Results 1 to 13 of 13
Thread: Web site could use a few updates :)
    Oct 2015
    Roma (IT, EU)
    336
    Wandering around PJRC website, there are a few pages which would need updating.
    I know Paul is so much busy, but at least let's keep track:
    https://www.pjrc.com/teensy/
    Pictures: Teensies 4.x are missing
    "Key features" table: even 3.2, 3.5 and 3.6 are missing
    I would also remove references to 3.1
    https://www.pjrc.com/teensy/techspecs.html
    Missing 4.x
    Title is wrong: "Teensy LC (Low Cost)"
    "Hardware" tree-menu on the left column misses 3.5, 3.6, 4.x
    Oct 2015
    Roma (IT, EU)
    336
    From Frank B:
    https://www.pjrc.com/store/
    4.x missing
    Teensyduino install instructions donít explain the latest method of bundling Arduino with Teensyduino (for Mac only?) and cause confusion
    No mention of Teensy 4 support in IntervalTimer https://www.pjrc.com/teensy/td_timin...rvalTimer.html
    11,806
    Cool update here included T_4.x's !!! - but change to T_3.6 looks like copy paste error?? : pjrc.com/store/
    Teensy 4.1 – Teensy 4.1 with Pins – Extreme 600 MHz Speed, with USB Host, SD Card, Memory Expansion
    Teensy 4.0 – Teensy 4.0 with Pins – Extreme 600 MHz Speed
    Teensy 3.6 – Teensy 3.6 with Pins – Fastest Teensy 3.x, with USB Host, Hi-Res Analog Inputs and 1 Analog Output
    Teensy 3.5 – Teensy 3.5 with Pins – Fastest 5V Tolerant Teensy
    Teensy 3.2 – Teensy 3.2 with Pins – Powerful in Small Size, Hi-Res Analog Inputs and 1 Analog Output
    Teensy LC – Teensy LC with Pins – Lowest Cost
    Should that be:
    Teensy 3.6 – Teensy 3.6 with Pins – Fastest Teensy 3.x, with USB Host, Hi-Res Analog Inputs and 2 Analog Outputs
    Teensy 3.5 – Teensy 3.5 with Pins – Fastest 5V Tolerant Teensy, Hi-Res Analog Inputs and 2 Analog Outputs
    maybe even:
    Teensy 4.1 – Teensy 4.1 with Pins – Extreme 600 MHz Speed, with USB Host, SD Card socket and pads for Memory Expansion
    Teensy 4.0 – Teensy 4.0 with Pins – Extreme 600 MHz Speed, with pads for USB Host, SD Card
    Germany NRW
    6,910
    "Extreme" - what will be the next (i.mx.rt 1070)
    Improbability Drive?
    ...it will be fun
    Don't panic.
    22,111
    Quote Originally Posted by XFer View Post
    4.x missing
    Added a few days ago, and also a couple weeks ago but then accidentally reverted to the old copy.
    Quote Originally Posted by embedded-creations View Post
    Fixed
    Fixed
    22,111
    Teensyduino install instructions don’t explain the latest method of bundling Arduino with Teensyduino (for Mac only?) and cause confusion
    I've added a "Install Step 1: (Macintosh 10.10-10.15 only) Complete Software" to that page.
    In the future I'm planning to move this to a top-level "Downloads" page, where we'll offer a complete ready-to-run copy for all operating systems, and the installer for all of them too (except Catalina of course), and probably a 3rd package for "stand alone" use with Arduino-specific stuff.
    In the meantime, these OS-specific install steps are kind of awkward, but hopefully they get the needed info to people?
    If you follow the steps in order, without reading ahead, "Install Step 1" has you download Arduino which is useless if you're using Macintosh 10.10-10.15. Maybe change the first step to "Install Step 1: (skip for Macintosh 10.10-10.15)"?
    I don’t know what topic to write ... Thanks for the forum. I am new, but already found a lot of useful information for myself!
    Nov 2019
    13
    https://www.pjrc.com/teensy/techspecs.html is missing the specs for Teensy 4.0 and Teensy 4.1.
    I'm wondering whether I could do without an external transistor array to drive up to eight 5 mA optocouplers.
    11,806
    The reference page link is hard to get to appear on the left frame - finally top clicked TEENSY and then it was there - would be nice to have it when viewing the store/device info: pjrc.com/teensy/pinout.html
    > schematics and manuals and other ref info not easy to find in 'Products' section.
    Dimensions are missing for new boards:
    Dimensions of the T_4.0 should match the T_3.2 shown here : https://pjrc.com/teensy/dimensions.html
    > That page doesn't include the T_4.1 or T_3.6 which add 10 pins - so should be one inch longer and still breadboard friendly
    > all edge pins are 0.10" for common spacing: 14 pins x 7 pins or 24 pins by 7 pins for the extended boards
    Interrupts page seems out of date and non-ARM helpful? : pjrc.com/teensy/interrupts.html
    https://www.pjrc.com/store/octo28_adaptor.html
    "Possible use of APA102" section is out of date, referring to Teensy 3.x pins only, and a broken G+ link. The FastLED G+ group was captured on another forum, and I found a link to the page:
    https://forum.makerforums.info/t/so-...02-144-m/58974
    BTW if you want to do this for another FastLED G+ broken link
    - Paste the G+ link into the Wayback Machine: http://web.archive.org
    - Find the topic name
    - Google the topic name in quotes, optionally including "site:makerforums.info"
