Page 3 of 3 FirstFirst 1 2 3
Results 51 to 55 of 55
Thread: Teensyduino 1.52 Released
  1. #51
    Apr 2016
    St. Petersburg, FL
    209
    The problem has been very irregular. Sometimes a change seems to work then several hours later, the problem returns. USB adapter speed does not seem to be the answer as it's the same on a Win7 desktop with USB2 ports and a Win10 laptop with both USB2 and USB3. Hubs and active extensions have no effect. Also, the same sonar sketch uploads, runs, and prints consistently on a T3.2 and T3.6. Those two boards have always worked correctly. The problem occurs on both T4.0 and T4.1 boards. One clue that shows up occasionally is an error message that "Windows reports the port is ready when it's not ready". The next time I see it I'll copy and paste the entire message on this thread.
  2. #52
    11,790
    Teensy LC :: error: 'CNT_HARDWARE_SERIAL' was not declared in this scope
    Just did fresh (re)install of T_1.52 and seeing this?
    > I did have github bits - so I re0-installed - maybe a holdover file from a change???
    INDEED: Wiped AVR\CORES folder and installed again and this went away
    T:\arduino-1.8.12\hardware\teensy\avr\cores\teensy3\HardwareS erial.cpp:36:63: error: 'CNT_HARDWARE_SERIAL' was not declared in this scope
    HardwareSerial *HardwareSerial::s_serials_with_serial_events[CNT_HARDWARE_SERIAL];
    T:\arduino-1.8.12\hardware\teensy\avr\cores\teensy3\HardwareS erial.cpp:37:27: error: 'uint8_t HardwareSerial::s_count_serials_with_serial_events ' is not a static data member of 'class HardwareSerial'
    uint8_t HardwareSerial::s_count_serials_with_serial_events = 0;
    T:\arduino-1.8.12\hardware\teensy\avr\cores\teensy3\HardwareS erial.cpp:41:44: error: no 'void HardwareSerial::addToSerialEventsList()' member function declared in class 'HardwareSerial'
    void HardwareSerial::addToSerialEventsList() {
  3. #53
    Oct 2019
    128
    I installed TD1.52 yesterday, running the latest OS on a MacBook Pro late 2016.
    It seems to unexpectedly quit sometimes. Today it did so while scrolling through a 1k line sketch.
    Here's the error log I got from Mac OS:
    Process:               Arduino [1541]
    Path:                  /Applications/Teensyduino.app/Contents/MacOS/Arduino
    Identifier:            cc.arduino.Arduino.teensyduino
    Version:               1.8.12 (1.8.12)
    Code Type:             X86-64 (Native)
    Parent Process:        ??? [1]
    Responsible:           Arduino [1541]
    User ID:               501
    Date/Time:             2020-06-07 19:37:33.400 +0300
    OS Version:            Mac OS X 10.15.5 (19F101)
    Report Version:        12
    Anonymous UUID:        4D7CF90E-9098-A777-E78F-0269C16FD269
    Sleep/Wake UUID:       EC523694-5222-43EE-88E1-2D3243848E40
    Time Awake Since Boot: 8900 seconds
    Time Since Wake:       1000 seconds
    System Integrity Protection: enabled
    Crashed Thread:        18  Java: Java2D Queue Flusher
    Exception Type:        EXC_BAD_INSTRUCTION (SIGABRT)
    Exception Codes:       0x0000000000000001, 0x0000000000000000
    Exception Note:        EXC_CORPSE_NOTIFY
    Application Specific Information:
    -[NSOpenGLContext setView:] must be called from the main thread.
    Thread 0:: AppKit Thread  Dispatch queue: com.apple.main-thread
    0   libsystem_kernel.dylib        	0x00007fff70778dfa mach_msg_trap + 10
    1   libsystem_kernel.dylib        	0x00007fff70779170 mach_msg + 60
    2   com.apple.CoreFoundation      	0x00007fff3663cf85 __CFRunLoopServiceMachPort + 247
    3   com.apple.CoreFoundation      	0x00007fff3663ba52 __CFRunLoopRun + 1319
    4   com.apple.CoreFoundation      	0x00007fff3663aece CFRunLoopRunSpecific + 462
    5   com.apple.HIToolbox           	0x00007fff35269abd RunCurrentEventLoopInMode + 292
    6   com.apple.HIToolbox           	0x00007fff352697d5 ReceiveNextEventCommon + 584
    7   com.apple.HIToolbox           	0x00007fff35269579 _BlockUntilNextEventMatchingListInModeWithFilter + 64
    8   com.apple.AppKit              	0x00007fff338b1829 _DPSNextEvent + 883
    9   com.apple.AppKit              	0x00007fff338b0070 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1352
    10  libosxapp.dylib               	0x000000011578fd2e -[NSApplicationAWT nextEventMatchingMask:untilDate:inMode:dequeue:] + 121
    11  com.apple.AppKit              	0x00007fff338a1d7e -[NSApplication run] + 658
    12  libosxapp.dylib               	0x000000011578fb73 +[NSApplicationAWT runAWTLoopWithApp:] + 219
    13  libsplashscreen.dylib         	0x000000011575cb16 __SplashInitPlatform_block_invoke + 70
    14  JavaNativeFoundation          	0x00007fff3af54ff9 +[JNFRunLoop _performCopiedBlock:] + 15
    15  com.apple.Foundation          	0x00007fff38d0e0dd __NSThreadPerformPerform + 204
    16  com.apple.CoreFoundation      	0x00007fff3663cde2 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
    17  com.apple.CoreFoundation      	0x00007fff3663cd81 __CFRunLoopDoSource0 + 103
    18  com.apple.CoreFoundation      	0x00007fff3663cb9b __CFRunLoopDoSources0 + 209
    19  com.apple.CoreFoundation      	0x00007fff3663b8ca __CFRunLoopRun + 927
    20  com.apple.CoreFoundation      	0x00007fff3663aece CFRunLoopRunSpecific + 462
    21  libjli.dylib                  	0x000000010139d621 CreateExecutionEnvironment + 875
    22  libjli.dylib                  	0x0000000101399c1b JLI_Launch + 1878
    23  cc.arduino.Arduino.teensyduino	0x0000000101379166 launch + 8838
    24  cc.arduino.Arduino.teensyduino	0x0000000101376d9f main + 143
    25  cc.arduino.Arduino.teensyduino	0x0000000101376d04 start + 52
    Thread 1:
    0   libsystem_kernel.dylib        	0x00007fff7077a55e __ulock_wait + 10
    1   libsystem_pthread.dylib       	0x00007fff7083d5c2 _pthread_join + 347
    2   libjli.dylib                  	0x000000010139dd61 ContinueInNewThread0 + 129
    3   libjli.dylib                  	0x000000010139c453 ContinueInNewThread + 170
    4   libjli.dylib                  	0x000000010139a881 JLI_Launch + 5052
    5   cc.arduino.Arduino.teensyduino	0x0000000101379166 launch + 8838
    6   cc.arduino.Arduino.teensyduino	0x0000000101376d9f main + 143
    7   libjli.dylib                  	0x000000010139e3cc apple_main + 84
    8   libsystem_pthread.dylib       	0x00007fff7083c109 _pthread_start + 148
    9   libsystem_pthread.dylib       	0x00007fff70837b8b thread_start + 15
    Thread 2:
    0   libsystem_kernel.dylib        	0x00007fff7077b882 __psynch_cvwait + 10
    1   libsystem_pthread.dylib       	0x00007fff7083c425 _pthread_cond_wait + 698
    2   libjvm.dylib                  	0x0000000103e1c237 os::PlatformEvent::park() + 297
    3   libjvm.dylib                  	0x0000000103dd76a2 ParkCommon(ParkEvent*, long) + 59
    4   libjvm.dylib                  	0x0000000103dd7e43 Monitor::IWait(Thread*, long) + 219
    5   libjvm.dylib                  	0x0000000103dd8d2c Monitor::wait(bool, long, bool) + 586
    6   libjvm.dylib                  	0x0000000103f5cb36 Threads::destroy_vm() + 140
    7   libjvm.dylib                  	0x0000000103bf5477 jni_DestroyJavaVM + 425
    8   libjli.dylib                  	0x000000010139b2c4 JavaMain + 1746
    9   libsystem_pthread.dylib       	0x00007fff7083c109 _pthread_start + 148
    10  libsystem_pthread.dylib       	0x00007fff70837b8b thread_start + 15
    Thread 3:
    5   libjvm.dylib                  	0x0000000103dd8cb5 Monitor::wait(bool, long, bool) + 467
    6   libjvm.dylib                  	0x0000000103ad0cec GCTaskManager::get_task(unsigned int) + 252
    7   libjvm.dylib                  	0x0000000103ad245e GCTaskThread::run() + 462
    8   libjvm.dylib                  	0x0000000103e16ee7 java_start(Thread*) + 250
    Thread 4:
    Thread 5:
    Thread 6:
    Thread 7:: Java: VM Thread
    2   libjvm.dylib                  	0x0000000103e196b9 os::PlatformEvent::park(long) + 529
    3   libjvm.dylib                  	0x0000000103dd7e43 Monitor::IWait(Thread*, long) + 219
    4   libjvm.dylib                  	0x0000000103dd8cb5 Monitor::wait(bool, long, bool) + 467
    5   libjvm.dylib                  	0x0000000103fdcec9 VMThread::loop() + 1169
    6   libjvm.dylib                  	0x0000000103fdc8f6 VMThread::run() + 202
    7   libjvm.dylib                  	0x0000000103e16ee7 java_start(Thread*) + 250
    Thread 8:: Java: Reference Handler
    3   libjvm.dylib                  	0x0000000103e095e7 ObjectMonitor::wait(long, bool, Thread*) + 1013
    4   libjvm.dylib                  	0x0000000103f20bc8 ObjectSynchronizer::wait(Handle, long, Thread*) + 562
    5   libjvm.dylib                  	0x0000000103c22715 JVM_MonitorWait + 519
    6   ???                           	0x0000000104fbd60f 0 + 4378580495
    7   ???                           	0x0000000106096ea4 0 + 4396248740
    Thread 9:: Java: Finalizer
    7   ???                           	0x00000001053c23b8 0 + 4382794680
    Thread 10:: Java: Signal Dispatcher
    0   libsystem_kernel.dylib        	0x00007fff70778e36 semaphore_wait_trap + 10
    1   libjvm.dylib                  	0x0000000103e1858e check_pending_signals(bool) + 200
    2   libjvm.dylib                  	0x0000000103e1241b signal_thread_entry(JavaThread*, Thread*) + 52
    3   libjvm.dylib                  	0x0000000103f55963 JavaThread::thread_main_inner() + 373
    4   libjvm.dylib                  	0x0000000103f556ff JavaThread::run() + 847
    5   libjvm.dylib                  	0x0000000103e16ee7 java_start(Thread*) + 250
    6   libsystem_pthread.dylib       	0x00007fff7083c109 _pthread_start + 148
    7   libsystem_pthread.dylib       	0x00007fff70837b8b thread_start + 15
    Thread 11:: Java: C2 CompilerThread0
    0   libjvm.dylib                  	0x0000000103903433 Node::in(unsigned int) const + 87
    1   libjvm.dylib                  	0x0000000103d2047e PhaseIdealLoop::idom_no_update(Node*) const + 134
    2   libjvm.dylib                  	0x0000000103d21f94 PhaseIdealLoop::is_dominator(Node*, Node*) + 132
    3   libjvm.dylib                  	0x0000000103d2d6ce PhaseIdealLoop::get_late_ctrl(Node*, Node*) + 790
    4   libjvm.dylib                  	0x0000000103d2dc98 PhaseIdealLoop::build_loop_late_post(Node*) + 408
    5   libjvm.dylib                  	0x0000000103d2ab74 PhaseIdealLoop::build_loop_late(VectorSet&, Node_List&, Node_Stack&) + 616
    6   libjvm.dylib                  	0x0000000103d29ad9 PhaseIdealLoop::build_and_optimize(bool, bool) + 1479
    7   libjvm.dylib                  	0x00000001039ab92c Compile::Optimize() + 3722
