Good afternoon
Lately I came across the great Teensy boards and they are great to work with VSCode and platformio
For a new project (SMT oven) I chose the Teensy LC board as it features two SPI ports...hooked up a MX31855 thermo coupler ADC on SPI0 which works just fine...
For displaying the temperature curve and user menu I have a Adafruit 2.0" TFT display with 240x320 resolution, and they suggest to use the Adafruit ST7789/GFX library...
When I add the libraries and include headers I get during compile with platformio:
Code looks like:
and platform.ini:
The ST7789 library is though listed as being compatible for the Teensy platform..but maybe not for all boards?
thanks for any pointers....even if I have to dump this display and go for another one (o;
Compiling .pio/build/teensylc/FrameworkArduino/HardwareSerial1.cpp.o
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp:30:17: error: 'RwReg' does not name a type
static volatile RwReg *mosiport, *clkport, *misoport;
Compiling .pio/build/teensylc/FrameworkArduino/HardwareSerial2.cpp.o
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp: In function 'void spiSend(uint8_t)':
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp:60:10: error: 'clkport' was not declared in this scope
*clkport &= ~clkpinmask;
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp:62:12: error: 'mosiport' was not declared in this scope
*mosiport |= mosipinmask;
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp:64:12: error: 'mosiport' was not declared in this scope
*mosiport &= ~mosipinmask;
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp:69:8: error: 'clkport' was not declared in this scope
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp: In function 'uint8_t spiRec()':
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp:88:6: error: 'mosiport' was not declared in this scope
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp:91:8: error: 'clkport' was not declared in this scope
*clkport |= clkpinmask;
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp:95:13: error: 'misoport' was not declared in this scope
if ((*misoport) & misopinmask) data |= 1;
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp: In member function 'uint8_t Sd2Card::init(uint8_t, uint8_t, int8_t, int8_t, int8_t)':
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp:302:5: error: 'clkport' was not declared in this scope
clkport = portOutputRegister(digitalPinToPort(clockPin_));
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp:304:5: error: 'mosiport' was not declared in this scope
mosiport = portOutputRegister(digitalPinToPort(mosiPin_));
/home/klingler/.platformio/lib/SD_ID161/utility/Sd2Card.cpp:306:5: error: 'misoport' was not declared in this scope
misoport = portInputRegister(digitalPinToPort(misoPin_));
Code looks like:
#include <Arduino.h>
#include <MAX31855.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ST7789.h>
int32_t rawData = 0;
MAX31855 myMAX31855(10); //chip select pin, for ESP8266 change to D4 (fails to BOOT/FLASH if pin LOW)
#define TFT_CS 6
#define TFT_DC 7
#define TFT_RST 8
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
tft.init(240, 320);
/* start MAX31855 */
myMAX31855.begin();
while (myMAX31855.getChipID() != MAX31855_ID)
Serial.println(F("MAX6675 error")); //(F()) saves string to flash & keeps dynamic memory free
delay(5000);
Serial.println(F("MAX6675 OK"));
while (myMAX31855.detectThermocouple() != MAX31855_THERMOCOUPLE_OK)
switch (myMAX31855.detectThermocouple())
case MAX31855_THERMOCOUPLE_SHORT_TO_VCC:
Serial.println(F("Thermocouple short to VCC"));
case MAX31855_THERMOCOUPLE_SHORT_TO_GND:
Serial.println(F("Thermocouple short to GND"));
case MAX31855_THERMOCOUPLE_NOT_CONNECTED:
Serial.println(F("Thermocouple not connected"));
case MAX31855_THERMOCOUPLE_UNKNOWN:
Serial.println(F("Thermocouple unknown error, check spi cable"));
delay(5000);
rawData = myMAX31855.readRawData();
Serial.println(myMAX31855.getTemperature(rawData));
and platform.ini:
[env:teensylc]
platform = teensy
board = teensylc
framework = arduino
lib_deps =
SPI
Adafruit ST7735 and ST7789 Library
Adafruit GFX Library
