Results 1 to 12 of 12
Thread: Soundfontdecoder compatible with Teensy 4.0?
    Apr 2020
    France
    19
    Hello, I am using a windows 10 with 64 bits, a Teensy 4.0 card and an Audio board.
    I use the SimpleWave.ino example with one of the files found in the soundfontdecoder bank, Celesta, to start and understand. Then I would like to use files created with Polyphone. So I replace Flute_100kbyte with celesta and include celesta_samples.h and .cpp
    /* Play a flute sound when a button is pressed.
       Connect a pushbutton to pin 1 and pots to pins A2 & A3.
       The audio tutorial kit is the intended hardware:
         https://www.pjrc.com/store/audio_tutorial_kit.html
       Without pots connected, this program will play a very
       strange sound due to rapid random fluctuation of the
       pitch and volume!
       Requires Teensy 3.2 or higher.
       Requires Audio Shield: https://www.pjrc.com/store/teensy3_audio.html
    #include <Bounce.h>
    #include "celesta_samples.h"
    AudioSynthWavetable wavetable;
    AudioOutputI2S i2s1;
    AudioMixer4 mixer;
    AudioConnection patchCord1(wavetable, 0, mixer, 0);
    AudioConnection          patchCord2(mixer, 0, i2s1, 0);
    AudioConnection          patchCord3(mixer, 0, i2s1, 1);
    // Bounce objects to read pushbuttons
    Bounce button1 = Bounce(1, 15);  // 15 ms debounce time
      pinMode(1, INPUT_PULLUP);
      AudioMemory(20);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.8);
      mixer.gain(0, 0.7);
      wavetable.setInstrument(celesta);
      wavetable.amplitude(1);
    bool playing = false;
      // Update all the button objects
      button1.update();
      //Read knob values
      int knob1 = analogRead(A3);
      int knob2 = analogRead(A2);
      //Get frequency and gain from knobs (Flute range is 261 to 2100 Hz)
      float freq = 261.0 + (float)knob1/1023.0 * (2100.0 - 261.0);
      float gain = (float)knob2/1023.0;
      //Set a low-limit to the gain
      if (gain < .05) gain = .05;
      if (button1.fallingEdge()) {
        if (playing) {
          playing = false;
          wavetable.stop();
        else {
          playing = true;
          wavetable.playFrequency(freq);
          wavetable.amplitude(gain);
      wavetable.setFrequency(freq);
    I followed the tutorial of installation and the video on Youtube
    I have this error message:
    Arduino: 1.8.12 (Windows 10), TD: 1.52-beta1, Card: "Teensy 4.0, Serial, 600 MHz, Faster, US English"
    In file included from C: \ Users \ US ~ 1 \ AppData \ Local \ Temp \ arduino_build_157559 \ sketch \ celesta_samples.cpp: 1: 0:
    C: \ Users \ US ~ 1 \ AppData \ Local \ Temp \ arduino_build_157559 \ sketch \ celesta_samples.h: 3: 33: fatal error: AudioSynthWavetable.h: No such file or directory
    compilation terminated.
    Several libraries found for "SD.h"
    Used: C: \ Users \ User \ Downloads \ arduino-1.8.12-windows \ arduino-1.8.12 \ hardware \ teensy \ avr \ libraries \ SD
    Not used: C: \ Users \ User \ Downloads \ arduino-1.8.12-windows \ arduino-1.8.12 \ libraries \ SD
    Compilation error for the Teensy 4.0 card
    This report could be more detailed with
    the option "Display the detailed results of the compilation"
    activated in File -> Preferences.
    So as indicated in the tutorial, I include the file in my library, AudioSynthWavetable.h and AudioSynthWavetable.cpp, and I have this error:
    Arduino : 1.8.12 (Windows 10), TD: 1.52-beta1, Carte : "Teensy 4.0, Serial, 600 MHz, Faster, US English"
    In file included from C:\Users\Utilisateur\Documents\Arduino\TutoWavetable\TutoWavetable.ino:22:0:
    Plusieurs bibliothèque trouvées pour "SD.h"
    Utilisé : C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\hardware\teensy\avr\libraries\SD
    C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_514752\sketch\celesta_samples.h:3:33: fatal error: AudioSynthWavetable.h: No such file or directory
    Non utilisé : C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\libraries\SD
    Erreur de compilation pour la carte Teensy 4.0
    Ce rapport pourrait être plus détaillé avec
    l'option "Afficher les résultats détaillés de la compilation"
    activée dans Fichier -> Préférences.