    8   libjvm.dylib                  	0x00000001039a9b03 Compile::Compile(ciEnv*, C2Compiler*, ciMethod*, int, bool, bool, bool) + 2959
    9   libjvm.dylib                  	0x00000001038fe629 C2Compiler::compile_method(ciEnv*, ciMethod*, int) + 199
    10  libjvm.dylib                  	0x00000001039bb336 CompileBroker::invoke_compiler_on_method(CompileTask*) + 1720
    11  libjvm.dylib                  	0x00000001039ba61e CompileBroker::compiler_thread_loop() + 834
    12  libjvm.dylib                  	0x0000000103f55963 JavaThread::thread_main_inner() + 373
    13  libjvm.dylib                  	0x0000000103f556ff JavaThread::run() + 847
    14  libjvm.dylib                  	0x0000000103e16ee7 java_start(Thread*) + 250
    15  libsystem_pthread.dylib       	0x00007fff7083c109 _pthread_start + 148
    16  libsystem_pthread.dylib       	0x00007fff70837b8b thread_start + 15
    Thread 12:: Java: C2 CompilerThread1
    4   libjvm.dylib                  	0x0000000103dd8dd0 Monitor::wait(bool, long, bool) + 750
    5   libjvm.dylib                  	0x00000001039b71d1 CompileQueue::get() + 131
    6   libjvm.dylib                  	0x00000001039ba4cd CompileBroker::compiler_thread_loop() + 497
    7   libjvm.dylib                  	0x0000000103f55963 JavaThread::thread_main_inner() + 373
    8   libjvm.dylib                  	0x0000000103f556ff JavaThread::run() + 847
    9   libjvm.dylib                  	0x0000000103e16ee7 java_start(Thread*) + 250
    10  libsystem_pthread.dylib       	0x00007fff7083c109 _pthread_start + 148
    11  libsystem_pthread.dylib       	0x00007fff70837b8b thread_start + 15
    Thread 13:: Java: C1 CompilerThread2
    0   libjvm.dylib                  	0x00000001038610fa IntervalArray::operator[](int) const + 70
    1   libjvm.dylib                  	0x00000001038c6f21 LinearScan::is_sorted(IntervalArray*) + 161
    2   libjvm.dylib                  	0x00000001038c7502 LinearScan::sort_intervals_after_allocation() + 548
    3   libjvm.dylib                  	0x00000001038ccf02 LinearScan::do_linear_scan() + 308
    4   libjvm.dylib                  	0x0000000103866d27 Compilation::emit_lir() + 171
    5   libjvm.dylib                  	0x000000010386752b Compilation::compile_java_method() + 335
    6   libjvm.dylib                  	0x0000000103867720 Compilation::compile_method() + 110
    7   libjvm.dylib                  	0x0000000103867ab2 Compilation::Compilation(AbstractCompiler*, ciEnv*, ciMethod*, int, BufferBlob*) + 468
    8   libjvm.dylib                  	0x0000000103868ef8 Compiler::compile_method(ciEnv*, ciMethod*, int) + 314
    9   libjvm.dylib                  	0x00000001039bb336 CompileBroker::invoke_compiler_on_method(CompileTask*) + 1720
    10  libjvm.dylib                  	0x00000001039ba61e CompileBroker::compiler_thread_loop() + 834
    11  libjvm.dylib                  	0x0000000103f55963 JavaThread::thread_main_inner() + 373
    12  libjvm.dylib                  	0x0000000103f556ff JavaThread::run() + 847
    13  libjvm.dylib                  	0x0000000103e16ee7 java_start(Thread*) + 250
    14  libsystem_pthread.dylib       	0x00007fff7083c109 _pthread_start + 148
    15  libsystem_pthread.dylib       	0x00007fff70837b8b thread_start + 15
    Thread 14:: Java: Service Thread
    6   libjvm.dylib                  	0x0000000103eb5e1e ServiceThread::service_thread_entry(JavaThread*, Thread*) + 258
    Thread 15:: Java: VM Periodic Task Thread
    3   libjvm.dylib                  	0x0000000103e193a6 os::sleep(Thread*, long, bool) + 686
    4   libjvm.dylib                  	0x0000000103f545c6 WatcherThread::run() + 524
    Thread 16:: com.apple.NSEventThread
    5   com.apple.AppKit              	0x00007fff33a53144 _NSEventThread + 132
    Thread 17:: Java: process reaper
    0   libsystem_kernel.dylib        	0x00007fff7077e482 __wait4 + 10
    1   libjava.dylib                 	0x0000000102fd9044 Java_java_lang_UNIXProcess_waitForProcessExit + 29
    2   ???                           	0x0000000104b4ffad 0 + 4373938093
    3   ???                           	0x0000000104b27d00 0 + 4373773568
    4   ???                           	0x0000000104b282bd 0 + 4373775037
    5   ???                           	0x0000000104b28302 0 + 4373775106
    6   ???                           	0x0000000104b282bd 0 + 4373775037
    7   ???                           	0x0000000104b28302 0 + 4373775106
    8   ???                           	0x0000000104b20671 0 + 4373743217
    9   libjvm.dylib                  	0x0000000103ba6127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
    10  libjvm.dylib                  	0x0000000103ba4966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
    11  libjvm.dylib                  	0x0000000103ba4bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
    12  libjvm.dylib                  	0x0000000103c3e739 thread_entry(JavaThread*, Thread*) + 177
    13  libjvm.dylib                  	0x0000000103f55963 JavaThread::thread_main_inner() + 373
    14  libjvm.dylib                  	0x0000000103f556ff JavaThread::run() + 847
    15  libjvm.dylib                  	0x0000000103e16ee7 java_start(Thread*) + 250
    16  libsystem_pthread.dylib       	0x00007fff7083c109 _pthread_start + 148
    17  libsystem_pthread.dylib       	0x00007fff70837b8b thread_start + 15
    Thread 18 Crashed:: Java: Java2D Queue Flusher
    0   libsystem_kernel.dylib        	0x00007fff7077f33a __pthread_kill + 10
    1   libsystem_pthread.dylib       	0x00007fff7083be60 pthread_kill + 430
    2   libsystem_c.dylib             	0x00007fff70706808 abort + 120
    3   libjvm.dylib                  	0x0000000103ffa8ca os::abort(bool) (.cold.1) + 125
    4   libjvm.dylib                  	0x0000000103e1755b os::abort(bool) + 33
    5   libjvm.dylib                  	0x0000000103fb08a6 VMError::report_and_die() + 2298
    6   libjvm.dylib                  	0x0000000103a0c2d3 report_vm_error(char const*, int, char const*, char const*) + 93
    7   libjvm.dylib                  	0x0000000103e1cfa8 os::get_sender_for_C_frame(frame*) + 76
    8   libjvm.dylib                  	0x0000000103a0d524 print_native_stack(outputStream*, frame, Thread*, char*, int) + 336
    9   libjvm.dylib                  	0x0000000103faf703 VMError::report(outputStream*) + 2617
    10  libjvm.dylib                  	0x0000000103fb0387 VMError::report_and_die() + 987
    11  libjvm.dylib                  	0x0000000103e1d3b7 JVM_handle_bsd_signal + 802
    12  libjvm.dylib                  	0x0000000103e19f0f signalHandler(int, __siginfo*, void*) + 88
    13  libsystem_platform.dylib      	0x00007fff708305fd _sigtramp + 29
    14  libobjc.A.dylib               	0x00007fff6f484954 lookUpImpOrForward + 63
    15  libawt_lwawt.dylib            	0x00000001176b8239 CGLSD_MakeCurrentToScratch + 93
    16  libawt_lwawt.dylib            	0x00000001176b8390 OGLSD_MakeOGLContextCurrent + 166
    17  libawt_lwawt.dylib            	0x00000001176d5e32 OGLContext_SetSurfaces + 188
    18  libawt_lwawt.dylib            	0x00000001176da69f Java_sun_java2d_opengl_OGLRenderQueue_flushBuffer + 1775
    19  ???                           	0x0000000105784d51 0 + 4386737489
    20  ???                           	0x00000001059dcd40 0 + 4389195072
    Thread 19:: Java: Java2D Disposer
    7   ???                           	0x0000000105f8b8a8 0 + 4395153576
    Thread 20:: Java: Thread-5
    0   libsystem_kernel.dylib        	0x00007fff7077981e read + 10
    1   libjava.dylib                 	0x0000000102fdc76c handleRead + 34
    2   libjava.dylib                 	0x0000000102fdbfc3 readBytes + 351
    3   ???                           	0x0000000105117ee9 0 + 4379999977
    4   ???                           	0x000000010510b4fc 0 + 4379948284
    Thread 21:: Java: cc.arduino.packages.discoverers.serial.SerialDiscovery
    3   libjvm.dylib                  	0x0000000103e09587 ObjectMonitor::wait(long, bool, Thread*) + 917
    7   ???                           	0x0000000104b282bd 0 + 4373775037
    8   ???                           	0x0000000104b282bd 0 + 4373775037
    9   ???                           	0x0000000104b20671 0 + 4373743217
    10  libjvm.dylib                  	0x0000000103ba6127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
    11  libjvm.dylib                  	0x0000000103ba4966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
    12  libjvm.dylib                  	0x0000000103ba4bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
    13  libjvm.dylib                  	0x0000000103c3e739 thread_entry(JavaThread*, Thread*) + 177
    14  libjvm.dylib                  	0x0000000103f55963 JavaThread::thread_main_inner() + 373
    15  libjvm.dylib                  	0x0000000103f556ff JavaThread::run() + 847
    16  libjvm.dylib                  	0x0000000103e16ee7 java_start(Thread*) + 250
    17  libsystem_pthread.dylib       	0x00007fff7083c109 _pthread_start + 148
    18  libsystem_pthread.dylib       	0x00007fff70837b8b thread_start + 15
    Thread 22:: Java: Multihomed mDNS.Timer
    Thread 23:: Java: Batik CleanerThread
    6   ???                           	0x0000000104b4ffad 0 + 4373938093
    7   ???                           	0x0000000104f7dee4 0 + 4378320612
    Thread 24:: Java: AWT-Shutdown
    7   ???                           	0x00000001051a3654 0 + 4380571220
    8   ???                           	0x0000000104b28302 0 + 4373775106
    Thread 25:: Java: MarlinRenderer Disposer
    Thread 26:: Java: AWT-EventQueue-0
    2   libjvm.dylib                  	0x0000000103e1c861 Parker::park(bool, long) + 1239
    3   libjvm.dylib                  	0x0000000103f8b61b Unsafe_Park + 430
    4   ???                           	0x000000010593d7d1 0 + 4388542417
    5   ???                           	0x000000010633db5c 0 + 4399029084
    Thread 27:: Java: TimerQueue
    2   libjvm.dylib                  	0x0000000103e1c82c Parker::park(bool, long) + 1186
    5   ???                           	0x0000000106126394 0 + 4396835732
    Thread 28:: Java: JmDNS(davids-mbp-3-018-co-il.local.).Timer
    Thread 29:: Java: JmDNS(davids-mbp-3-018-co-il.local.).State.Timer
    Thread 30:: Java: JmDNS(davids-mbp-3-018-co-il.local.).Timer
    Thread 31:: Java: JmDNS(davids-mbp-3-018-co-il.local.).State.Timer
    Thread 32:: Java: JmDNS(davids-mbp-3-018-co-il.local.).Timer
    Thread 33:: Java: JmDNS(davids-mbp-3-018-co-il.local.).State.Timer
    Thread 34:: Java: SocketListener(davids-mbp-3-018-co-il.local.)
