Page 3 of 3 FirstFirst 1 2 3
Results 51 to 57 of 57
Thread: Web site could use a few updates :)
  1. #51
    12,341
    p#32 - Windows Perf Issues? Without a specific case - and not knowing a single cause ... perhaps link the doc pjrc.com/teensy/td_download.html#antivirus_performance_issue to the posts here on this thread in case they lead to a solution
  2. #52
    22,654
    Added under "Other Libraries".
    Quote Originally Posted by boxxofrobots View Post
    When will audioEffectRectifier be added to the ASD tool?
    Added some time ago...
    https://www.pjrc.com/teensy/gui/?inf...ffectRectifier
    Quote Originally Posted by kd5rxt-mark View Post
    I've made some preliminary screen captures from Windows Defender as requested.
    I've put these instructions and 6 screenshots on the download page.
    https://www.pjrc.com/teensy/td_downl...formance_issue
    Thanks for taking the time to make these screenshots! I really appreciate help with Windows stuff, as I mostly use Linux and occasionally Macintosh.
    Just to be safe, it would probably be best to add both methods/changes to the webpage !!
    I'd be happy to add this too, but it needs some editing....
    Also related: The USB Host adapter cable: https://www.pjrc.com/store/cable_usb_host_t36.html
    Should be updated to say that this works on T4.1 as well.
    Updated to state Teensy 4.1 compatibility, and explain bottom side pads on Teensy 4.0.
  3. #53
    22,654
    @Degragster - Any chance I can talk you into re-writing the guidance in msg #24 in a step-by-step style?
    I want to put this on the download page. But the conversational style of msg #24 isn't a good fit for the web page. It really needs a brief and clear description of why to use this approach rather than Mark's 8-step process, and then a set of specific steps to follow to accomplish it.
    Remember, I don't use Windows. I'm really looking for text & images to copy verbatim into the web page, so I don't mess up some subtle but important Windows detail.
  4. #54
    22,654
    Fixed
    T4 product page on memory usage: https://www.pjrc.com/store/teensy40.html
    Fixed FLASHMEM for code usage, added EXTMEM.
    And wish the T4.1 page would refer users to the T4 page for memory stuff or a copy of it also showing external memory...
    Added a link under "Memory Expansion".
    Eventually I want to move that memory layout stuff to a dedicated page and expand it with examples. But hopefully this helps until I can put more time into the website.
  5. #55
    22,654
    Quote Originally Posted by embedded-creations View Post
    https://www.pjrc.com/teensy/td_libs_OctoWS2811.html
    No mention of Teensy 4: "OctoWS2811 requires the DMA (Direct Memory Access) engine which is available only in Teensy LC & 3.x."
    Updated, now says "Teensy LC & 3.x & 4.x".
    Also, it appears from skimming your OctoWS2811 Teensy 4 code and reading between the lines on some forum posts you made that OctoWS2811 running on the Teensy 4 can drive more than 8 outputs, but there's no documentation to that effect.
    Under "Hardware Requirements" the page does say:
    Teensy 4.0 and Teensy 4.1 can use any group of pins, even groups smaller or larger than 8 pins! In Arduino, open File > Examples > OctoWS2811 > Teensy4_PinList for details. If a custom pin list is not specified, the same group of 8 pins as Teensy 3.x will be used by default.
    I've added "Teensy 4.x boards support use of any set of pins, not limited to only 8 fixed pins. See the Teensy4_PinList example for details." near the top of the page to hopefully make this more visible.
  6. #56
    2,750
    on https://www.pjrc.com/store/teensy41.html
    in
    "Teensy 4.0 can be programmed using the Arduino IDE with Teensyduino add-on."
    change 4.0 to 4.1
  7. #57
    22,654
    change 4.0 to 4.1
    Fixed it just now