    When I go to this address, however, I have the AudioSynthWavetable.h file present in the folder C: \ Users \ US ~ 1 \ AppData \ Local \ Temp \ arduino_build_514752 \ sketch \AudioSynthWavetable.h
    An idea ?
    Thank you in advance for your help.
    Feb 2014
    Colmar, France
    2,586
    First thing would be to do as suggested :
    Ce rapport pourrait être plus détaillé avecl'option "Afficher les résultats détaillés de la compilation"
    and then to post the details here ;-)
    Apr 2020
    France
    19
    It' true, it's more complete. Could it be a problem of compatibility or access to the file? Tanks.
    C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\hardware -hardware C:\Users\Utilisateur\AppData\Local\Arduino15\packages -tools C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\tools-builder -tools C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\hardware\tools\avr -tools C:\Users\Utilisateur\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\libraries -libraries C:\Users\Utilisateur\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10812 -build-path C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_592291 -warnings=none -build-cache C:\Users\UTILIS~1\AppData\Local\Temp\arduino_cache_321507 -verbose C:\Users\Utilisateur\Documents\Arduino\TutoWavetable\TutoWavetable.ino
    C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\arduino-builder -compile -logger=machine -hardware C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\hardware -hardware C:\Users\Utilisateur\AppData\Local\Arduino15\packages -tools C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\tools-builder -tools C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\hardware\tools\avr -tools C:\Users\Utilisateur\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\libraries -libraries C:\Users\Utilisateur\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10812 -build-path C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_592291 -warnings=none -build-cache C:\Users\UTILIS~1\AppData\Local\Temp\arduino_cache_321507 -verbose C:\Users\Utilisateur\Documents\Arduino\TutoWavetable\TutoWavetable.ino
    Using board 'teensy40' from platform in folder: C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\hardware\teensy\avr
    Using core 'teensy4' from platform in folder: C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\hardware\teensy\avr
    Detecting libraries used...
    "C:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_592291\\sketch\\TutoWavetable.ino.cpp" -o nul
    Alternatives for Bounce.h: [Bounce]
    ResolveLibrary(Bounce.h)
      -> candidates: [Bounce]
    "C:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\Bounce" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_592291\\sketch\\TutoWavetable.ino.cpp" -o nul
    Alternatives for Audio.h: [Audio@1.3]
    ResolveLibrary(Audio.h)
      -> candidates: [Audio@1.3]
    "C:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\Audio" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_592291\\sketch\\TutoWavetable.ino.cpp" -o nul
    Alternatives for SPI.h: [SPI@1.0]
    ResolveLibrary(SPI.h)
      -> candidates: [SPI@1.0]
    "C:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\SPI" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_592291\\sketch\\TutoWavetable.ino.cpp" -o nul
    Alternatives for SD.h: [SD@1.2.4 SD@1.2.2]
    ResolveLibrary(SD.h)
      -> candidates: [SD@1.2.4 SD@1.2.2]
    "C:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\SD" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_592291\\sketch\\TutoWavetable.ino.cpp" -o nul
    Alternatives for SerialFlash.h: [SerialFlash@0.5]
    ResolveLibrary(SerialFlash.h)
      -> candidates: [SerialFlash@0.5]
    "C:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\SerialFlash" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_592291\\sketch\\TutoWavetable.ino.cpp" -o nul
    Alternatives for Wire.h: [Wire@1.0]
    ResolveLibrary(Wire.h)
      -> candidates: [Wire@1.0]
    "C:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Users\\Utilisateur\\Downloads\\arduino-1.8.12-windows\\arduino-1.8.12\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_592291\\sketch\\TutoWavetable.ino.cpp" -o nul
    Alternatives for AudioSynthWavetable.h: []
    ResolveLibrary(AudioSynthWavetable.h)
      -> candidates: []
    C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_592291\sketch\celesta_samples.h:3:33: fatal error: AudioSynthWavetable.h: No such file or directory
    Utilisation de la bibliothèque Bounce prise dans le dossier : C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\hardware\teensy\avr\libraries\Bounce (legacy)