    0   libsystem_kernel.dylib        	0x00007fff7077c3a6 __recvfrom + 10
    1   libnet.dylib                  	0x0000000115711167 NET_RecvFrom + 135
    2   libnet.dylib                  	0x000000011570d457 Java_java_net_PlainDatagramSocketImpl_receive0 + 449
    3   ???                           	0x0000000105779311 0 + 4386689809
    4   ???                           	0x0000000106003d44 0 + 4395646276
    5   ???                           	0x0000000104b20671 0 + 4373743217
    6   libjvm.dylib                  	0x0000000103ba6127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
    7   libjvm.dylib                  	0x0000000103ba4966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
    8   libjvm.dylib                  	0x0000000103ba4bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
    9   libjvm.dylib                  	0x0000000103c3e739 thread_entry(JavaThread*, Thread*) + 177
    10  libjvm.dylib                  	0x0000000103f55963 JavaThread::thread_main_inner() + 373
    11  libjvm.dylib                  	0x0000000103f556ff JavaThread::run() + 847
    12  libjvm.dylib                  	0x0000000103e16ee7 java_start(Thread*) + 250
    13  libsystem_pthread.dylib       	0x00007fff7083c109 _pthread_start + 148
    14  libsystem_pthread.dylib       	0x00007fff70837b8b thread_start + 15
    Thread 35:: Java: JmDNS(davids-mbp-3-018-co-il.local.).Timer
    Thread 36:: Java: JmDNS(davids-mbp-3-018-co-il.local.).State.Timer
    Thread 37:: Java: SocketListener(davids-macbook-pro-3.local.)
    Thread 38:: Java: JmDNS(davids-macbook-pro-3.local.).Timer
    Thread 39:: Java: JmDNS(davids-macbook-pro-3.local.).State.Timer
    Thread 40:
    0   libsystem_pthread.dylib       	0x00007fff70837b68 start_wqthread + 0
    Thread 41:
    Thread 42:
    Thread 43:
    Thread 18 crashed with X86 Thread State (64-bit):
      rax: 0x0000000000000000  rbx: 0x00007000077c0000  rcx: 0x00007000077be5f8  rdx: 0x0000000000000000
      rdi: 0x0000000000012907  rsi: 0x0000000000000006  rbp: 0x00007000077be620  rsp: 0x00007000077be5f8
       r8: 0x0000000000000010   r9: 0x00007000077be630  r10: 0x00007000077c0000  r11: 0x0000000000000246
      r12: 0x0000000000012907  r13: 0x00007000077be7a0  r14: 0x0000000000000006  r15: 0x0000000000000016
      rip: 0x00007fff7077f33a  rfl: 0x0000000000000246  cr2: 0x0000000103ff9644
    Logical CPU:     0
    Error Code:      0x02000148
    Trap Number:     133
    Binary Images:
           0x101376000 -        0x10137afff +cc.arduino.Arduino.teensyduino (1.8.12 - 1.8.12) <2AE2040B-3408-3208-B101-5825B8F425F0> /Applications/Teensyduino.app/Contents/MacOS/Arduino
           0x101398000 -        0x1013a1fff +libjli.dylib (0) <212562B4-111E-35D6-BB2B-A1BFD63A5B64> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/jli/libjli.dylib
           0x102fbd000 -        0x102fc5fff +libverify.dylib (0) <B8F4EBC4-811F-33AD-BB9A-2C4B148C8C6D> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libverify.dylib
           0x102fd0000 -        0x102feefff +libjava.dylib (0) <32138414-C5B3-3330-8911-97D6CD983944> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libjava.dylib
           0x10301e000 -        0x103022fff +libzip.dylib (0) <346621C0-4ADF-3E59-A9AA-76CC581A12F0> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libzip.dylib
           0x1035f5000 -        0x103686eff  dyld (750.5) <E4698FBD-806A-3396-B279-E685BA37430B> /usr/lib/dyld
           0x1036fa000 -        0x104193fff +libjvm.dylib (0) <31202E71-A956-3765-B4D6-876A7D4FFBD9> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/server/libjvm.dylib
           0x1156ef000 -        0x1156f5fff +libnio.dylib (0) <1FB68BF9-1173-3A83-A617-15DA017AD812> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libnio.dylib
           0x115707000 -        0x115714fff +libnet.dylib (0) <B9072F4C-3145-3661-9DBE-8AECB4DF85DB> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libnet.dylib
           0x115727000 -        0x115763ff3 +libsplashscreen.dylib (0) <F8DFB9AF-1758-3CB3-8ECF-A40AF50AEFE2> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libsplashscreen.dylib
           0x11578d000 -        0x115792fff +libosxapp.dylib (0) <44AA406A-BF46-3779-8247-5363068551AC> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libosxapp.dylib
           0x115fc6000 -        0x115fc7fe7 +libjSSC-2.8_x86_64.jnilib (0) <42816ADC-83A4-F3FF-6E2F-422A583B0174> /Users/USER/*/libjSSC-2.8_x86_64.jnilib
           0x116f9f000 -        0x116ff9ff3 +libawt.dylib (0) <F9DD7DEF-AB6A-3718-9314-73F7B227B709> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libawt.dylib
           0x11708c000 -        0x117136ff7 +libmlib_image.dylib (0) <9474B2D4-5C83-3AED-A17D-155AC6A1292F> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libmlib_image.dylib
           0x11769e000 -        0x1176fdff3 +libawt_lwawt.dylib (0) <4D83B9A4-989F-3D85-BA5E-F0208BEB2F86> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libawt_lwawt.dylib
           0x117ff7000 -        0x117ffa047  libobjc-trampolines.dylib (787.1) <8212B354-A106-3806-A022-A60F2B2FA5C9> /usr/lib/libobjc-trampolines.dylib
           0x1180ee000 -        0x1180ffff7 +liblistSerialsj.dylib (0) <9652E9D9-1D2A-37ED-982B-F222108D70FF> /Applications/Teensyduino.app/Contents/Java/lib/liblistSerialsj.dylib
           0x118108000 -        0x118140ff3 +libfontmanager.dylib (0) <DF7F570B-A725-35D6-AD41-D00755395693> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libfontmanager.dylib
           0x118189000 -        0x118222ff7 +libfreetype.dylib.6 (0) <D7022DC9-4783-3993-97D4-A548688EF098> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libfreetype.dylib.6
           0x11825c000 -        0x118262fff +libosx.dylib (0) <65FD3A00-CBF7-3B4C-95AA-041E9A8A0907> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libosx.dylib
           0x14874d000 -        0x148750ffb +libmanagement.dylib (0) <8413F67C-85D3-3B3C-9FC2-75A0B470A96C> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libmanagement.dylib
           0x148eaf000 -        0x148eb3fff +libosxui.dylib (0) <298413FC-09E2-3331-8821-E08823132ED9> /Applications/Teensyduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libosxui.dylib
           0x1493f7000 -        0x149432fff +libastylej.dylib (0) <906AC4F1-6792-3FBA-A552-EF8D40DBEA1B> /Applications/Teensyduino.app/Contents/Java/lib/libastylej.dylib
           0x14a281000 -        0x14a28fff7 +libJTouchBar.dylib5545651800035006961 (0) <E9801EEC-0090-3848-8C4B-8335665DFE26> /var/folders/*/libJTouchBar.dylib5545651800035006961
        0x7fff296ab000 -     0x7fff298f8ff8  com.apple.RawCamera.bundle (9.02.0 - 1350.29) <0CC24FF1-0754-3A75-BA2D-212CF70ADDC1> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
        0x7fff2f3bd000 -     0x7fff303c5ff7  com.apple.driver.AppleIntelSKLGraphicsGLDriver (14.6.18 - 14.0.6) <99F84715-F7B1-39DF-85E9-B3CEE6ACBD10> /System/Library/Extensions/AppleIntelSKLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsGLDriver
        0x7fff303c6000 -     0x7fff307c5ff3  com.apple.driver.AppleIntelSKLGraphicsMTLDriver (14.6.18 - 14.0.6) <9737C6FD-3998-3354-A4F6-FBF8E37792DB> /System/Library/Extensions/AppleIntelSKLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelSKLGraphicsMTLDriver
        0x7fff32244000 -     0x7fff32244fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <56DFF715-6A4E-3231-BDCC-A348BCB05047> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
        0x7fff32245000 -     0x7fff3225bfef  libCGInterfaces.dylib (524.2.1) <A423F932-C044-3CEB-BF20-BF4CB323361E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
        0x7fff3225c000 -     0x7fff328b2fff  com.apple.vImage (8.1 - 524.2.1) <17C93AB9-1625-3FDB-9851-C5E77BBE3428> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
        0x7fff328b3000 -     0x7fff32b1aff7  libBLAS.dylib (1303.60.1) <CBC28BE4-3C78-3AED-9565-0D625251D121> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
        0x7fff32b1b000 -     0x7fff32feefef  libBNNS.dylib (144.100.2) <8D653678-1F9B-3670-AAE2-46DFB8D37643> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
        0x7fff32fef000 -     0x7fff3338afff  libLAPACK.dylib (1303.60.1) <F8E9D081-7C60-32EC-A47D-2D30CAD73C5F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
        0x7fff3338b000 -     0x7fff333a0fec  libLinearAlgebra.dylib (1303.60.1) <D2C1ACEA-2B6A-339A-9EEB-62A76CC92CBE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
        0x7fff333a1000 -     0x7fff333a6ff3  libQuadrature.dylib (7) <3112C977-8306-3190-8313-01A952B7F3CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
        0x7fff333a7000 -     0x7fff33417fff  libSparse.dylib (103) <40510BF9-99A7-3155-A81D-6DE5A0C73EDC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
        0x7fff33418000 -     0x7fff3342afef  libSparseBLAS.dylib (1303.60.1) <3C1066AB-20D5-38D2-B1F2-70A03DE76D0B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
        0x7fff3342b000 -     0x7fff33602fd7  libvDSP.dylib (735.121.1) <74702E2E-ED05-3765-B18C-64BEFF62B517> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
        0x7fff33603000 -     0x7fff336c5fef  libvMisc.dylib (735.121.1) <137558BF-503D-3A6E-96DC-A181E3FB31FF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
        0x7fff336c6000 -     0x7fff336c6fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <D7E8E400-35C8-3174-9956-8D1B483620DA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
        0x7fff336c7000 -     0x7fff33726ff0  com.apple.Accounts (113 - 113) <0510C893-F1F2-38B2-B3AA-A30DB2F5B688> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
        0x7fff33870000 -     0x7fff34630ffd  com.apple.AppKit (6.9 - 1894.50.103) <61269B8C-C432-335F-8894-B95C235A41A5> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff34680000 -     0x7fff34680fff  com.apple.ApplicationServices (48 - 50) <EEC73694-1A37-3C14-A839-6991E2BD8655> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
        0x7fff34681000 -     0x7fff346ecfff  com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <A6912C4A-55CC-3701-BACA-E63423B99481> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
        0x7fff34785000 -     0x7fff347c3ff0  libFontRegistry.dylib (274.0.5.1) <A78A7869-C96C-3AD6-A038-DE541639BB60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
        0x7fff3481e000 -     0x7fff3484dfff  com.apple.ATSUI (1.0 - 1) <4B3C2201-DBB3-352C-936B-9C423122EFF6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
