]) + "." +
           String(Ethernet.localIP()[3]);
      Serial.print("IP address is: "); Serial.println(Ethernet.localIP());
    /*********************** getFixedIpAddress *********************/
    void getFixedIpAddress()
      IPAddress ip(169, 254, 5, 25);
      Serial.println("=== Setting fixed IP address");
    } // end getFixedIpAddress
    /*********************** teensyMAC *********************/
    I hope this helps.
    Len
    EDIT: Sorry, forgot:
    definition for mac: byte mac[6];
  17. #192
    Jan 2020
    Toronto, Canada
    72
    Just created a PR Fix the DNS bug #21 for NativeEthernet library to fix the DNS issue when the host is actually an IP Address.
    Check the issue Socket.io client on Teensy Native Ethernet not working on Websockets_Generic #12
  18. #193
    Oct 2020
    4
    i am not shure if i am right on this place, but does anyone have experiance with the https://github.com/gallegojm/Arduino-Ftp-Server on Teensy 4.1 ?
    I want to change the files on my SDKard (Webserver) over ftp. I am using SDFat 2.02 and the last Native Ethernet lib.
    I don't think there is an Problem with the nativeethernetlib, but i can't get it work with any of the supportet ftpclients.
    My tests are with the FtpServerSdFat2.ino from the exaples, and i can't transver files from or to the SDCard.
    But first i want to check if it is posible to use that server on T4.1 ?
    tanks
    Jake
  19. #194
    Probably dumb question but I'm going crazy trying to make my Teensy 3.6 project run with Teensy 4.1 and native ethernet.
    Is the Ethernet.begin(mac, IP, Gateway, netmask) call supported within NativeEthernet?
    My code:
     Ethernet.begin(macArray, currentSettings.srcIP, Dns, currentSettings.gateway, currentSettings.subnet);    //Initializes the ethernet library and network settings.
        OK = Udp.begin(currentSettings.srcPort);         //Initializes the ethernet UDP library and network settings.
        if(OK == 0){
          Serial.println("UDP Inizialization Error");
        else{
          DEBUG_PRINTLN("Ethernet Started");
    Seems to struggle to send any ethernet messages and if I try
    I always have link off even if the cable is connected and the ethernet connector led is on.
    If I try
        //Ethernet.begin(macArray, currentSettings.srcIP, Dns, currentSettings.gateway, currentSettings.subnet);    //Initializes the ethernet library and network settings.
        if (Ethernet.begin(macArray) == 0) {
        if(OK == 0){
        else{
    Then it works!
    Running latest arduino and teensyduino (1.54)
    Side question, the standard Ethernet.begin(mac) returns a int so you can check initialization, but if try the same with my ethernet call I get an error because the function returns void, is that true I can't check status of Ethernet.begin if I send all the parameters and not only mac address?
  20. #195
    Quote Originally Posted by lorenzofattori View Post
    My code:
        if(OK == 0){
        else{
    If I try
        if(OK == 0){
        else{
    Then it works!
    Please ignore the above, today for some reason it works. I will investigate further.
    I also found the answer to the side question by digging in the thread.
  21. #196
    Feb 2020
    100
    I have a TCP server, stays open as it forms a serial data bridge with packets going back & forth (4-17 bytes at a time). Nothing incredibly fast, a few packets a second, but I keep getting this error, and the teensy is locked up for seconds at a time.
    No data available, closing socket
    There is data available, and I'd like to keep the socket open. Any ideas on what causes this and where I should be looking?
    EDIT: I replaced server.available with server.accept, seems to not cause the above error...
    if (server.available() && !tcpConnected){
    with
          client = server.accept();
    But, eventually get a streaming set of errors, like below.
    Socket Event Err: -20
    Socket Event Err: -6
  22. #197
    Apr 2017
    822
    I feel your pain on this, unfortunately itís due to a bug in FNET causing the socket to lose its data thus resulting in this error. Iíve recently rewritten NativeEthernet to make it less error prone and overall by itself itís way more rock solid than the current version. Doubly unfortunate it seems that FNET does not want to cooperate with me at all and eventually it will lock up the main loop of the Teensy without reason.
    Personally Iím not happy with FNET currently because of this, if you can get QNEthernet to work for you I would recommend switching to that. I havenít tested it myself but the underlying TCP/IP stack shouldnít have these issues and you shouldnít even notice a difference. Of course me being me I donít particularly feel like LWIP or FNET will completely suit my needs at this point so my only option is to make my own stack which will take some time to get done. Iíve already started on this and know what itís going to take to get it to where Iím completely happy with it
  23. #198
    Feb 2020
    100
    Thanks vjmuzik, for all your work in this library. Too bad the FNET is such a pain.
    I'm trying QNEthernet now.
  24. #199
    Quote Originally Posted by TeensyWolf View Post
    Seconding that thanks, @vjmuzik. It will be good to get more people testing QNEthernet. It seems like LWIP may be a better bet than FNET as a foundation, and it seems to have broader application and more active development.
  25. #200
    Apr 2017
    822
    It appears the freezing problem happens as a result of the IntervalTimer interrupt which I am honestly surprised about because FNET was designed to run from an interrupt when used without an RTOS. Despite it being an easy fix for those who want to continue using this library it really should be no problem for everyone to move to QNEthernet since it has the same API and better underlying code than the currently released version of NativeEthernet. I'll still be making my own stack despite this because there are things I want to do differently which is a lot easier than trying to repurpose one of the already existing libraries since they each have their own thing going on.