    Utilisation de la bibliothèque Audio version 1.3 dans le dossier: C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\hardware\teensy\avr\libraries\Audio
    Utilisation de la bibliothèque SPI version 1.0 dans le dossier: C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\hardware\teensy\avr\libraries\SPI
    Utilisation de la bibliothèque SD version 1.2.2 dans le dossier: C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\hardware\teensy\avr\libraries\SD
    Utilisation de la bibliothèque SerialFlash version 0.5 dans le dossier: C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\hardware\teensy\avr\libraries\SerialFlash
    Utilisation de la bibliothèque Wire version 1.0 dans le dossier: C:\Users\Utilisateur\Downloads\arduino-1.8.12-windows\arduino-1.8.12\hardware\teensy\avr\libraries\Wire
    Apr 2020
    France
    19
    I saw that I had 2 versions of Arduino, so 2 files. So I deleted the one that was present in the download folder and use the one in Programs (x86). I have a 64-bit version of Windows, does that change anything?
    Arduino : 1.8.12 (Windows 10), TD: 1.52-beta3, Carte : "Teensy 4.0, Serial, 600 MHz, Faster, US English"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Utilisateur\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Utilisateur\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Utilisateur\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10812 -build-path C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_87683 -warnings=none -build-cache C:\Users\UTILIS~1\AppData\Local\Temp\arduino_cache_318162 -verbose C:\Users\Utilisateur\Documents\Arduino\TutoWavetable\TutoWavetable.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Utilisateur\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Utilisateur\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Utilisateur\Documents\Arduino\libraries -fqbn=teensy:avr:teensy40:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10812 -build-path C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_87683 -warnings=none -build-cache C:\Users\UTILIS~1\AppData\Local\Temp\arduino_cache_318162 -verbose C:\Users\Utilisateur\Documents\Arduino\TutoWavetable\TutoWavetable.ino
    Using board 'teensy40' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    Using core 'teensy4' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_87683\\sketch\\TutoWavetable.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_87683\\sketch\\TutoWavetable.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_87683\\sketch\\TutoWavetable.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_87683\\sketch\\TutoWavetable.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_87683\\sketch\\TutoWavetable.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_87683\\sketch\\TutoWavetable.ino.cpp" -o nul
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy4" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Bounce" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\UTILIS~1\\AppData\\Local\\Temp\\arduino_build_87683\\sketch\\TutoWavetable.ino.cpp" -o nul
      -> candidates: []
    C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_87683\sketch\celesta_samples.h:3:33: fatal error: AudioSynthWavetable.h: No such file or directory
    Utilisé : C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
    Non utilisé : C:\Program Files (x86)\Arduino\libraries\SD
    Utilisation de la bibliothèque Bounce prise dans le dossier : C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce (legacy)
    Utilisation de la bibliothèque Audio version 1.3 dans le dossier: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
    Utilisation de la bibliothèque SPI version 1.0 dans le dossier: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
    Utilisation de la bibliothèque SD version 1.2.2 dans le dossier: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
    Utilisation de la bibliothèque SerialFlash version 0.5 dans le dossier: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SerialFlash
    Utilisation de la bibliothèque Wire version 1.0 dans le dossier: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
    Feb 2014
    Colmar, France
    2,586
    The error messages seem to point towards a problem (among still multiple library instances present on your hard disk -> fais le ménage !!!) in celesta_samples.h, line 3.
    I'd do a differential diagnosis by checking if the same sketch works with the original flute sample.
    23,036
    The reference to AudioSynthWavetable.h probably means these wavetable files were created with a very old version of SoundfontDecoder, from before Teensyduino 1.44.