        0x7fff3484e000 -     0x7fff34852ffb  com.apple.ColorSyncLegacy (4.13.0 - 1) <47D42CDE-2E9A-3AF6-9365-1BFD1189196B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
        0x7fff348ec000 -     0x7fff34943ffa  com.apple.HIServices (1.22 - 675.1) <273492E3-FF0F-3A8A-A83F-0F11F99B5F26> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
        0x7fff34944000 -     0x7fff34952fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <DA175323-5BE3-3C54-92D4-A171A4A067E6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
        0x7fff34953000 -     0x7fff34998ffa  com.apple.print.framework.PrintCore (15.4 - 516.2) <99AEBCDB-2DCA-3A13-906F-7F0D7962B002> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
        0x7fff34999000 -     0x7fff349a3ff7  com.apple.QD (4.0 - 413) <D2E1DC80-D26F-3508-BBA5-B8AE7ED6CB0E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
        0x7fff349a4000 -     0x7fff349b1ffc  com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <823C0DE7-1351-3B39-8F06-AB5FCAD2C874> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
        0x7fff349b2000 -     0x7fff34a93ffa  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <75651F0A-F2CE-3F68-B86A-E66B8815DCF4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
        0x7fff34a95000 -     0x7fff34a95fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <E51DCB3C-CF4F-320B-AC86-D445E30C0891> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
        0x7fff34e2b000 -     0x7fff351b9ffd  com.apple.CFNetwork (1126 - 1126) <BB8F4C63-10B8-3ACD-84CF-D4DCFA9245DD> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff35235000 -     0x7fff35235fff  com.apple.Carbon (160 - 162) <4F1F60CB-6C1E-3D79-832E-8D606601F282> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
        0x7fff35236000 -     0x7fff35239ff3  com.apple.CommonPanels (1.2.6 - 101) <333BBF55-AF23-3B99-A9FF-7906175B9406> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
        0x7fff3523a000 -     0x7fff3552eff3  com.apple.HIToolbox (2.1.1 - 994.6) <5C44ACA7-D158-3F9B-8F88-0477510D44FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
        0x7fff3552f000 -     0x7fff35532ff3  com.apple.help (1.3.8 - 71) <4B2701A0-8813-35F8-82F8-676B184D15C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
        0x7fff35533000 -     0x7fff35538ff7  com.apple.ImageCapture (9.0 - 1600.60.4.2) <20872A2D-CBF9-38E6-BD16-C1D387120651> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
        0x7fff35539000 -     0x7fff35539fff  com.apple.ink.framework (10.15 - 227) <5B60FDDE-D60E-326B-BD3D-6EA5FA1CBB76> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
        0x7fff3553a000 -     0x7fff35554ffa  com.apple.openscripting (1.7 - 185.1) <E59F893B-1A73-3098-8924-79227EC9787E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
        0x7fff35575000 -     0x7fff35575fff  com.apple.print.framework.Print (15 - 271) <07C50BF6-2222-3769-A5B8-79D7F996183F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
        0x7fff35576000 -     0x7fff35578ff7  com.apple.securityhi (9.0 - 55008) <D7017D5A-4206-3E2F-9F8E-0F932422CA87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
        0x7fff35579000 -     0x7fff3557ffff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1188E643-967C-334E-BC1A-60A0F82C67E5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
        0x7fff35719000 -     0x7fff35719fff  com.apple.Cocoa (6.11 - 23) <87426C3A-7C6C-39D0-905C-C591B997029E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
        0x7fff35727000 -     0x7fff3581dfff  com.apple.ColorSync (4.13.0 - 3394.9) <61698A7B-BB8C-3891-9547-703FF84671A8> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
        0x7fff35b08000 -     0x7fff36011ffb  com.apple.audio.CoreAudio (5.0 - 5.0) <62BEE4B7-8A26-3951-9D78-4E193617AF7A> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
        0x7fff36064000 -     0x7fff3609cfff  com.apple.CoreBluetooth (1.0 - 1) <6BC7F863-4495-371F-BC54-543E5CFE1665> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
        0x7fff3609d000 -     0x7fff36487fe8  com.apple.CoreData (120 - 977.3) <D902A2E3-1D0A-3995-974E-A526976E5735> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
        0x7fff36488000 -     0x7fff365b8ffe  com.apple.CoreDisplay (1.0 - 186.6.12) <EA74CC46-8715-3B90-95E8-4594D2F0CC8A> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
        0x7fff365b9000 -     0x7fff36a38ffb  com.apple.CoreFoundation (6.9 - 1676.105) <6AF8B3CC-BC3F-3869-B9FB-1D881422364E> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
        0x7fff36a3a000 -     0x7fff370aeff8  com.apple.CoreGraphics (2.0 - 1355.17) <E1CE3919-F36B-309F-89BA-79F36DC8125E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
        0x7fff370bc000 -     0x7fff37417ff0  com.apple.CoreImage (15.0.0 - 940.9) <44F68E8C-315A-32A6-BB19-7F24C00AB347> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
        0x7fff377d8000 -     0x7fff378b3ffc  com.apple.CoreMedia (1.0 - 2620.11.40.2) <0F490101-ED30-3189-B099-E247B6361A0B> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fff379a0000 -     0x7fff379a0fff  com.apple.CoreServices (1069.24 - 1069.24) <D9F6AB40-10EC-3682-A969-85560E2E4768> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
        0x7fff379a1000 -     0x7fff37a26fff  com.apple.AE (838.1 - 838.1) <5F26DA9B-FB2E-3AF8-964B-63BD6671CF12> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
        0x7fff37a27000 -     0x7fff37d08ff7  com.apple.CoreServices.CarbonCore (1217 - 1217) <8022AF47-AA99-3786-B086-141D84F00387> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
        0x7fff37d09000 -     0x7fff37d56ffd  com.apple.DictionaryServices (1.2 - 323.6) <C0F3830C-A4C6-3046-9A6A-DE1B5D448C2C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
        0x7fff37d57000 -     0x7fff37d5fff7  com.apple.CoreServices.FSEvents (1268.100.1 - 1268.100.1) <E4B2CAF2-1203-335F-9971-1278CB6E2AE0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
        0x7fff37d60000 -     0x7fff37f9aff6  com.apple.LaunchServices (1069.24 - 1069.24) <2E0AD228-B1CC-3645-91EE-EB7F46F2147B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
        0x7fff37f9b000 -     0x7fff38033ff1  com.apple.Metadata (10.7.0 - 2076.6) <C8034E84-7DD4-34B9-9CDF-16A05032FF39> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
        0x7fff38034000 -     0x7fff38061fff  com.apple.CoreServices.OSServices (1069.24 - 1069.24) <72FDEA52-7607-3745-AC43-630D80962099> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
        0x7fff38062000 -     0x7fff380c9fff  com.apple.SearchKit (1.4.1 - 1.4.1) <086EB5DF-A2EC-3342-8028-CA7996BE5CB2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
        0x7fff380ca000 -     0x7fff380eeff5  com.apple.coreservices.SharedFileList (131.4 - 131.4) <AE333DA2-C279-3751-8C15-B963E58EE61E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
        0x7fff38413000 -     0x7fff385caffc  com.apple.CoreText (643.1.5.1 - 643.1.5.1) <715FE3F7-E8FB-3997-85A0-3AB2839F6C30> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
        0x7fff385cb000 -     0x7fff3860fffb  com.apple.CoreVideo (1.8 - 344.3) <A200AFC7-2CB2-30CD-8B2A-1269CA64A29B> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff38610000 -     0x7fff3869dffc  com.apple.framework.CoreWLAN (13.0 - 1601.2) <855E51AA-DF3A-3BB9-A4F0-6880D42B8762> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
        0x7fff38859000 -     0x7fff38864ff7  com.apple.DirectoryService.Framework (10.15 - 220.40.1) <06D98FD0-796F-356F-B492-A6D8F3D5BEC0> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
        0x7fff38865000 -     0x7fff3890fff0  com.apple.DiscRecording (9.0.3 - 9030.4.5) <D9033DDA-E4C8-36FB-AE60-4EF66F4F1F9E> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
        0x7fff38934000 -     0x7fff3893afff  com.apple.DiskArbitration (2.7 - 2.7) <52E7D181-2A18-37CD-B24F-AA32E93F7A69> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
        0x7fff38b0e000 -     0x7fff38b10ff2  com.apple.ExceptionHandling (1.5 - 13) <62FDDF8D-2DD1-3812-A28F-80A273F6C0F6> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
        0x7fff38b2d000 -     0x7fff38c5bff6  com.apple.FileProvider (304.1 - 304.1) <58D64236-947E-3E6A-85E6-C66AEF9E0EE0> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
        0x7fff38c73000 -     0x7fff39038fff  com.apple.Foundation (6.9 - 1676.105) <1FA28BAB-7296-3A09-8E1E-E62A7D233DB8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff390a5000 -     0x7fff390f5ff7  com.apple.GSS (4.0 - 2.0) <4E241C00-42A5-3572-9430-D950FBB7A4A0> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
        0x7fff39232000 -     0x7fff39346ff3  com.apple.Bluetooth (7.0.5 - 7.0.5f6) <5897C368-9674-3E34-B144-FFB06A2DF37B> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
        0x7fff393ac000 -     0x7fff39450ff3  com.apple.framework.IOKit (2.0.2 - 1726.121.1) <A0F54725-036F-3279-A46E-C2ABDBFD479B> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff39452000 -     0x7fff39463ffb  com.apple.IOSurface (269.11 - 269.11) <D3CC2AA1-4AE2-30EE-A9DB-C04CCAA88ADE> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
        0x7fff394e2000 -     0x7fff3963effe  com.apple.ImageIO.framework (3.3.0 - 1976.6) <5B4C2E04-9161-3C82-A7FB-F4D51E3C1E10> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
        0x7fff3963f000 -     0x7fff39642fff  libGIF.dylib (1976.6) <3B26EE1C-C570-305C-A9A3-EA62D2F2E7B8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
        0x7fff39643000 -     0x7fff396fcfff  libJP2.dylib (1976.6) <EB4E4E09-DD81-3E6B-A513-3667E810AEF3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
        0x7fff396fd000 -     0x7fff39720fe3  libJPEG.dylib (1976.6) <9D7FAC55-85A6-34AB-9F26-0BCA381E8CE7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
        0x7fff3999c000 -     0x7fff399b6fef  libPng.dylib (1976.6) <4886A1F8-E9CA-38F2-BF2F-1FCA1DFDD1C9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
        0x7fff399b7000 -     0x7fff399b8fff  libRadiance.dylib (1976.6) <FA759D33-131A-33B8-943E-32409F162738> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
        0x7fff399b9000 -     0x7fff39a02fff  libTIFF.dylib (1976.6) <E9994BF8-6CF5-3422-B4FD-A14DC390EF12> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
        0x7fff3af4e000 -     0x7fff3af56ffc  JavaNativeFoundation (75) <8BCA18FD-514F-3B7D-9C7A-2988B38F3E7B> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
        0x7fff3af57000 -     0x7fff3af5effa  com.apple.java.JavaRuntimeSupport (15.0.1 - 15.0.1) <73034041-5247-34ED-96C2-97C5AD2C554E> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
