Results 1 to 1 of 1
Thread: Audio System Design Tool for Teensy Audio Library GUI [BUG]
    Apr 2020
    DFW area in Texas
    262
    When using filters, if/when the low-pass output (EDIT: narrowed it down specifically to the low-pass output) from a filter remains unconnected (i.e. not connected to another device), when you take the text exported from the GUI & try to import it back into the GUI, an error ("wires[w2] is null") is reported and any patch cords after that error are not restored.
    See the following post for a specific example which demonstrates the problem, as well as a suggested workaround:
    https://forum.pjrc.com/threads/60859...l=1#post239080
    Mark J Culross
    KD5RXT
    Note: All of this was done using the online Audio System Design Tool for Teensy Audio Library GUI, so nothing here is dependent upon Teensy version, Teensyduino version, or Arduino GUI version. However, to be exact, I was using Firefox 76.0.1 (64-bit) under Windows 10 Pro version 1909.
    Last edited by kd5rxt-mark; 05-13-2020 at 04:08 PM. Reason: clarification: unconnected low-pass output induces problem