    Probably your best option is to create new .cpp and .h files with the latest SoundfontDecoder.
    https://github.com/PaulStoffregen/SoundfontDecoder
    Going back to the very old version probably will not work, because Teensy 4 didn't exist at that time. But if you want to try anyway, the old Teensyduino versions are still on the server. Just copy the download location, then paste the URL and edit the 3 digit number to the old version you want.
    Back then the wavetable stuff was a separate library. Here's the original source.
    https://github.com/TeensyAudio/Wavetable-Synthesis
    There might be some way to use this old version with the latest audio library. Perhaps start by deleting the synth_wavetable.h and synth_wavetable.cpp files from the library, and edit Audio.h to not include synth_wavetable.h.
    But running the latest SoundfontDecoder to generate files compatible with the modern audio library is probably the easiest and best path.
    Apr 2020
    France
    19
    Thank you for your help. I just learned to use Python and it works. I made with python a new version of SoundfontDecoder.exe. Now the code is different with the .h and .cpp files. and it looks ok. But now I have a different error:
    SimpleWavetableTEST.ino.elf section `.data 'will not fit in region` DTCM'
    or :
    SimpleWavetableTEST.ino.elf section `.bss 'is not within region` DTCM'
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_828023/SimpleWavetableTEST.ino.elf section `.data' will not fit in region `DTCM'
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: address 0x200ed2c0 of C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_828023/SimpleWavetableTEST.ino.elf section `.bss' is not within region `DTCM'
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: region `DTCM' overflowed by 447168 bytes
    Germany NRW
    7,065
    Try to add PROGMEM to the array with the data. And make it const (don't know if it is already)
    23,036
    Oh, yeah, that python code should be updated to put PROGMEM into the generated files.
    You might also need to include Arduino.h, since PROGMEM won't be defined by default in a .cpp file.
    Here are examples of how the files should look:
    https://github.com/PaulStoffregen/Au...mpet_samples.h
    https://github.com/PaulStoffregen/Au...et_samples.cpp
    Apr 2020
    France
    19
    Thanks for your help. PROGMEM was indeed missing in the .cpp file and .h is correct
    #include "flut_samples.h"
    PROGMEM
    static const uint32_t sample_0_flut_flut1[80000] = {
    #pragma once
    extern const AudioSynthWavetable::instrument_data flut;
    but I still get the same error. However it compiles with Teensy 3.6 but not with Teensy 4.0.
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s.cpp: In static member function 'static void AudioInputI2S::isr()':
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s.cpp:125:52: warning: invalid conversion from 'const void*' to 'void*' [-fpermissive]
        arm_dcache_delete(src, sizeof(i2s_rx_buffer) / 2);
    In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/core_pins.h:32:0,
                     from C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/wiring.h:39,
                     from C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/WProgram.h:45,
                     from C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_289786\pch\Arduino.h:6:
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/imxrt.h:9124:20: note:   initializing argument 1 of 'void arm_dcache_delete(void*, uint32_t)'
     static inline void arm_dcache_delete(void *addr, uint32_t size)
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s2.cpp: In static member function 'static void AudioInputI2S2::isr()':
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s2.cpp:106:53: warning: invalid conversion from 'const void*' to 'void*' [-fpermissive]
        arm_dcache_delete(src, sizeof(i2s2_rx_buffer) / 2);
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_289786/SimpleWavetableTEST.ino.elf section `.data' will not fit in region `DTCM'
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: address 0x2009f2c0 of C:\Users\UTILIS~1\AppData\Local\Temp\arduino_build_289786/SimpleWavetableTEST.ino.elf section `.bss' is not within region `DTCM'
    c:/program files (x86)/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: region `DTCM' overflowed by 127680 bytes
    23,036
    One or more is probably still missing PROGMEM
    Apr 2020
    France
    19
    Hello, that was it! PROGMEM were missing before static const. Now it works for all my SF2 files.
    Thank you very much for your help. I have a lot of fun with my Teensy 4.0.