        0x7fff3af5f000 -     0x7fff3af63ffd  com.apple.JavaVM (15.0.3 - 15.0.3) <8D6E6E58-21A6-325B-97C0-0CB065C6AEC5> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
        0x7fff3af64000 -     0x7fff3af76ff3  com.apple.Kerberos (3.0 - 1) <AE0E56CA-D924-3CC8-BBAA-8C6EEC3038BE> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
        0x7fff3af77000 -     0x7fff3af77fff  libHeimdalProxy.dylib (77) <A970C7A8-7CCD-3701-A459-078BD5E8FE4E> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
        0x7fff3af78000 -     0x7fff3afaeff7  com.apple.LDAPFramework (2.4.28 - 194.5) <4CFB6351-53B9-36AF-B654-AE636BBC361A> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
        0x7fff3b309000 -     0x7fff3b313ffb  com.apple.MediaAccessibility (1.0 - 125.1) <DBF40A12-65A6-33E4-839C-292600B7D910> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
        0x7fff3b3df000 -     0x7fff3bb2cff5  com.apple.MediaToolbox (1.0 - 2620.11.40.2) <40F16AF6-79D1-3C2E-976C-E7E7870A4EF9> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
        0x7fff3bb2e000 -     0x7fff3bbf8ff7  com.apple.Metal (212.7 - 212.7) <CC7BF715-142B-3C2A-81AD-0E35693230F2> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
        0x7fff3bc15000 -     0x7fff3bc52ff7  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <52089325-EC97-3EED-ABB3-9B39EC0BD429> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
        0x7fff3bc53000 -     0x7fff3bcddfe2  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <9E434EA0-6BCA-3903-B882-CEB69730A63B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
        0x7fff3bcde000 -     0x7fff3bd03ff4  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <EDD6C3A5-E231-3FB1-B4D4-45742AFB9A4E> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
        0x7fff3bd04000 -     0x7fff3bd19ffb  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <C5A2B865-5CE2-3E5D-8452-54639FCB0954> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
        0x7fff3bd1a000 -     0x7fff3be78ffc  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <47CCDBAC-5843-366A-A68C-6E8851D0865D> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
        0x7fff3be79000 -     0x7fff3bec8ff4  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <302BDF8E-B00A-3123-A6C4-E262B7513CF6> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
        0x7fff3bec9000 -     0x7fff3becaff5  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <14F84B42-9DA2-39A1-81B4-666B8020520C> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
        0x7fff3cf51000 -     0x7fff3cf5dffe  com.apple.NetFS (6.0 - 4.0) <AC74E6A4-6E9B-3AB1-9577-8277F8A3EDE0> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
        0x7fff3cf5e000 -     0x7fff3d0b5ff3  com.apple.Network (1.0 - 1) <B5B8E999-BBCC-3DEF-8881-8FFF69F8EC4B> /System/Library/Frameworks/Network.framework/Versions/A/Network
        0x7fff3fadd000 -     0x7fff3fae5ff7  libcldcpuengine.dylib (2.14) <D8583B54-FE2A-33FD-A702-ABF307D99FD1> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
        0x7fff3fae6000 -     0x7fff3fb3efff  com.apple.opencl (3.5 - 3.5) <9B101D40-EA79-3C0D-B7AE-A3F18094B2D7> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
        0x7fff3fb3f000 -     0x7fff3fb5bfff  com.apple.CFOpenDirectory (10.15 - 220.40.1) <BFC32EBE-D95C-3267-B95C-5CEEFD189EA6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
        0x7fff3fb5c000 -     0x7fff3fb67ffd  com.apple.OpenDirectory (10.15 - 220.40.1) <76A20BBA-775F-3E17-AB0F-FEDFCDCE0716> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
        0x7fff404cd000 -     0x7fff404cffff  libCVMSPluginSupport.dylib (17.10.22) <AAE07E0C-4B28-364B-A7D9-028C7CD14954> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
        0x7fff404d0000 -     0x7fff404d5fff  libCoreFSCache.dylib (176.15) <609C5DFC-9A97-344D-BBC7-E0B08D862C63> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
        0x7fff404d6000 -     0x7fff404dafff  libCoreVMClient.dylib (176.15) <8F8DD27F-AC7C-398D-A8E3-396F1528E317> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
        0x7fff404db000 -     0x7fff404e3ff7  libGFXShared.dylib (17.10.22) <D0649AB5-5331-328D-8141-E5A6F06D4AD7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
        0x7fff404e4000 -     0x7fff404eefff  libGL.dylib (17.10.22) <116DDBF7-D725-3B8C-BD0B-A21B758FE421> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
        0x7fff404ef000 -     0x7fff40523ff7  libGLImage.dylib (17.10.22) <2B314C76-C7E6-3AC5-9157-70B0529C1F9B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
        0x7fff40524000 -     0x7fff406b8ff7  libGLProgrammability.dylib (17.10.22) <757192B3-4509-3C26-B3B3-C10165F97661> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
        0x7fff406b9000 -     0x7fff406f5fff  libGLU.dylib (17.10.22) <B29F73B2-B5A9-3C38-AF77-351173D2E3DB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
        0x7fff41131000 -     0x7fff41140ff7  com.apple.opengl (17.10.22 - 17.10.22) <D5BF32A8-2E0A-345D-80A3-7CA7C2CF748D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff41141000 -     0x7fff412bafff  GLEngine (17.10.22) <0B6AF0FD-DBF3-3D91-B0EA-80402E9E1484> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
        0x7fff412bb000 -     0x7fff412e3fff  GLRendererFloat (17.10.22) <A3D159EB-39BB-3F7C-8C1E-005D81788963> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
        0x7fff420fe000 -     0x7fff42380ff9  com.apple.QuartzCore (1.11 - 841.2) <444E6F22-DFA6-391B-B51F-A96AE69E524D> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
        0x7fff42f01000 -     0x7fff4324aff1  com.apple.security (7.0 - 59306.120.7) <AEA33464-1507-36F1-8CAE-A86EB787F9B5> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff4324b000 -     0x7fff432d3ffb  com.apple.securityfoundation (6.0 - 55236.60.1) <79289FE1-CB5F-3BEF-A33F-11A29A93A681> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
        0x7fff43302000 -     0x7fff43306ff8  com.apple.xpc.ServiceManagement (1.0 - 1) <4194D29D-F0D4-33F8-839A-D03C6C62D8DB> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
        0x7fff43fb2000 -     0x7fff44020ff7  com.apple.SystemConfiguration (1.19 - 1.19) <0CF8726A-BE41-3E07-B895-FBC44B75450E> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
        0x7fff4429f000 -     0x7fff44622ff4  com.apple.VideoToolbox (1.0 - 2620.11.40.2) <53E0D852-61CA-34FE-9A9B-788708ADE495> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
        0x7fff47f81000 -     0x7fff48046ff7  com.apple.APFS (1412.120.2 - 1412.120.2) <1E8FD511-FDC4-31A2-ACDE-EB5192032BC6> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
        0x7fff49156000 -     0x7fff49157ff1  com.apple.AggregateDictionary (1.0 - 1) <B907CE7A-0122-3E63-BF39-0A242B0DD7C4> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
        0x7fff496f1000 -     0x7fff4970eff4  com.apple.AppContainer (4.0 - 448.100.6) <9C2D0065-9B38-3D1C-A090-46F129A1B3CA> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
        0x7fff49763000 -     0x7fff49771ff7  com.apple.AppSandbox (4.0 - 448.100.6) <7DAB58B1-8176-3FB0-A7B0-8A38E118E90B> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
        0x7fff49bec000 -     0x7fff49c10ffb  com.apple.framework.Apple80211 (13.0 - 1610.1) <B4B80CD6-B38E-3748-B30B-5088CCE9A7A8> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
        0x7fff49ece000 -     0x7fff49eddfd7  com.apple.AppleFSCompression (119.100.1 - 1.0) <2E75CF51-B693-3275-9A4F-40571D48745E> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
        0x7fff49fdc000 -     0x7fff49fe7ff7  com.apple.AppleIDAuthSupport (1.0 - 1) <F4651654-E24F-3BF4-8DDF-8F91E5219BA4> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
        0x7fff4a029000 -     0x7fff4a071ff7  com.apple.AppleJPEG (1.0 - 1) <4655FF70-9772-3D7C-8159-5A5E56C9F84B> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
        0x7fff4a45b000 -     0x7fff4a45fff7  com.apple.AppleSRP (5.0 - 1) <B683AD55-A121-31DD-9A87-3A31C35FEABF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
        0x7fff4a460000 -     0x7fff4a482fff  com.apple.applesauce (1.0 - 16.25) <33B66B71-64A4-365D-9953-E0545E69A5E7> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
        0x7fff4a541000 -     0x7fff4a544ffb  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <92580EE3-74BF-3488-90ED-C8EBD7A1B4C3> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
        0x7fff4a545000 -     0x7fff4a595ff7  com.apple.AppleVAFramework (6.1.2 - 6.1.2) <39C3583D-C824-3168-B67A-498487FD03D9> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
        0x7fff4a5de000 -     0x7fff4a5edff9  com.apple.AssertionServices (1.0 - 223.100.31) <478D2004-9B84-3AE9-9A0B-0A0B68ED028F> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
        0x7fff4ab2f000 -     0x7fff4af2aff8  com.apple.audio.AudioResourceArbitration (1.0 - 1) <9ABFE41A-FD01-3111-BA73-D2DD1BF96525> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
        0x7fff4b180000 -     0x7fff4b3c0fe0  com.apple.audio.AudioToolboxCore (1.0 - 1104.84) <FA17E892-6A1A-309D-95C7-30ACFC44319C> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
        0x7fff4b3c4000 -     0x7fff4b4e0ff0  com.apple.AuthKit (1.0 - 1) <375C3886-5430-3C02-BD2C-4244BF490ABA> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
        0x7fff4b69d000 -     0x7fff4b6a6ff7  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <F070F440-27AB-3FCF-9602-F278C332CA01> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
        0x7fff4b6a7000 -     0x7fff4b748ff5  com.apple.backup.framework (1.11.5 - 1298.5.10) <637CA389-627A-365C-98C2-D297C47D6EE3> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
        0x7fff4b749000 -     0x7fff4b7d5ff6  com.apple.BaseBoard (466.3 - 466.3) <1718A41A-9923-3FD0-96B8-82376E153D27> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
        0x7fff4b8d7000 -     0x7fff4b913ff7  com.apple.bom (14.0 - 219.2) <586F1D9C-23B0-3F38-9C5B-728E9DD8B953> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
        0x7fff4c492000 -     0x7fff4c4e1fff  com.apple.ChunkingLibrary (307 - 307) <32E0F1A1-9DD6-3B52-91C2-93643041AA60> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
        0x7fff4c63b000 -     0x7fff4c6c6ff8  com.apple.CloudDocs (1.0 - 698.14) <4CFF0DF0-8A89-3DAD-8A07-A208FDDD163B> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
        0x7fff4d388000 -     0x7fff4d398ffb  com.apple.CommonAuth (4.0 - 2.0) <91EC83B5-857D-3D4F-93B1-AAD7E0E029D8> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
        0x7fff4d3ac000 -     0x7fff4d3c3fff  com.apple.commonutilities (8.0 - 900) <12C6DEE5-1740-39A5-9711-6F815C6D77BD> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
        0x7fff4dac7000 -     0x7fff4de9cfc8  com.apple.CoreAUC (283.0.0 - 283.0.0) <BA9522E5-95D0-30D0-BEF4-691CEB51035B> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
        0x7fff4de9d000 -     0x7fff4decaff7  com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <14FC549B-86BD-396A-B03E-6F5219482943> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
        0x7fff4deed000 -     0x7fff4df0cffc  com.apple.analyticsd (1.0 - 1) <A4F653CA-2FD6-348B-B7B3-48D91A67508A> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
        0x7fff4e217000 -     0x7fff4e222ff7  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <8F8E586D-C153-3ABA-88B7-6CEC7F476F0E> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
        0x7fff4e4a3000 -     0x7fff4e4b3ff3  com.apple.CoreEmoji (1.0 - 107.1) <CDCCB4B0-B98F-38E8-9568-C81320E756EB> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
        0x7fff4eaf3000 -     0x7fff4eb5dff0  com.apple.CoreNLP (1.0 - 213) <40FC46D2-844C-3282-A8E4-69DD827F05C5> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
        0x7fff4ef8b000 -     0x7fff4ef93ff8  com.apple.CorePhoneNumbers (1.0 - 1) <B2CE100D-B82F-3481-86F6-7F85FF8BFAFB> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
        0x7fff4f980000 -     0x7fff4f9a3fff  com.apple.CoreSVG (1.0 - 129) <3141D198-0507-3F72-A2C9-752EAFE3EEB3> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
        0x7fff4f9a4000 -     0x7fff4f9d7fff  com.apple.CoreServicesInternal (446.7 - 446.7) <B2CEC515-2225-3CB1-B34A-904AAEA54FDF> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
        0x7fff4f9d8000 -     0x7fff4fa06ffd  com.apple.CSStore (1069.24 - 1069.24) <C96E5CE8-D604-3F13-B079-B2BA33B90081> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
        0x7fff4ff2b000 -     0x7fff4ffc1ff7  com.apple.CoreSymbolication (11.4 - 64535.33.2) <0E7A1529-C737-33FD-AA7D-A32EB8B192DA> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
        0x7fff50059000 -     0x7fff50185ff6  com.apple.coreui (2.1 - 609.4) <9B93CC42-804B-305A-8FCE-5F06821B544C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
        0x7fff50186000 -     0x7fff5033cff5  com.apple.CoreUtils (6.2.1 - 621.5) <CD4B58E5-1494-3457-84FF-3869378E2DC9> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
        0x7fff50476000 -     0x7fff50489ff1  com.apple.CrashReporterSupport (10.13 - 15016) <827F4E31-9F23-3683-AC5A-59CCA90F2359> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
        0x7fff50542000 -     0x7fff50554ff8  com.apple.framework.DFRFoundation (1.0 - 252.50.1) <19F79D32-71D3-3A87-98C9-B5C6C96076C4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
        0x7fff50555000 -     0x7fff5055afff  com.apple.DSExternalDisplay (3.1 - 380) <971F24F1-B1FC-3674-9C00-F88EEF94DC05> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
        0x7fff505e4000 -     0x7fff5065eff0  com.apple.datadetectorscore (8.0 - 659) <9FD9BDFA-3724-3BEA-946C-0473447196A3> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
        0x7fff506aa000 -     0x7fff506e7ff8  com.apple.DebugSymbols (194 - 194) <9BCE6685-6C45-3DF9-98EB-FCF8196160F0> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
        0x7fff506e8000 -     0x7fff50870ff6  com.apple.desktopservices (1.14.5 - 1281.5.3) <79972B8B-7B60-3AD5-9A5F-17976DE8080B> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
        0x7fff50b0d000 -     0x7fff50bd5ffe  com.apple.DiskImagesFramework (559.100.2 - 559.100.2) <DE281E96-21D0-3BE3-BEE0-D901B24D71EE> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
        0x7fff50bd6000 -     0x7fff50ca9ff1  com.apple.DiskManagement (13.0 - 1648.120.5) <650DBBE4-6624-3064-A26D-6BCAA0FE41F9> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
        0x7fff50d8c000 -     0x7fff50d90ff9  com.apple.EFILogin (2.0 - 2) <B95015BC-5BC2-33D9-AD94-01905DD56193> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
        0x7fff5221e000 -     0x7fff52639ff1  com.apple.vision.FaceCore (4.3.0 - 4.3.0) <1B5D7DD6-718E-3111-A702-EB04B8903662> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
        0x7fff52cd7000 -     0x7fff52e0fffc  libFontParser.dylib (277.2.5.3) <DEB18756-082F-359B-AE93-F9C3B5EC7AF4> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
        0x7fff52e10000 -     0x7fff52e44fff  libTrueTypeScaler.dylib (277.2.5.3) <B16255A6-C51A-328B-B679-8FBF64495770> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
        0x7fff52ea9000 -     0x7fff52eb9ff6  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <6396BC1F-13C1-37D7-91B9-1FF60910C7FA> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
        0x7fff5639a000 -     0x7fff5639bfff  libmetal_timestamp.dylib (902.14.11) <BE88F259-0A3C-3910-8983-FB5E2C905E87> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
        0x7fff57a4c000 -     0x7fff57a57ff7  libGPUSupportMercury.dylib (17.10.22) <B2E086E1-6E50-3A3D-B014-FCDAACBACE90> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
        0x7fff57a58000 -     0x7fff57a5efff  com.apple.GPUWrangler (5.2.4 - 5.2.4) <5B819701-9F0C-374B-8925-A22DFC16514F> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
        0x7fff57d7d000 -     0x7fff57da3ff1  com.apple.GenerationalStorage (2.0 - 314) <5613706F-710A-39E0-8B25-BA103A768613> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
        0x7fff58ed2000 -     0x7fff58ee0ffb  com.apple.GraphVisualizer (1.0 - 100.1) <0A86C9FF-4484-3C7F-BC71-3D23BDBE81CE> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
        0x7fff5907f000 -     0x7fff5913dff4  com.apple.Heimdal (4.0 - 2.0) <F2C504F6-E211-3AB0-9754-D96D2F96634B> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
        0x7fff59b3a000 -     0x7fff59b69ff8  com.apple.HelpData (2.3 - 199) <31ECA355-3529-3FD8-961A-5E5F70DAE1A8> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
        0x7fff5b2c1000 -     0x7fff5b2c9ff5  com.apple.IOAccelerator (438.5.4 - 438.5.4) <A3CF45E0-4D88-33BF-BAEC-690D5664CDA0> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
        0x7fff5b2d6000 -     0x7fff5b2edfff  com.apple.IOPresentment (1.0 - 37) <3EDBB454-D248-394B-A026-9717CD8535C3> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
        0x7fff5b675000 -     0x7fff5b6c0ff1  com.apple.IconServices (438.3 - 438.3) <2AE74790-64F1-3B0A-9534-DEEEE307E562> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
        0x7fff5b87e000 -     0x7fff5b885ff9  com.apple.InternationalSupport (1.0 - 45.4) <C22AA77A-EDA6-3626-8816-521A8CD43C4A> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
        0x7fff5b929000 -     0x7fff5b92dff4  JavaLaunching (43) <9427F093-E8E7-3AFE-8B35-77EFFAE37B47> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
        0x7fff5bb12000 -     0x7fff5bb31ffd  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <76DB5326-BE5D-3339-975C-D9FCF39A341E> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
        0x7fff5bc66000 -     0x7fff5bd34ffd  com.apple.LanguageModeling (1.0 - 215.1) <A6FAA215-9A01-3EE1-B304-2238801C5883> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
        0x7fff5bd35000 -     0x7fff5bd7dfff  com.apple.Lexicon-framework (1.0 - 72) <6AE1872C-0352-36FE-90CC-7303F13A5BEF> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
        0x7fff5bd84000 -     0x7fff5bd89ff3  com.apple.LinguisticData (1.0 - 353.18) <686E7B7C-640F-3D7B-A9C1-31E2DFACD457> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
        0x7fff5be2d000 -     0x7fff5be32ff7  com.apple.LoginUICore (4.0 - 4.0) <5D60C7D1-9DB7-30A3-9209-7E13644D3E9D> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
        0x7fff5c621000 -     0x7fff5c624fff  com.apple.Mangrove (1.0 - 25) <11A30F47-B1C1-375E-9FE7-0A196E92A52C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
        0x7fff5c88d000 -     0x7fff5c917ff8  com.apple.MediaExperience (1.0 - 1) <34E15DA2-02AA-32FA-99E1-9A139521E226> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
        0x7fff5c918000 -     0x7fff5c94bfff  com.apple.MediaKit (16 - 923) <14E38848-C9BD-37F1-AE44-FC4CC839E8A1> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
        0x7fff5d0f0000 -     0x7fff5d13cfff  com.apple.spotlight.metadata.utilities (1.0 - 2076.6) <C3AEA22D-1FEB-3E38-9821-1FA447C8AF9D> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
        0x7fff5d13d000 -     0x7fff5d20effa  com.apple.gpusw.MetalTools (1.0 - 1) <A23FFAB6-437C-303C-A3E8-99F323F8E734> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
        0x7fff5d26c000 -     0x7fff5d285ff4  com.apple.MobileAssets (1.0 - 619.120.1) <5AF95641-68C7-351A-A317-3C7B793502D6> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
        0x7fff5d442000 -     0x7fff5d460fff  com.apple.MobileKeyBag (2.0 - 1.0) <B564179F-A5E9-3BD8-892D-CEF2BE0DA0D7> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
        0x7fff5d6c3000 -     0x7fff5d6f3ff7  com.apple.MultitouchSupport.framework (3440.1 - 3440.1) <4E7CB188-382E-3128-8671-4A3EF6E06622> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
        0x7fff5dbf3000 -     0x7fff5dbfdfff  com.apple.NetAuth (6.2 - 6.2) <D660F2CB-5A49-3DD0-9DB3-86EF0797828C> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
        0x7fff5e613000 -     0x7fff5e65effb  com.apple.OTSVG (1.0 - 643.1.5.1) <CD494F00-9AA4-3A48-916B-EA8661F9772D> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
        0x7fff5f872000 -     0x7fff5f87dff2  com.apple.PerformanceAnalysis (1.243.2 - 243.2) <941698D6-EF00-3D59-8560-F160BC04B412> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
        0x7fff5f87e000 -     0x7fff5f8a6ffb  com.apple.persistentconnection (1.0 - 1.0) <FFC20BB6-9CF3-39F2-AE5C-8DEE348FE0C1> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
        0x7fff6137a000 -     0x7fff6138dffc  com.apple.PowerLog (1.0 - 1) <63A89A9B-2ACC-3378-9BD0-7FA971E07C2A> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
        0x7fff62209000 -     0x7fff62263ff6  com.apple.ProtectedCloudStorage (1.0 - 1) <969BF7A2-E989-3A22-BC1B-72B72E107229> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
        0x7fff62264000 -     0x7fff6227dffb  com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <A2E34123-7CED-378B-A43D-1B98B5B85F5C> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
        0x7fff626dc000 -     0x7fff62705ff1  com.apple.RemoteViewServices (2.0 - 148) <1C61CFC2-F76F-31E5-BA13-EFD5DC69C8D5> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
        0x7fff6286a000 -     0x7fff628a5ff0  com.apple.RunningBoardServices (1.0 - 223.100.31) <9FD1FC53-186A-3327-A359-B0BC7F4360EF> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
        0x7fff64185000 -     0x7fff64188ff5  com.apple.SecCodeWrapper (4.0 - 448.100.6) <813B3E57-6A95-3D7B-9094-C65D687A72B8> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
        0x7fff642fb000 -     0x7fff64422ff0  com.apple.Sharing (1526.31 - 1526.31) <2CB07F08-7794-3BF2-9ED5-BAB5C55C9D2C> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
        0x7fff6447b000 -     0x7fff64499ff2  com.apple.shortcut (2.16 - 106) <51323823-C5EB-3EE0-AA81-8D633A3F75BD> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
        0x7fff65835000 -     0x7fff65b2bff7  com.apple.SkyLight (1.600.0 - 451.4) <F5B9065A-E975-36D1-8D53-9FBF02171FAB> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
        0x7fff66378000 -     0x7fff66386ffb  com.apple.SpeechRecognitionCore (6.0.91.2 - 6.0.91.2) <820602AB-117B-3C3E-B20B-819CBC97B7A4> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
        0x7fff66448000 -     0x7fff666d2ffe  com.apple.spotlight.index (10.7.0 - 2076.6) <38E208FE-A4E5-3B6C-9937-97CA152F1BB2> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
        0x7fff66a60000 -     0x7fff66aa1ff9  com.apple.StreamingZip (1.0 - 1) <EFCDDC94-28EE-3BCA-A105-0A928D15ED8C> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
        0x7fff66bb8000 -     0x7fff66bc1ff7  com.apple.SymptomDiagnosticReporter (1.0 - 1238.120.1) <581F31D6-94CB-38AA-BD56-1A63606E516E> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
        0x7fff66c32000 -     0x7fff66c5cffa  com.apple.framework.SystemAdministration (1.0 - 1.0) <926BB2F5-E02C-30B7-949A-20EFE57CF242> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
        0x7fff66e78000 -     0x7fff66e88ff3  com.apple.TCC (1.0 - 1) <FD146B21-6DC0-3B66-BB95-57A5016B1365> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
        0x7fff673ad000 -     0x7fff67473ff0  com.apple.TextureIO (3.10.9 - 3.10.9) <E23E05ED-8190-3564-985E-446F15CB0709> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
        0x7fff675ff000 -     0x7fff67600fff  com.apple.TrustEvaluationAgent (2.0 - 33) <11DF5A28-4410-36A8-B3B8-BF1094BE1544> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
        0x7fff67638000 -     0x7fff67890ff0  com.apple.UIFoundation (1.0 - 662) <DFD3DD4A-E661-3A12-BB02-06898949617D> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
        0x7fff68503000 -     0x7fff68523ffc  com.apple.UserManagement (1.0 - 1) <E168206A-9DC1-3C67-A9A6-52D816DBD5B1> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
        0x7fff692cf000 -     0x7fff693b9ff8  com.apple.ViewBridge (464.1 - 464.1) <C698BAC9-26C8-39F1-BBC0-F57EBD2EFD7B> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
        0x7fff6955f000 -     0x7fff69560fff  com.apple.WatchdogClient.framework (1.0 - 67.120.2) <3B8EBB6B-77D0-317C-A3DB-D0D2E294B18D> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
        0x7fff6a18d000 -     0x7fff6a190ffa  com.apple.dt.XCTTargetBootstrap (1.0 - 16091) <D4F09EC7-C63F-3861-B5DA-3F7C0DFF153D> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
        0x7fff6a20a000 -     0x7fff6a218ff5  com.apple.audio.caulk (1.0 - 32.3) <7D3D2F91-8B1D-3558-B324-45BDF11306DB> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
        0x7fff6a55a000 -     0x7fff6a55cff3  com.apple.loginsupport (1.0 - 1) <31F02734-1ECF-37D9-9DF6-7C3BC3A324FE> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
        0x7fff6a55d000 -     0x7fff6a570ffd  com.apple.login (3.0 - 3.0) <1DC570FD-29EC-3AE8-BD34-D44C00E4621B> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
        0x7fff6d040000 -     0x7fff6d073ffa  libAudioToolboxUtility.dylib (1104.84) <BB234563-F952-3E7F-B630-4140DB5E0380> /usr/lib/libAudioToolboxUtility.dylib
        0x7fff6d07a000 -     0x7fff6d0aefff  libCRFSuite.dylib (48) <02C52318-C537-3FD8-BBC4-E5BD25430652> /usr/lib/libCRFSuite.dylib
        0x7fff6d0b1000 -     0x7fff6d0bbfff  libChineseTokenizer.dylib (34) <04A7CB5A-FD68-398A-A206-33A510C115E7> /usr/lib/libChineseTokenizer.dylib
        0x7fff6d0bc000 -     0x7fff6d144fff  libCoreStorage.dylib (551) <BBD3B3DC-270D-35F2-8C67-4595A257EEBB> /usr/lib/libCoreStorage.dylib
        0x7fff6d147000 -     0x7fff6d149ff7  libDiagnosticMessagesClient.dylib (112) <27220E98-6CE2-33E3-BD48-3CC3CE4AA036> /usr/lib/libDiagnosticMessagesClient.dylib
        0x7fff6d18f000 -     0x7fff6d346ffb  libFosl_dynamic.dylib (100.4) <68038226-8CAA-36B5-B5D6-510F900B318D> /usr/lib/libFosl_dynamic.dylib
        0x7fff6d36d000 -     0x7fff6d373ff3  libIOReport.dylib (54) <E3A2148E-C5B2-30A8-ACD3-E081DD02BE90> /usr/lib/libIOReport.dylib
        0x7fff6d455000 -     0x7fff6d45cfff  libMatch.1.dylib (36) <081FB6A9-0482-3697-A98B-6821FF476C6E> /usr/lib/libMatch.1.dylib
        0x7fff6d48b000 -     0x7fff6d4abfff  libMobileGestalt.dylib (826.120.5) <1977AD00-533A-31AA-8D74-EA6CB962F668> /usr/lib/libMobileGestalt.dylib
        0x7fff6d61d000 -     0x7fff6d61efff  libSystem.B.dylib (1281.100.1) <B6FDA8A9-3D2B-3BD5-B5B0-57D311C0FF3D> /usr/lib/libSystem.B.dylib
        0x7fff6d6ab000 -     0x7fff6d6acfff  libThaiTokenizer.dylib (3) <97DC10ED-3C11-3C89-B366-299A644035E7> /usr/lib/libThaiTokenizer.dylib
        0x7fff6d6c4000 -     0x7fff6d6dafff  libapple_nghttp2.dylib (1.39.2) <B99D7150-D4E2-31A2-A594-36DA4B90D558> /usr/lib/libapple_nghttp2.dylib
        0x7fff6d70f000 -     0x7fff6d781ff7  libarchive.2.dylib (72.100.1) <20B70252-0C4B-3AFD-8C8D-F51921E9D324> /usr/lib/libarchive.2.dylib
        0x7fff6d782000 -     0x7fff6d81bfe5  libate.dylib (3.0.1) <C4A5AE88-4E44-36FA-AD3E-0629AF9B94E0> /usr/lib/libate.dylib
        0x7fff6d81f000 -     0x7fff6d81fff3  libauto.dylib (187) <85383E24-1592-36BC-BB39-308B7F1C826E> /usr/lib/libauto.dylib
        0x7fff6d8e5000 -     0x7fff6d8f5ffb  libbsm.0.dylib (60.100.1) <B2331E11-3CBB-3BCF-93A6-12627AE444D0> /usr/lib/libbsm.0.dylib
        0x7fff6d8f6000 -     0x7fff6d902fff  libbz2.1.0.dylib (44) <BF40E193-8856-39B7-98F8-7A17B328B1E9> /usr/lib/libbz2.1.0.dylib
        0x7fff6d903000 -     0x7fff6d955fff  libc++.1.dylib (902.1) <AD0805FE-F98B-3E2F-B072-83782B22DAC9> /usr/lib/libc++.1.dylib
        0x7fff6d956000 -     0x7fff6d96bffb  libc++abi.dylib (902) <771E9263-E832-3985-9477-8F1B2D73B771> /usr/lib/libc++abi.dylib
        0x7fff6d96c000 -     0x7fff6d96cfff  libcharset.1.dylib (59) <FF23D4ED-A5AD-3592-9574-48486C7DF85B> /usr/lib/libcharset.1.dylib
        0x7fff6d96d000 -     0x7fff6d97efff  libcmph.dylib (8) <296A51E6-9661-3AC2-A1C9-F1E3510F91AA> /usr/lib/libcmph.dylib
        0x7fff6d97f000 -     0x7fff6d996fd7  libcompression.dylib (87) <21F37C2E-B9AA-38CE-9023-B763C8828AC6> /usr/lib/libcompression.dylib
        0x7fff6dc70000 -     0x7fff6dc86ff7  libcoretls.dylib (167) <9E5D1E0C-03F8-37B6-82A1-0D0597021CB8> /usr/lib/libcoretls.dylib
        0x7fff6dc87000 -     0x7fff6dc88fff  libcoretls_cfhelpers.dylib (167) <C23BE09B-85D1-3744-9E7B-E2B11ACD5442> /usr/lib/libcoretls_cfhelpers.dylib
        0x7fff6e12b000 -     0x7fff6e22ffef  libcrypto.44.dylib (47.120.1) <B48C0D1A-CDCB-34E4-921E-00EBFF1208DE> /usr/lib/libcrypto.44.dylib
        0x7fff6e232000 -     0x7fff6e23dfff  libcsfde.dylib (551) <8FBB94EC-712C-3C0F-A8A9-88EE5F4679EF> /usr/lib/libcsfde.dylib
        0x7fff6e245000 -     0x7fff6e2a4ff7  libcups.2.dylib (483.6) <FFE8FE67-A6CC-3C38-A9D7-D411D7B562F1> /usr/lib/libcups.2.dylib
        0x7fff6e2a6000 -     0x7fff6e30bff7  libcurl.4.dylib (118.120.2) <F2C246F3-460E-31A7-B900-2A9560533730> /usr/lib/libcurl.4.dylib
        0x7fff6e3ae000 -     0x7fff6e3aefff  libenergytrace.dylib (21) <DBF8BDEE-7229-3F06-AC10-A28DCC4243C0> /usr/lib/libenergytrace.dylib
        0x7fff6e3af000 -     0x7fff6e3c7fff  libexpat.1.dylib (19.60.2) <C9163264-BA81-3CC6-9B8C-48A9A0709DD5> /usr/lib/libexpat.1.dylib
        0x7fff6e3d5000 -     0x7fff6e3d7fff  libfakelink.dylib (149.1) <122F530F-F10E-3DD5-BBEA-91796BE583F3> /usr/lib/libfakelink.dylib
        0x7fff6e3e6000 -     0x7fff6e3ebfff  libgermantok.dylib (24) <DD279BF6-E906-30D3-A69E-DC797E95F147> /usr/lib/libgermantok.dylib
        0x7fff6e3ec000 -     0x7fff6e3f5ff7  libheimdal-asn1.dylib (564.100.1) <68FA1BE5-8FFC-3345-8980-8D8629EBA451> /usr/lib/libheimdal-asn1.dylib
        0x7fff6e3f6000 -     0x7fff6e4e6fff  libiconv.2.dylib (59) <F58FED71-6CCA-30E8-9A51-13E9B46E568D> /usr/lib/libiconv.2.dylib
        0x7fff6e4e7000 -     0x7fff6e73efff  libicucore.A.dylib (64260.0.1) <7B9204AC-EA14-3FF3-B6B9-4C85B37EED79> /usr/lib/libicucore.A.dylib
        0x7fff6e758000 -     0x7fff6e759fff  liblangid.dylib (133) <36581D30-1C7B-3A58-AA07-36237BD75E0E> /usr/lib/liblangid.dylib
        0x7fff6e75a000 -     0x7fff6e772ff3  liblzma.5.dylib (16) <4DB30730-DBD1-3503-957A-D604049B98F9> /usr/lib/liblzma.5.dylib
        0x7fff6e78a000 -     0x7fff6e831ff7  libmecab.dylib (883.11) <66AD729B-2BCC-3347-B9B3-FD88570E884D> /usr/lib/libmecab.dylib
        0x7fff6e832000 -     0x7fff6ea94ff1  libmecabra.dylib (883.11) <2AE744D2-AC95-3720-8E66-4F9C7A79384C> /usr/lib/libmecabra.dylib
        0x7fff6ee01000 -     0x7fff6ee30fff  libncurses.5.4.dylib (57) <B0B09D08-A7C9-38E9-8BF4-E4F4882F93A6> /usr/lib/libncurses.5.4.dylib
        0x7fff6ef60000 -     0x7fff6f3dcff5  libnetwork.dylib (1880.120.4) <715FB943-BA01-351C-BEA6-121970472985> /usr/lib/libnetwork.dylib
        0x7fff6f47d000 -     0x7fff6f4b0fde  libobjc.A.dylib (787.1) <CA836D3E-4595-33F1-B70C-7E39A3FBBE16> /usr/lib/libobjc.A.dylib
        0x7fff6f4b1000 -     0x7fff6f4b2ff7  libodfde.dylib (26) <2DDA61BF-E92A-3463-B1C4-D59E40D34D34> /usr/lib/libodfde.dylib
        0x7fff6f4c3000 -     0x7fff6f4c7fff  libpam.2.dylib (25.100.1) <732E8D8E-C630-3EC2-B6C3-A1564E3B68B8> /usr/lib/libpam.2.dylib
        0x7fff6f4ca000 -     0x7fff6f500ff7  libpcap.A.dylib (89.120.1) <CF2ADF15-2D44-3A35-94B4-DD24052F9B23> /usr/lib/libpcap.A.dylib
        0x7fff6f584000 -     0x7fff6f59cfff  libresolv.9.dylib (67.40.1) <B0F5D204-7EF2-3B0B-90EF-BB4D196FCC62> /usr/lib/libresolv.9.dylib
        0x7fff6f59e000 -     0x7fff6f5e2ff7  libsandbox.1.dylib (1217.120.7) <728BC15F-9A6C-3634-9427-60C01CB5A5D6> /usr/lib/libsandbox.1.dylib
        0x7fff6f5e3000 -     0x7fff6f5f5ff7  libsasl2.2.dylib (213.120.1) <E6375405-168D-3B75-8042-C8B329D01AB9> /usr/lib/libsasl2.2.dylib
        0x7fff6f5f6000 -     0x7fff6f5f7ff7  libspindump.dylib (281.3) <0C3A8B48-DC31-3F61-B4CC-746157042D0E> /usr/lib/libspindump.dylib
        0x7fff6f5f8000 -     0x7fff6f7e2ff7  libsqlite3.dylib (308.5) <AF518115-4AD1-39F2-9B82-E2640E2221E1> /usr/lib/libsqlite3.dylib
        0x7fff6f8d6000 -     0x7fff6f903ffb  libssl.46.dylib (47.120.1) <6209494A-4AAD-344E-992C-03ACD2D4C402> /usr/lib/libssl.46.dylib
        0x7fff6f906000 -     0x7fff6f950ff7  libstdc++.6.dylib (104.1) <26211C4C-8B34-3A63-8B38-61B195B586C8> /usr/lib/libstdc++.6.dylib
        0x7fff6fa33000 -     0x7fff6fa36ffb  libutil.dylib (57) <D33B63D2-ADC2-38BD-B8F2-24056C41E07B> /usr/lib/libutil.dylib
        0x7fff6fa37000 -     0x7fff6fa44ff7  libxar.1.dylib (425.2) <943A4CBB-331B-3A04-A11F-A2301189D40B> /usr/lib/libxar.1.dylib
        0x7fff6fa4a000 -     0x7fff6fb2cff7  libxml2.2.dylib (33.3) <262EF7C6-7D83-3C01-863F-36E97F5ACD34> /usr/lib/libxml2.2.dylib
        0x7fff6fb30000 -     0x7fff6fb58fff  libxslt.1.dylib (16.9) <86FE4382-BD77-3C19-A678-11EBCD70685A> /usr/lib/libxslt.1.dylib
        0x7fff6fb59000 -     0x7fff6fb6bff3  libz.1.dylib (76) <DB120508-3BED-37A8-B439-5235EAB4618A> /usr/lib/libz.1.dylib
        0x7fff70419000 -     0x7fff7041eff3  libcache.dylib (83) <A5ECC751-A681-30D8-B33C-D192C15D25C8> /usr/lib/system/libcache.dylib
        0x7fff7041f000 -     0x7fff7042afff  libcommonCrypto.dylib (60165.120.1) <C321A74A-AA91-3785-BEBF-BEDC6975026C> /usr/lib/system/libcommonCrypto.dylib
        0x7fff7042b000 -     0x7fff70432fff  libcompiler_rt.dylib (101.2) <652A6012-7E5C-3F4F-9438-86BC094526F3> /usr/lib/system/libcompiler_rt.dylib
        0x7fff70433000 -     0x7fff7043cff7  libcopyfile.dylib (166.40.1) <40113A69-A81C-3397-ADC6-1D16B9A22C3E> /usr/lib/system/libcopyfile.dylib
        0x7fff7043d000 -     0x7fff704cffe3  libcorecrypto.dylib (866.120.3) <5E4B0E50-24DD-3E04-9374-EDA9FFD6257B> /usr/lib/system/libcorecrypto.dylib
        0x7fff705dc000 -     0x7fff7061cff0  libdispatch.dylib (1173.100.2) <201EDBF3-0B36-31BA-A7CB-443CE35C05D4> /usr/lib/system/libdispatch.dylib
        0x7fff7061d000 -     0x7fff70653fff  libdyld.dylib (750.5) <7E711A46-5E4D-393C-AEA6-440E2A5CCD0C> /usr/lib/system/libdyld.dylib
        0x7fff70654000 -     0x7fff70654ffb  libkeymgr.dylib (30) <52662CAA-DB1F-30A3-BE13-D6274B1A6D7B> /usr/lib/system/libkeymgr.dylib
        0x7fff70655000 -     0x7fff70661ff3  libkxld.dylib (6153.121.2) <5EBB4886-C7B6-31D6-AA63-D861B2D58FCE> /usr/lib/system/libkxld.dylib
        0x7fff70662000 -     0x7fff70662ff7  liblaunch.dylib (1738.120.8) <07CF647B-F9DC-3907-AD98-2F85FCB34A72> /usr/lib/system/liblaunch.dylib
        0x7fff70663000 -     0x7fff70668ff7  libmacho.dylib (959.0.1) <D91DFF00-E22F-3796-8A1C-4C1F5F8FA03C> /usr/lib/system/libmacho.dylib
        0x7fff70669000 -     0x7fff7066bff3  libquarantine.dylib (110.40.3) <D3B7D02C-7646-3FB4-8529-B36DCC2419EA> /usr/lib/system/libquarantine.dylib
        0x7fff7066c000 -     0x7fff7066dff7  libremovefile.dylib (48) <B5E88D9B-C2BE-3496-BBB2-C996317E18A3> /usr/lib/system/libremovefile.dylib
        0x7fff7066e000 -     0x7fff70685ff3  libsystem_asl.dylib (377.60.2) <1170348D-2491-33F1-AA79-E2A05B4A287C> /usr/lib/system/libsystem_asl.dylib
        0x7fff70686000 -     0x7fff70686ff7  libsystem_blocks.dylib (74) <7AFBCAA6-81BE-36C3-8DB0-AAE0A4ACE4C5> /usr/lib/system/libsystem_blocks.dylib
        0x7fff70687000 -     0x7fff7070efff  libsystem_c.dylib (1353.100.2) <935DDCE9-4ED0-3F79-A05A-A123DDE399CC> /usr/lib/system/libsystem_c.dylib
        0x7fff7070f000 -     0x7fff70712ffb  libsystem_configuration.dylib (1061.120.2) <EA9BC2B1-5001-3463-9FAF-39FF61CAC87C> /usr/lib/system/libsystem_configuration.dylib
        0x7fff70713000 -     0x7fff70716fff  libsystem_coreservices.dylib (114) <3D0A3AA8-8415-37B2-AAE3-66C03BCE8B55> /usr/lib/system/libsystem_coreservices.dylib
        0x7fff70717000 -     0x7fff7071ffff  libsystem_darwin.dylib (1353.100.2) <6EEC9975-EE3B-3C95-AA5B-030FD10587BC> /usr/lib/system/libsystem_darwin.dylib
        0x7fff70720000 -     0x7fff70727fff  libsystem_dnssd.dylib (1096.100.3) <0115092A-E61B-317D-8670-41C7C34B1A82> /usr/lib/system/libsystem_dnssd.dylib
        0x7fff70728000 -     0x7fff70729ffb  libsystem_featureflags.dylib (17) <AFDB5095-0472-34AC-BA7E-497921BF030A> /usr/lib/system/libsystem_featureflags.dylib
        0x7fff7072a000 -     0x7fff70777ff7  libsystem_info.dylib (538) <851693E9-C079-3547-AD41-353F8C248BE8> /usr/lib/system/libsystem_info.dylib
        0x7fff70778000 -     0x7fff707a4ff7  libsystem_kernel.dylib (6153.121.2) <9F9902C9-A46F-3CA9-B7F9-5CCFE98FBF75> /usr/lib/system/libsystem_kernel.dylib
        0x7fff707a5000 -     0x7fff707ecfff  libsystem_m.dylib (3178) <436CFF76-6A99-36F2-A3B6-8D017396A050> /usr/lib/system/libsystem_m.dylib
        0x7fff707ed000 -     0x7fff70814fff  libsystem_malloc.dylib (283.100.6) <D4BA7DF2-57AC-33B0-B948-A688EE43C799> /usr/lib/system/libsystem_malloc.dylib
        0x7fff70815000 -     0x7fff70822ffb  libsystem_networkextension.dylib (1095.120.6) <6DE86DB0-8CD2-361E-BD6A-A34282B47847> /usr/lib/system/libsystem_networkextension.dylib
        0x7fff70823000 -     0x7fff7082cff7  libsystem_notify.dylib (241.100.2) <7E9E2FC8-DF26-340C-B196-B81B11850C46> /usr/lib/system/libsystem_notify.dylib
        0x7fff7082d000 -     0x7fff70835fef  libsystem_platform.dylib (220.100.1) <736920EA-6AE0-3B1B-BBDA-7DCDF0C229DF> /usr/lib/system/libsystem_platform.dylib
        0x7fff70836000 -     0x7fff70840fff  libsystem_pthread.dylib (416.100.3) <77488669-19A3-3993-AD65-CA5377E2475A> /usr/lib/system/libsystem_pthread.dylib
        0x7fff70841000 -     0x7fff70845ff3  libsystem_sandbox.dylib (1217.120.7) <20C93D69-6452-3C82-9521-8AE54345C66F> /usr/lib/system/libsystem_sandbox.dylib
        0x7fff70846000 -     0x7fff70848fff  libsystem_secinit.dylib (62.100.2) <E851113D-D5B1-3FB0-9D29-9C7647A71961> /usr/lib/system/libsystem_secinit.dylib
        0x7fff70849000 -     0x7fff70850ffb  libsystem_symptoms.dylib (1238.120.1) <25C3866B-004E-3621-9CD3-B1E9C4D887EB> /usr/lib/system/libsystem_symptoms.dylib
        0x7fff70851000 -     0x7fff70867ff2  libsystem_trace.dylib (1147.120) <A1ED1D3A-5FAD-3559-A1D6-1BE4E1C5756A> /usr/lib/system/libsystem_trace.dylib
        0x7fff70869000 -     0x7fff7086eff7  libunwind.dylib (35.4) <253A12E2-F88F-3838-A666-C5306F833CB8> /usr/lib/system/libunwind.dylib
        0x7fff7086f000 -     0x7fff708a4ffe  libxpc.dylib (1738.120.8) <68D433B6-DCFF-385D-8620-F847FB7D4A5A> /usr/lib/system/libxpc.dylib
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 14
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 4799
        thread_create: 0
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=628.2M resident=0K(0%) swapped_out_or_unallocated=628.2M(100%)
    Writable regions: Total=971.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=971.6M(100%)
                                    VIRTUAL   REGION
    REGION TYPE                        SIZE    COUNT (non-coalesced)
    Accelerate framework              1024K        8
    Activity Tracing                   256K        1
    CG backing stores                 1328K        4
    CG image                           284K       18
    CoreAnimation                     6400K       33
    CoreGraphics                         8K        1
    CoreImage                           52K        6
    CoreUI image data                 2576K       27
    Foundation                          24K        2
    Kernel Alloc Once                    8K        1
    MALLOC                           632.8M     1119
    MALLOC guard page                   32K        8
    MALLOC_LARGE (reserved)           7424K        3         reserved VM address space (unallocated)
    Memory Tag 242                      12K        1
    STACK GUARD                        432K       44
    Stack                             47.1M       45
    Stack Guard                       56.1M       32
    VM_ALLOCATE                        1.8G      663
    __DATA                            30.1M      349
    __DATA_CONST                        48K        3
    __FONT_DATA                          4K        1
    __GLSLBUILTINS                    5176K        1
    __LINKEDIT                       398.6M       26
    __OBJC_RO                         32.2M        1
    __OBJC_RW                         1892K        2
    __TEXT                           229.6M      340
    __UNICODE                          564K        1
    mapped file                      805.0M      310
    shared memory                      656K       19
    TOTAL                              4.0G     3069
    TOTAL, minus reserved VM space     4.0G     3069
    Model: MacBookPro13,1, BootROM 245.0.0.0.0, 2 processors, Dual-Core Intel Core i5, 2 GHz, 8 GB, SMC 2.36f101
    Graphics: kHW_IntelIrisGraphics540Item, Intel Iris Graphics 540, spdisplays_builtin
    Memory Module: BANK 0/DIMM0, 4 GB, LPDDR3, 1867 MHz, 0x802C, 0x4D5435324C3531324D3332443250462D3130
    Memory Module: BANK 1/DIMM0, 4 GB, LPDDR3, 1867 MHz, 0x802C, 0x4D5435324C3531324D3332443250462D3130
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x159), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1610.1)
    Bluetooth: Version 7.0.5f6, 3 services, 27 devices, 1 incoming serial ports
    Network Service: Wi-Fi, AirPort, en0
    Network Service: iPhone, Ethernet, en4
    USB Device: USB3.0 Hub
    USB Device: USB5537B
    USB Device: USB 3.0 Bus
    USB Device: USB2.0 Hub
    USB Device: USB2137B
    USB Device: iPhone
    USB Device: USB-C Digital AV Multiport Adapter
    Thunderbolt Bus: MacBook Pro, Apple Inc., 41.2
  4. #54
    The new release of the Teensyduino is very good, but I found a bug and the bug is reproducable on different computers/ Notebooks, under Windows 8.1 and Windows 10, as well as on the Arduino IDE 1.8.5 up to 1.8.12:
    If you used a TEENSY 4.0 board and want to change the MCU clock speed to 450 Hz (debug mode), the TEENSY 4.0 will not be uploaded with the compiled code (for example blink). Instead, the board is not longer detected on the USB-Port, until you change from TEENSY 4.0 to e.g. TEENSY 4.1 or TEENSY 3.2 and try to upload. Than you can reset the board.
    Please check it.
    Best regards: Mariano
  5. #55
    6,927
    Quote Originally Posted by Dr.Mariano1980 View Post
    Please check it.
    I confirmed there appears to be an issue with compiling a T4 with the Debug optimize option. I tried it at both 450 and 600mhz and in both cases the blink program did not blink and did not show up on USB port list.
    I could easily recover, by choosing a different option, do a build and press the program button on the T4
