Results 1 to 8 of 8
Thread: Web site could use a few updates :)
    Oct 2015
    Roma (IT, EU)
    329
    Wandering around PJRC website, there are a few pages which would need updating.
    I know Paul is so much busy, but at least let's keep track:
    https://www.pjrc.com/teensy/
    Pictures: Teensies 4.x are missing
    "Key features" table: even 3.2, 3.5 and 3.6 are missing
    I would also remove references to 3.1
    https://www.pjrc.com/teensy/techspecs.html
    Missing 4.x
    Title is wrong: "Teensy LC (Low Cost)"
    "Hardware" tree-menu on the left column misses 3.5, 3.6, 4.x
    Oct 2015
    Roma (IT, EU)
    329
    From Frank B:
    https://www.pjrc.com/store/
    4.x missing
    Teensyduino install instructions donít explain the latest method of bundling Arduino with Teensyduino (for Mac only?) and cause confusion
    No mention of Teensy 4 support in IntervalTimer https://www.pjrc.com/teensy/td_timin...rvalTimer.html
    11,571
    Cool update here included T_4.x's !!! - but change to T_3.6 looks like copy paste error?? : pjrc.com/store/
    Teensy 4.1 – Teensy 4.1 with Pins – Extreme 600 MHz Speed, with USB Host, SD Card, Memory Expansion
    Teensy 4.0 – Teensy 4.0 with Pins – Extreme 600 MHz Speed
    Teensy 3.6 – Teensy 3.6 with Pins – Fastest Teensy 3.x, with USB Host, Hi-Res Analog Inputs and 1 Analog Output
    Teensy 3.5 – Teensy 3.5 with Pins – Fastest 5V Tolerant Teensy
    Teensy 3.2 – Teensy 3.2 with Pins – Powerful in Small Size, Hi-Res Analog Inputs and 1 Analog Output
    Teensy LC – Teensy LC with Pins – Lowest Cost
    Should that be:
    Teensy 3.6 – Teensy 3.6 with Pins – Fastest Teensy 3.x, with USB Host, Hi-Res Analog Inputs and 2 Analog Outputs
    Teensy 3.5 – Teensy 3.5 with Pins – Fastest 5V Tolerant Teensy, Hi-Res Analog Inputs and 2 Analog Outputs
    maybe even:
    Teensy 4.1 – Teensy 4.1 with Pins – Extreme 600 MHz Speed, with USB Host, SD Card socket and pads for Memory Expansion
    Teensy 4.0 – Teensy 4.0 with Pins – Extreme 600 MHz Speed, with pads for USB Host, SD Card
    Germany NRW
    6,901
    "Extreme" - what will be the next (i.mx.rt 1070)
    Improbability Drive?
    ...it will be fun
    Don't panic.
    21,871
    Quote Originally Posted by XFer View Post
    4.x missing
    Added a few days ago, and also a couple weeks ago but then accidentally reverted to the old copy.
    Quote Originally Posted by embedded-creations View Post
    Fixed
    Fixed
    21,871
    Teensyduino install instructions don’t explain the latest method of bundling Arduino with Teensyduino (for Mac only?) and cause confusion
    I've added a "Install Step 1: (Macintosh 10.10-10.15 only) Complete Software" to that page.
    In the future I'm planning to move this to a top-level "Downloads" page, where we'll offer a complete ready-to-run copy for all operating systems, and the installer for all of them too (except Catalina of course), and probably a 3rd package for "stand alone" use with Arduino-specific stuff.
    In the meantime, these OS-specific install steps are kind of awkward, but hopefully they get the needed info to people?
