Results 1 to 3 of 3
Thread: How to use USB serial? usb_init() not defined
    I did:
    #include <usb_serial.h>
    RSGPIO: In function 'void setup()':
    HRSGPIO:138: error: 'usb_init' was not declared in this scope
    usb_init();
    HRSGPIO: In function 'void loop()':
    HRSGPIO:204: warning: comparison between signed and unsigned integer expressions
    if (usb_serial_available() >= sizeof(controlPacket)) {
    'usb_configured' was not declared in this scope
    I expected those functions to be defined.
    Also I could not find any example code?
    24,080
    Quote Originally Posted by JasonH View Post
    In Arduino, click File > Examples > 04.Communication > ASCIITable.
    Or just do something simple like this to print to the serial monitor
      static int count = 0;
      Serial.print("Hello World ");
      Serial.println(count++);
    No need to include special headers or worry about low level USB details.
    Documentation can be found here:
    https://www.pjrc.com/teensy/td_serial.html
    Haha too easy!
    Thanks :facepalm:
