Results 1 to 9 of 9
Thread: Debug and sketch upload over serial# UART?
    I am facing a situation where I need the on-board micro-USB of the Teensy for other purposes, but don't want to lose the ability to connect to PC, including for dev/debug over COM.
    Is there an example of anybody using any of the non-USB serial
    https://www.pjrc.com/teensy/td_uart.html
    for debug including sketch upload?
    Say, with an off-the-shelf USB-to-serial adapter: USB attached to the PC, serial attached to Teensy?
    Is it just a matter of making the Teensy Serial# show up as COM on the PC, or are there other constraints e.g. on sketch upload?
    25,496
    Teensy uploading is done using USB HID protocol. USB serial isn't used at all for uploading.
    Teensy only acts as a USB serial device while running your program, and only if Tools > USB Type is set to one of the options with Serial.
    So that means whenever I want to change the sketch, I have to physically unplug the target host and plug the dev PC into the on-board micro-USB?
    I could run the uploader on the target, as part of a test app.
    Start here?
    https://github.com/PaulStoffregen/teensy_loader_cli
    I found this
    https://forum.pjrc.com/threads/26024...a-new-USB-type
    so I could try to tailor a custom type to whatever the target hosts support/permit. As you mentioned in the original threat - thanks!
    From
    "Teensy can only be programmed through the USB Micro connector - or {for T_3.2} the equivalent USB pins connected on the underside. There is no mapping through UART Serial or other way to program a Teensy through the bootloader chip."
    https://forum.pjrc.com/threads/57963...Serial-adapter
    For debug printf to PC over a non-USB Serial, I'll try something like this
    https://www.amazon.com/CP2102-Module...dp/B009T2ZR6W/
    from https://openwrt.org/docs/techref/har....serial.cables
    If somebody has used something like this with a Teensy 3.x or 4.x and has a recommendation, links appreciated.
    Oct 2015
    Roma (IT, EU)
    360
    I use the CP2104, more compatible with Windows 10:
    https://www.amazon.com/WINGONEER-CP2...9657667&sr=8-9
    and yes, I often use Hardware Serial1 as a debug port to the PC.
    I have my own Serial Terminal, but any will do, for example the notorious PUTTY.
    15,518
    Yes if set to 3.3V and connected to Teensy UART that should work. Or it can be done with another Teensy with a simple ECHO program.
    @XFer linked item seems better as noted.
    TyCommander in use here works with Multiple Teensy's and should connect to the CP2104 as terminal too.
    Thanks guys!
